Westinghouse AC window unit works great for a few hours and then it ices up. What causes it to ice up?
  • hungarian Jul 09, 2010
    One of the best explanations I have ever read on this site. Thanks for taking the time.
    President:
  • 1,561 Answers
When this problem occurs most people immediately think it is the fault of the refrigerant gas. More often the cause is the result of other difficulties.
It is most often the result of poor airflow.
Any time the airflow through an air conditioner is restricted the cooling system becomes affected. If taken to extremes the critical pressure-temperature balance of the cooling coil can be changed. If they drop too low the cooling coils surface temperature can drop below the dew point temperature of the room. When this happens the cooling coil will begin to operate as a refrigerator rather than an air conditioner. Rather than simply cooling the air it will collect and hold moisture. This moisture will then freeze onto the cooling coil where it will appear as ice.
With this information in mind the following are a few problems that can result in your air conditioner icing up:
1. Dirty filter.
To avoid this replace or clean your filter every couple of weeks of the cooling season. If a smoker, clean every week.
To clean filter remove from air conditioner, wet thoroughly, and lay in bottom of a sink. Sprinkle cleaner (laundry detergent works well) onto filter surface. Allow to sit for a few minutes. Then add enough hot water to to cover filter. Soak for 15 minutes. Remove from water and rinse. Allow to air dry.
2. Dirty or blocked cooling coil.
An air conditioner requires regular maintenance. Usually every two or three years. Every year would be best, but this can be costly unless you do it yourself. During cleaning the cooling coil should be degreased and washed to remove accumulated dirt and debris. Degreasing is important to remove any coatings on the coil. If not done greasy residue can trap and hold air borne particles. They will build up on the coil and affect heat transfer. If left too long this can result in the cooling coil becoming partially blocked. This will produce a lower airflow, which can lead to icing.
3. Dirty or blocked condenser coil.
The condenser coil is the one at the rear of the air conditioner. Its job is to dissipate the heat that is being removed from the room. Just like the cooling coil it too must be cleaned every few years. Since the condenser is outdoors it becomes exposed to a lot of dirt, pollen, and smog. Since airflow direction is from inside to outside it is the inside surface of the condenser that becomes dirty. Therefore to clean this part the air conditioner must be completely disassembled. If not cleaned regularly an airflow blockage here can even burn out the compressor. Before this happens though the lowering of airflow will affect the overall operation. This can result in the compressor efficiency dropping, the internal pressure-temperature relationships being affected, and the resultant production of ice on the cooling coil.
4. Inefficient compressor.
As describe above an inefficient compressor can cause icing up. When the compressor is inefficient the cooing coil may not get cold enough to shut off the cold control. It can hover just above the cut off point. This causes the cooling coil to refrigerate, rather than dehumidify. Ice on the cooling coil will result. If the compressor itself is at fault the air conditioner will usually be replaced. But note that many icing problems are misdiagnosed as bad compressors when they were actually one of the other faults discussed in this article.
5. Not enough refrigerant. Too much refrigerant.
Both scenarios can result in and icing condition. If your air conditioner was repaired recently suspect too much refrigerant. Mixed with an airflow problem this can be difficult to diagnose. If not repaired recently then suspect airflow problems before considering a refrigerant imbalance.
6. Outdoor temperature too low.
Icing can occur if the outdoor temperature falls below 60 Degrees Fahrenheit. When the outdoor temperature is too low the air conditioner pressure-temperatures can be affected, causing the cooling coil temperature to fall so low that the coil will refrigerate the room air. This results in ice production.
This problem is more prevalent in the fall. If it is hot during the day but cold at night suspect this problem as the cause of icing up. If this problem is suspected try running the air conditioner in the 'fan only' position. Leave the re-circulating vent open. This will circulate the room air without cooling it, while bringing in a small amount of outside air during the night. Alternately, turn of air conditioner at night and restart next morning as day becomes warmer.
7. Oversized air conditioner.
If the air conditioner is too large for the room size icing up can result. If oversized the air conditioner can short-cycle. This condition is usually seen as the air conditioner starting and stopping every few minutes. Even though it runs almost constantly the air conditioner will give poor cooling. Use a sizing chart to determine what is the proper air conditioner size for that particular room.
8. Cold control not shutting off.
If the cold control does not shut off the cooling coil surface temperature will drop below the room’s dew point and begin to refrigerate. This will allow ice to build up onto the cooling coil.
9. Cold control bulb broken or loose.
As in the previous paragraph this will result in the cold control not shutting off and ice to build up on the cooling coil. If this is suspected remove the front grille and inspect the bulb. If broken replace cold control. If bent, kinked, or not securely fastened suspect a problem here.
Take care.
Posted on Jul 03, 2010
Why does it work for a few hours, then shut off?
Sounds like you may have ice build up on the coil. This will cause the refrigerant pressures in the AC to go out of desired range and cause the unit to shut down. Ice build up can be caused by a dirty filter or blocked coils in the front of the AC or a fan not running up to speed. There could be another problem with the AC refrigerant charge, but normally the homeowner can not fix that. If the unit shuts down, it will not start again until the pressures equalize.
Jun 07, 2015 | Frigidaire FRA144HT2 Air Conditioner
Westinghouse ice maker quit working
Is it your ice maker, or possible the blades that crush the ice or dispense the cubes? What can happen in the latter case is that during the storm the ice melted and pooled in the cutter mechanism. Then, when power was restored, the blades were frozen solid. To fix, investigate taking out the cutter mechanism and letting it thaw and drain. Then reinstall and use frequently for the first few days to prevent refereezimg.
Feb 26, 2014 | White-Westinghouse White Westinghouse...
It cools great when first turned on. After so many hours of cooling it stops cooling
Have you checked up in filter area at ceiling to see if fins are frozen or frosted bad? If they are dirty, they can cause frost/ice and AC goes in to fan only until frost/ice is gone. When did unit actually get a good cleaning last? Too many registers closed or blocked can cause freeze up as well. Does this unit have ducted or non-ducted system?
Aug 18, 2013 | Dometic Rooftop RV Air Conditioner
PROBLEM WINDOW AC ICING
Dirty coil.Clean air filter, blower, evaporator coil and then check.
Aug 17, 2012 | Heating & Cooling
MY AC WORKS FOR FOUR HOURS PER DAY AND BARELY COOLS DOWN THE HOUSE, NOT MUCH AIR COMING UP TO THE UPSTAIRS OF THE HOUSE. AFTER 4 HOURS, THE OUTSIDE UNIT SHUTS UP AND NOT MORE COOL AIR COMES IN. BEFORE THIS...
I am not understanding exactly what is happening with your unit. You say it only runs for 4 hours a day and then say that after 4 hours the outside unit shut off. But you don't describe the condition of the outside unit! Is there ice on your outside unit after it runs for four hours or is it so hot that the housing would fry an egg? Since it works for four hours and then stops working, I would guess that ice forms on the condenser grill which tells the thermostat that your air is much colder than it actually is. Then it takes time for the ice to melt off again. Am I close? If so this condition is usually caused by your unit being low on freon making everything work harder. But it could also mean that you have a leak in the system somewhere. But it shouldn't be much of a leak or it wouldn't run for the 4 hours.
I would recommend you charge it to the correct level and then check for leaks.
Aug 03, 2011 | Carrier 38CKC060 Air Conditioner
Our Quietmaster 's cooling works for a while and then doesn't.
Remove the front cover and make sure the temp sensing wire is in place on the front of the evaporator coils. If it has fallen and is touching the evaporator plumbing the unit can preform as you described.
Also check for signs of icing / ice build up on the evaporator coils after the uint has run for a couple of hours. Ice build up will also cause this symptom. IF you do find that the unit is icing up that can be caused by:
1. A very dirty evaporator
2.. A clogged Air filter
3. Contaminated by internal plumbing debris / clogged freon passages
4. A blower Fan motor running to slow.
5. Freon Pressure and return lines touching together usually either on the side of the unit or just behind the center chassis air wall enroute to the compressor.
6. A corroded electronic control board.
As you can see above there are several things that can cause the symptom your described. It cetainly sounds as if you either have an icing problem or a control board problem.
The next time the symptom occurs... place the unit of fan only for at least 30 minutes and then see if you can switch it to cool, and actually have it cool. If it does cool properly after switching to fan only for 30 minutes you most likely have an icing problem.
Thanks for using FixYa.
Kelly
Jul 20, 2010 | Friedrich QuietMaster Electronic SS12J30D...
Ice fallingfrom split ac
Try turning off the ac unit for about an hour.(Your might have too small of ac unit or just have the ac set too low..Causing the coils to freeze.
May 27, 2010 | LG Art Cool LA121CNP wall/window Air...
Ice maker not working, no water or ice dispensed.
Cause found to be faulty ice/water control board which is located at the back left hand side of the condensor behind the water solinoid valves.This is the single most expensive part of the ice maker!
Oct 13, 2009 | Westinghouse Refrigerators
1.5T Voltas Vetris window AC. Ice formation
I think the more likely problem is that the unit is slightly short of gas\ refrigerant, which is a common cause of icing up evaporator coils and this sound you describe. First check that the air filter is clean. Another cause could be the defrost sensor is faulty, but I would think not. Some ice isn't actually a bad thing, but quite common as long as it doesn't form over too much of the coil, or get too thick.
Aug 15, 2009 | LG Heat cool Window Air Conditioner
I have the automatic frozen yogurt-ice cream & sorbet maker ICE-20 series made bby CUISINART. The first few times the icecream came out perfect & great. I made ice cream yesterday and it was soupy. I put...
I would actually let the freezer bowl thaw out on a level surface. Then place perfectly level back in the freezer for 24 hours. Should work again. Enjoy!
-Tha Mp3 Doctor
Dec 10, 2008 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Heating & Cooling Logo
123 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
