Question about Rheem Water Heaters
Rheem hot water system- Not getting hot enough.
I have a Rheem quick recovery hot water system, i am in australia and it has a mandatory tempering valve fitted that limits it to 50degrees, but on cold mornings it barely gets hot enough to have a warm shower,no cold water needed!
i have wound the tempering valve all the way and it is set to the highest setting. Any ideas would be greatly appreciated thanks.
Vee
  • 68 Answers
Sound like the mixing valve is damage.. even though the valve is mandatory rheem tankless system don't really need one due to the fact you can set the temp to avoid scalding..these unit will only go up to 120F (48C) The only reason you wll need a mixing valve is when you store water because you have to mantain a temp to kill bacteria and since there is no storage on the tankless it just does not make sense to have one. also you can turn down the temp on the control at anytime to any desire temp..this is a plumbing regulation in many part of the world that need to be look at a little more carefully..not only where you live.
Posted on Aug 12, 2010
Rheem rte13 standby (green) light not on
You might have crossover problem caused by bad faucet cartridge.
http://waterheatertimer.org/Crossover.html
The green standby light should come on when 240Volt power is applied. Page 6 manual.
Both red lights should come on when tankless is activated. Page 6 manual
RTE 13 requires 60 amp breaker and 6 gauge wire
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
http://waterheatertimer.org/pdf/Rheem-TanklessElectricUC_AP15447.pdf
Factory temperature setting is usually default 120 degrees.
Adjust temps page 11 manual
Thermostat calibration is always approximate.
120 degrees is not hot enough to burn the skin.
Exceptionally cold incoming water temperature can cause tankless not to heat enough hot water: install tempering tank to preheat water to room temperature.
Tankless cannot be exposed to more than 11 grains hardness in water. Delime tankless yearly, clean water filter monthly, do not install low-flow restrictions or conserve water since the flow rate must remain high for tankless to activate.
Rheem does not post service manuals for their tankless water heaters.
Call Rheem 800 432-8373
Aug 05, 2012 | Rheem Tankless Hot Water Heater...
My rheem (20) instatanious gas hot water heater takes so much longer to heat up in the colder months wasting too much water and also losing water pressure when it finally does get hot.In the warmer months...
2 possible things: tempering tank and crossover.
http://waterheatertimer.org/Tempering-tank.html
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Add a comment for more help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 08, 2011 | Rheem Water Heaters
Our gas water heater (Rheem Optima Quick recovery 81 series) heats the water as evidenced by the steaming water we can release from the temperature and pressure relief valve but we get no hot water from...
Sounds like a plumbing problem.
Since no tap gets hot water, chances are good the problem lies in the hot water pipes between the water heater to the first Tee.
Look for sediment lodged in water heater hot water pipe.
Or sediment lodged in elbow or Tee.
Other problems can be in play.
Faulty check valve or mixing valve if these are installed.
Faulty recirculation system if this is installed.
Also crossover at single-handled faucet where the cartridge is bad and lets the cold water flow into hot water pipe whenever another faucet is turned on. If you are getting cold water out the hot tap, and you know the hot water heater has hot water, then crossover is suspect > in addition to sediment blockage at hot water heater.
Upvote the help.
For a price, expert works with you while you work on timer or any do-it-yourself project.
May 15, 2011 | Rheem Water Heaters
I have a Rheem EcoSense tankless water heater that I want to set the temp to 140degF. How do I set it internally for this?
1) The best place to find this information in your manual.
Typical Rheem manual in my files shows temperature is adjusted by pressing UP and DOWN temperature buttons on remote.
2) Manual says: Temperatures of up to 140°F
(60°C) for Light duty models and up to 180°F
(82°C) for Heavy Duty models can be
achieved with the MAIN (UMC-117) remote
control and a dip switch adjustment. Only
qualified service personnel should perform
this adjustment. Only factory authorized
remote control(s) should be used.
3) Typical manual shows information on page 22-23. Search pdf for 'temp'
http://waterheatertimer.org/pdf/Rheem-RTG74IndoorOutdoor_owners.pdf
4) This information squares with what I heard before that trained service technician is needed to adjust water temperature.
I think Rheem does this since tankless will not achieve that rise in temperature if incoming water is cold.
BTUs put out by tankless burner has limit.
If incoming water is colder than certain temperature, then tankless cannot raise temperature quick enough as water passes through burner.
5) You might also need a tempering tank, to modify cold water in winter:
6) Suggest you also read the yearly maintenance required for tankless.
For example tankless are prone to lime build up and need to be de-limed each year with vinegar.
Lime build up will certainly affect water temperature.
7) Following 2 links might be helpful for tankless owner:
http://waterheatertimer.org/pdf/Delime-tankless-water-heater.pdf
http://waterheatertimer.org/pdf/Paloma-Tankless-Error-Codes.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
Mar 04, 2011 | Rheem Tankless Hot Water Heater...
I am only receiving half of the normal amount of hot water.
You have electric water heater.
Electric water heaters are fully repairable by homeowner, excluding hybrid type.
Rheem electric water heaters:
http://www.rheem.com/products/tank_water_heaters/electric_water_heaters/
Rheem fury series manuals and models
http://www.rheem.com/product.aspx?id=09DF2BDD-5E11-4D32-B574-84ACFB8A4619
Age of Rheem water heater is shown first 4 digits of serial number located on side of tank: for example 0705 means July 2005.
Serial number also shows model number & wattage of elements in case you need to buy new generic 4-bolt type 4500 Watt element from hardware store.
A) If your water heater receives very cold incoming water, it may not heat fast enough to keep tank warm.
Add a tempering tank.
Add insulation over entire water heater except TP valve. Insulate pipes completely.
Read more information:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
B) 40 or 50 gallon water heater is 240Volts and tank will have 2 access panels on front.
Rheem ships all water heaters with 4500 Watt elements.
Narrow down the suspects:
C) Water heater has some hot water.
This tells us upper element is working.
And that water heater electricity is working.
And that reset button is not tripped.
And that heater is not experiencing run-away overheating event.
That gives us 3 solid suspects.
1) lower element is burned out. Test lower element using inexpensive multi-meter from Home Depot.
http://waterheatertimer.org/How-to-test-water-heater-element.html
Replace element with same wattage shown on label, and clean out sediment:
This will restore water heater to full 99% efficiency.
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
2) Upper or lower thermostat is bad. Replace both thermostats for about $25.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
If you want to test thermostats and all parts before replacing anything:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
3) Burned or shorted wire. Turn off power. Open covers on side of tank. Remove insulation. Inspect parts for signs of high heat and burning. Especially lower element. Tighten any loose wires. Replace part that shows signs of burning.
Put insulation and cover back over thermostats so cooler outside temperature doesn't cause thermostat to misread tank temperature.
geno_3245_185.jpgRheem 4500 watt element
Dec 14, 2010 | Rheem Water Heaters
The water want stay hot very long
Age of Rheem
water heater is first 4 digits of serial number located on side of tank: for example 0705 means July 2005.
Serial number also shows model number & wattage of elements.
B) If cold outside temperatures are not to blame, your water heater may have a bad thermostat or bad lower element.
C) 40 or 50 gallon water heater is 240Volts and tank will have 2 access panels on front.
D) Water heater has some hot water.
geno_3245_183.jpgRheem element
Dec 14, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Not heating water hot enough or as much water.
You probably have a bad heating element. Probably the upper element.
Feb 03, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have replaced my electric water heater and I have checked everything I can think of and I still run out of hot water in 3 minutes. What on earth is the problem.
3 minutes?? does the water run cold then? or just warm?
Is this what the tank you replaced was doing? If so, then you may have: 1 a recirculating pump instant hot water system thats faulty and allowing cold water backflow into hot water piping. 2 A tempering valve that has stuck, allowing cold water into your hot water system.
Or maybe a broken or missing dip tube in your new heater.
If after 3 minutes the water is coming cold out leave that faucet running and go to heater and feel the hot water outlet pipe from the heater. if that pipe is hot then the heater is not the problem. If the hot pipe from the heater is cold the heater is the problem. (Make sure the cold pipe coming into the heater is connected to the Right side marked "cold" !) If there is a tempering valve by the heater: feel the output from the tempering valve, if it is cold and the pipe from the heater to the tempering valve is hot, then the tempering valve is the problem. If all these are OK somewhere in your plumbing system hot and cold may be connected possibly a faucet or showerhead that is shut off at the spout/head, but hot/cold handles are left turned on then cold water can backflow thru hot pipe.
Jan 18, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Water Heaters Logo
207 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
