Question about Toshiba Computers & Internet
Computer freezes as soon as I strike a key at log-in . XP Pro O\S . Wont boot in safe mode. Cannot boot from installation cd either. Any suggestions?
  • Toshiba Master
  • 6,487 Answers
Base from the description of your concern, lets do this we need to reset your BIOS settings to its default so restart the computer then access the BIOS menu by pressing the DEL key or it depends on your computer what ever the key that it uses to access BIOS menu, then from there look for the option to restore BIOS to its default and then save the changes and restart the computer and check if that fix the problem.
If still same problem open again BIOS menu and from there we need to change the boot sequence select the CD/DVD drive as the first boot device and then save changes and put the operating system installation disc and and restart the computer you should now be able to repair or do a fresh installation of your operating system now.
Posted on Jul 03, 2010
start your laptop before booting windows press f8 button continuously
ndows 2000 / XP users
bulb.gif If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
Microsoft Windows Vista and Windows 7 users
To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Sep 27, 2011 | Lenovo G460 Laptop Computer - 06779XU...
My laptop get restart in an intervals or get hang ...
This will occur if the Windows files are Corrupted or Fragmented, the solution is to backup by logging in to Safe Mode. Please restart the computer and try pressing F8 Key to select Safe Mode. If the Safe Mode is working fine then please backup the data and Format the computer using the Window XP or the Operating System Disc which you have. If the Safe Mode is not working then use any Linux CD like Ubuntu (www.ubuntu.com) it's free! Then boot the CD to backup the data for any external Hard Drive or Pen Drive and format the Notebook using the appropriate Operating System Disc like Windows XP, Vista, or Windows 7.
Mar 26, 2011 | Toshiba Satellite Pro L300 Notebook
I have a toshiba satellite a205-4707 when i got it it would freeze at startup i had a ancient copy of xp pro sp1 i could only install with power cord unplugged.even after install if i plugged in power cord...
http://www.4shared.com/file/oE15gXll/killdisk_and_boot-cd-iso.html
get this from my shared drive(read instructions in there)
and wipe your disk clean (Warning...this process will make you lose all data on disk so be careful, if posible backup all critical data that you need)
once done install WinXP SP3(get a Windows XP cd from a friend or download a pirated copy from net) look for "WinXP SP3 piratebay" in google
when installing WinXP make more than 2 partitions (C, D, E)
Install WinXP in C
once done, let Windows boot and show Desktop
install WinVista or Win7 in D
use E for saving your critical data
Nov 29, 2010 | Toshiba Satellite A205-S4617 Notebook
Can't access laptop computer in safe mode, keyboard freeze up
Try booting your system from a LIVE cd like linux, a verson of Hiren's tools, or the UBCD (ultimate boot disc for windows). If your keyboard still freezes with the alternate OS, you may have a hardware malfunction.
Jan 18, 2010 | Compaq Computers & Internet
Every time I log in my computer freeze
When booting up press F8 and boot in safe mode then run MSCONFIG and make sure your computer turns on running only basic programs. It could be you have a program running that is causing it to freeze as soon as you boot up. If it still freezes in safe mode you might need to repair windows using the original CD.
Dec 17, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Out of frequency range
When you are booting the PC as soon as you see your Computer Make's logo disapear, start hitting the F8 key, this should bring you to the boot selection screen, select Safe Mode, change your resolution in there. Reboot.
Jun 22, 2009 | Dell Computers & Internet
Gateway MX6927 Windows Xp won't boot
put your xp disk in the optical drive.Turn off computer. Turn computer back on as soon as you turn it on start tapping f 12 constantly.it should go the boot menu giving you a choice of booting from cd or hard drive choose boot from cd.Be sure you choose repair rather than new installation or you could loose all your information stored on the hard drive,I personally would try safe mode first you can get to safe mode by tapping f 6 when you first turn on your computer.
May 04, 2009 | Gateway MX6927 Notebook
I just installed xp pro and it keeps freezing
I would suggest that you run only one stick of Ram at a time to determine if they are the problem.. Also these CPU's had heat problems that damaged the cpu. This also causes freezing. I would consider resetting the CPU and the heat sink, and case fans are clean and working.
Dec 10, 2008 | Computers & Internet
Can't get a picture
Turn of your computer. disconnect external devices like printer, scanner and then try. If you still have the same problem boot in safe mode by tapping F8 key as soon as u turn on the computer. In the advanced option window select safe mode and log in as administrator. Then disable all third party services and startup items and then check. If nothing works you have to do a repair installation in case you have the XP installation CD or try System Recovery
Oct 08, 2008 | HP Pavilion dv9000z Notebook
Lost admistrator password
There are 2 options if you have forgotten the password.
1)Turn the PC Off.
2)Now, as soons as you push power buttin to turn it ON, keep tapping F8 key
3)Select safe mode and enter.
4)Click on the adminstrator user and try to log in without typing any password.
If you are able to log in great otherwise Windows needs to un-installed and re-installed.
Jun 10, 2008 | Microsoft Windows XP Professional With...
Computers & Internet Logo
16 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
