Question about Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS 2 OHM Car Audio Amplifier
I have a 4 channel amp n i am trying to hook up my highs and 6x9 but it gives me a high static noise . i tried the noise resister but that doesn;t work
  • 70 Answers
Did you put the ground loop isolator near the amp end and the deck end of the rca or near the EQ if you have one
Posted on Jul 28, 2010
Having problems with my highs amp
Use shielded cables.
BTW, how did you check the cables to determine that they are okay?
Nov 27, 2013 | Boss BV7334 3.2-Inch DVD/MP3 Receiver with...
Left channels weak and statiky
Maybe your amp is bad? Swich your right and left wires around and see. If the problem moves your player is bad. If it doesn't your amp is bad. Doubt it is the amp though if it is all of your left channels.
Apr 19, 2012 | Dual XD7500 AM/FM/CD Receiver, Motorized...
The master volume have a sond tha when it inn high become to noise and disturbing my ears
For decent signal to noise ratio your channel faders should be about 75% up. You should set the trims when punching down the PFL button for each channel so that peaks go up the meter to about 80% of max. Your master levels shoulld be from 50 to 80% up. You should be using BALANCED cables (TRS or XLR) everywhere. Your equipment should ALL be powered from a single receptacle or power conditioning module, even if it means running extension cords. Many people try to run unbalnced cables from this to their amps... it doesn't work and noise results. You didn't give us much info on your system so that we could analyze further
Sep 13, 2011 | Behringer XENYX 2442FX Mixer
Is it possible to hook up 2-6x9 and 2-12in.subs to the 7540a and still pack a nice punch
yes it is however the hookup for it requires something a bit unorthodox
you have 4 outputs (bridgeable)
channel 1 and 2 must be bridged (to lower the ohms) then connected to the 2 6X9 in Parallel..
this must then be set to the high pass frequency (eliminates bass)
lower all the settings as low as possible then turn them up slightly to increase volume to a level where its the hardest and clean sounding..lower volume after
this eliminates the bass and keeps the 6x9 pushing your mid range and high range frequency
now you have 2 channels remaining,, set 3 and 4 to low pass and connect each 12" to an individual channel. (this keeps the bass and ohms high so you will get a clean bass to match with mids and high's. Dont set or bridge for a low bass as it will jam out the 6x9 and your music will sound terrible.
so there u have a simple hookup that will work and keep you sounding clean. remember not to raise the volume on the 6X9 too much as you will blow them..
Mar 29, 2011 | Infinity 7540A Car Audio Amplifier
Constant RPM engine static during alert on 9500IX on Gold Wing Motorcycle. Only accessory to ever give engine static. Use multiple Apple music accessories, GPS, bluetooth, 80 watt amplifier, CB and...
Most likely you will need to get a group loop isolator for it. I think escort sells one on their site. Or a good quality car stereo shop can get you one from Escort or PAC.
Dec 30, 2010 | 9500IX Radar Detector
I'm getting static noise on only a few channels. The other tv's are ok. They are all hooked up to cable.
it is most likely that this issue is a broadcasting issue and not related to your tv. Signals get messed up while getting to your cable supplier.
Oct 11, 2010 | Polaroid Televison & Video
Powering 4 6x9 speakers, need amp
Hi firstof all your deck isnt really putting out 52 watts x4 more like 17-22w rmsx4 ,companies like to throw out some crazy numbers it seems. If your into Kenwood try out a KAC-8404 4-channel on the mids/highs that will put 50 w x4 rms at 4 ohms or if you wanna go a lil louder try the kenwood x600f that will throw 100w rms on each 6x9 at 4 ohms no problem. My system is very similar to yours but running 4 pioneer 5x7's in all the doors and powering it with the 8404 its loud and clean ,fan cooled and no problems at all. My subs are a pair of 15's soundstream t-4's powered by an Alphasonik pma2500a its throwing 800w rms on each sub running in stereo at 2 ohms.It can drown out the mids if i set it that way but my mids /highs cant take as much power as your kenwoods can or else id step up to the x600f too.
May 10, 2009 | Kenwood KFC-6982ie Car Mid-Range Speaker
2 channel amp to 6-6x9 wiring diagram
Hello magoocsl,
Yes, with the use of 2 high-pass and 1 low-pass crossovers, that Kicker amp will operate in what they call stereo and mono simultaneously (SAMS). You'd run 4 of the 6X9's in mono. Wire them in series-parallel with a low-pass crossover on the positive leg to the amp. The amp would see a 4ω load. The other two 6X9's would be wired as stereo, one to each channel with a high-pass crossover. Again, the amp sees a 4ω load.
Here's a link to the appropriate wiring diagram. The diagram is on page 5. Just substitute your 4 6X9's wired in series-parallel where they show the "mono" speaker.
http://www.kicker.com/sites/default/files/02KX300_400_500_800_2AmpManual.pdf
Hope this helps.
Apr 01, 2009 | Kicker KX500.2 Car Audio Amplifier
Jl audio 500/1 amp low ohm light at high volume
I would try running the subs in parallel. Pos to Pos Dual Voice, Neg to Neg Dual Voice. Then Run + to + stereo - to - stereo on both channels.
So you have + and - running to one channel and + and - running to the other channel.
Also your LPF filter could be set too high.
Feb 07, 2009 | Jl Audio 500/1 Car Audio Amplifier
Need specs and wiring options
  • 105W x 4 Channel Max. Power Output at 2o.gif Stereo
  • 60W x 4 Channel 0.1% THD at 2o.gif Stereo @13.8V (RMS Continuous Power)
  • 40W x 4 Channel 0.1% THD at 4o.gif Stereo @13.8V (RMS Continuous Power)
  • ChannelFlex Crossover
  • Adjustable High-Pass Frequency (50-200Hz, L/R Independent)
  • Low-Pass Frequency (120Hz)
  • Adjustable Bass-Boost Level (45Hz, 0-9dB, F/R Separate)
  • High-Current, High-Speed Output Devices
  • High-Efficiency, High-Energy MOS-FET Power Supply
  • Audiophile Grade Component Selection
  • Intelligent 7-Way Discrete Protection Circuitry
  • Noise Reduction with Low Distortion & Ultra-Low Negative Feedback
  • High-Level Input - Add on Capability
  • Epoxy Composite PCB
  • 2o.gif Stable Design
Each 6 1/2" speaker will see 40 Watts
Each 6"x9" will see 521/2 Watts
Yes your solution is correct. Front wired in stereo, bridge rear.
Dec 29, 2008 | Eclipse Car Audio & Video
Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS 2 OHM Car Audio Amplifier Logo
103 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
