Question about Maytag Atlantis MDE6400AY Electric Dryer
When drying clothes, there is a loud banging noise, almost like if the clasp to overalls is hitting the inside of the dryer. Right now I am drying towels, so there is nothing metal or hard that could be hitting around, but I am still hearing that noise.
    President:
  • 1,194 Answers
Check all exposed screws, and make sure they are tight. Loose cabinet screws may cause a banging sound. Make sure nothing is loose inside the drum. Remove the lint trap and look below the lint trap holder for any loose items that may have slipped through the cracks.
Check to see if the drum is supported on wheels or rollers. Sometimes these can wear and require replacement.
Good luck and have a nice day
Posted on Jul 03, 2010
Clunking banging noise
It may be something stuck in the drum, ie a bra wire, which would have extra weight on it whilst the clothes are wet. If this is the case, it will need looking at sooner, rather than later, as it will just be causing further internal damage
Dec 19, 2013 | Fisher and Paykel Dryers
Maytag neptune dryer making loud banging noise mde6700ayw
First, check the vane's (paddles inside the drum) to see if one is loose. Post back the results.
Nov 06, 2012 | Maytag Neptune MDE6700A Electric Dryer
I was drying my clothes and heard a loud bang and the dryer started making a weird noise so i shut it off then turned it back on and it kept doing it then the drum just stopped moving completely
The sound was probably the spring tensioner hitting the chassis when the belt broke.
the dryer needs a new belt. Without knowing the model, hard to describe disassembly
You might be able to get a good maintenance tech off hours who can do this reasonably
by checking on Fixya or Craigslist as it can be a bit of a nuisance. Approximately
an hour to do and around 7 to 10 dollars for the belt.
Jul 31, 2011 | Dryers
We have an estate by whirlpool dryer that quit working. During last cycle it made a loud bang noise that ended the dry cycle and the clothes inside were dry. When we tried to restart it, it wouldn't...
The fuse is tied into the door switch circuit and looks like this:
Unplug the dryer and remove the rear cover. All the heater components is back there.
Service manual and more info are HERE at my FixYa tip.
Jul 17, 2011 | Estate TEDX640JQ Electric Dryer
How will i open the dryer to see if there
You probably need to remove the back cover and look into the dryer that way.
Post if you need anything else.
Jun 18, 2009 | Dryers
Loud banging noise while drying
the Idler bearing maybe going. its fairly easy to replace. go here http://www.repairclinic.com/Maytag-Dryer-Parts?s=b4a8c203
the part is cheap and i will show you how to remove the front door and replace the bearing.
May 28, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Banging Noise in Kenmore Dryer
There are two rollers that hold the drum in place. I'm betting that one of those rollers have broken or fallen off. It's not a very easy fix since you'll have to take the dryer completely apart to fix it. Good luck!
May 25, 2009 | Dryers
Clunking grinding sound
It sound like there is change or hard object in the inner dryer tumbler fins Not sure what model or make the dryer is need more info please.Maytag inglis??????
May 07, 2009 | Dryers
Dryer makes alot of noise when drying clothes.
First you will have to locate the two screws inside the dryer. Open the door and look up inside the trim around the opening of the dryer. Take them out then the top of the dryer will come right out. Look at the very from of the dryer. There should be 4 small "slides" attached to a trim piece. If there are any missing that is probably your problem. I just went through this problem. The pieces each are no longer than an 2" each but cost almost 8.00 a piece. They are easy to replace though. You might also have to replace the whole trim piece as I did because it was completely worn out. Very easy to replace.
Jan 13, 2009 | GE DWXR483EBCC Electric Dryer
Maytag Atlantis MDE6400AY Electric Dryer Logo
254 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
