Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
PROPANE IGNITER We have had our igniter replaced twice in a year. The repair man said our washer shaking could make it go out. Is this correct? Where can we buy these igniters?? My husband watched him put it in, and our son-in-law is an electician. Thanks Bonnie
    Scholar:
    New Friend:
  • 70 Answers
I have never seen one go bad because of a dryer. I would call heating companies in your area and ask them to sell a igniter.Have the brand,model and serial number for the heater. You could get one off the Internet to. I would pull out the igniter and make sure the screw is tight and that the deflector doesn't it the igniter
Posted on Apr 18, 2008
BernzOmatich3200n
Repairing Benzomatic Patio Heater
The above link unfortunately states Benzomatic no longer provides parts for their patio heaters. There may be a comparable generic part out here that you can substitue for the original part.
Tall Propane Patio Heater Starting Striker Switch
The second link shows an igniter switch that may work. You can find other possiilities by doing a search on the web for" Propane Heater igniter switch"
May 16, 2014 | Stainless Patio Heaters - Steel Deluxe...
The oven lights up, but the oven will not reach temperature and it smells of propane. The burners work fine.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Feb 24, 2011 | Ovens
Some of my burners will not lite...i see a small spark. It will light if i use a lighter. what part will solve the issue?
There is likely a buildup of crud inside of the gas unit - this can best be cleared with a toothpick poked into the gas jet holes - specifically the holes in front of the igniter. It is also likely the igniter is sparking, but not enough to light up the gas. Theoretically, very little spark is needed to light propane - but I think we've both seen that as not such a practical theory!! If cleaning out the holes ( I would also remove the burner and shake out the crud ) doesn't work, then I would consider replacing the igniter. It is not difficult to replace and your local BBQ store should have igniters in stock. Take the old igniter with you to match it up, to be sure you get the right configuration for your Q. Best of luck in this and Merry Christmas - AND thanks for using Fixya!!
Dec 16, 2010 | Ducane 30400040 Stainless Steel Grill
The oven seldom lights. Igniter is working, there's usually no smell of gas, burners and broiler are working properly, replaced dual gas safety valve with no help. When it does light, it won't maintain...
Just because it glows that does not mean it is not bad...
Oven not Working or Oven not Heating
heatman101
Sep 07, 2010 | Maytag Kitchen Ranges
I have a Bosch tankless propane water heater 125fx. Yes, I know it's ****, we replaced the igniter switch last year. Then struggled with ordering parts to repair a water leak. During the leak, it was...
There is likely an onboard relay stuck in the open position.
This is a gas appliance and should be serviced by an authorized BOSCH repair center to avoid potential catastrophe.
Thanks!!
Aug 06, 2010 | Bosch AquaStar 125FXKIT-LP 125FX Liquid...
Armstrong furnace ultra 80sx doesnt always lite on first try,service repair man replaced smartvalve,sensor and igniter he says its ok if it doesnt always lite on the first try ,sometimes it takes three...
Sounds like your gas valve is sticking. Your repair man is somewhat correct by meaning that the furnace will attempt to start 3 times before going out on "Lock-out". The furnace is reaching it's expected life and you will start experiencing more frequent issues with it. Check into some of the incentives to get a replacement with a higher efficiency rating. The newer units have greatly improved in performance as well as comfort.
Jan 13, 2010 | Heating & Cooling
I have a kenmore range the oven burner does not work but the broiler does. The igniter on the oven element appears to glow in preparation of lighting but propane does not come out of the element. Now when...
heatman101
sgf
Nov 16, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Burner igniter won't click or work
This is an easy problem to fix. If your repair man is correct and it is the spark module and not a wire harness problem you can pick up a spark module as sears for about $37 and it only takes a couple of minutes to install. Just pull off the back panel and replace the module. This is a repair that anyone can do. I would recommend unplugging the unit before replacing.
Jun 20, 2009 | Maytag MGR6772 Gemini Gas Kitchen Range
How to install an igniter?
if the heater uses a hot surface igniter its a simple matter of unscrewing the igniter and replacing it with another unit. if it is a spark ignition, the spark wire is a heavy insulated wire that goes to the gap. check out white-rodgers for a replacement. if your furnace uses a purge mode get a purge cycle programmable igniter.
Nov 12, 2007 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
70 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
