Question about SanDisk Audio Players & Recorders
My sansa m230 driver mp3 player is not detected as removalble disk i mean as a flash drive on my laptop how can i fix this issue
  • 820 Answers
When you're able to change USB mode in the display:
- From the Main Menu, select Settings > USB
- Select in "Auto Detect", "MTP" or "MSC": choose MSC for viewing the player as a removable disk.
When you cannot select MSC mode in the player's menu, force MSC mode with the player switches/buttons:
1. Turn device OFF.
2. Facing the hold switch: slide it to the right so an orange color would show, putting the device on Hold.
3. Connect the device to the PC with the provided USB cable.
note
In MSC mode: Before disconnecting the USB cable always go through the safely remove hardware icon in the lower screen of your computer on the right. Left click the icon to see all removable disks and left click on the removable disk drive letter of the player to disconnect: after the message you can take out the USB cable.
Posted on Jul 03, 2010
Pls driver for sansa sandisk m230 model
You can download the driver from the manufacturer's web site at http://www.sansa.com
Apr 07, 2010 | SanDisk Sansa m230 MP3 Player
How to delete music from sanDisk M230
>if you have the data cable means connect it with the computer
>Then go to the My computer and there you can find a removable drive it might be with the name of san disk
>opened that drive and you can find the music folder over there and from there you can remove the music files
............All the best
Nov 19, 2009 | SanDisk Sansa m230 MP3 Player
Wont turn on
Slide the hold switch to off and when detected as a flash drive,format the device.... After this if it still doesnt work,use sansa updater to update the firmware
Sep 19, 2009 | SanDisk Sansa m230 MP3 Player
Sansa clip problems with driver
okay
there u go
rate me fix ya
choose the model of sansa thta u got
http://www.sandisk.com/sansa/#/support-0/
Aug 08, 2008 | SanDisk Sansa m230 MP3 Player
Hello
The software is available from the SanDisk website
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Jun 22, 2008 | SanDisk Sansa m230 MP3 Player
Sandisk m230
Hi big dee. Deleting songs from your M230 can be done by either browsing the player through your Windows Explorer and then selectively deleting the music file, or by formatting the player which would delete all of your music files. It's also important to know that your player has 2 modes -- MTP and MSC -- because music files saved in one mode would not be seen in the other mode, and vice versa. To switch the modes on your player, use the menu and navigate as follows: Menu > Settings > USB You would get a choice of "Autodetect" (this is for MTP) and MSC. Here's how to delete the files: Step 1: Plug in your player to your computer. Open explorer and check if your player is detected. Your player's LCD would display "USB Connected" and the mode would be indicated below that. If your player's mode is MTP: A. Look for the Sansa M230 icon on Explorer (it will be recognized as a Portable Audio Device). Double left click on it to browse the player. B. The player will have 2 sub-folders: "Data" and "Media". Double left-click on the "Media" folder and either find your music files or open the "Music" folder to find your music files If your player's mode is MSC: A. Look for the Sansa M230 icon and drive letter on Explorer (it will be recognized as a "Removable Drive". Double left click on it to browse the player. B. The player will have several sub-folders such as "Audible", "Config", "Record". You may already be able to see your music files or the player may have a "Music" sub-folder. Open that to check for your files Step 2 Once you've located your files, you may now be able to delete them. Step 3 Once you've unplugged your player, the M230's LCD will display the message "Rebuilding Library". Let that process complete, then you may turn on your player to confirm that the files have been deleted. To format your player, just right-click on the M230 icon in Explorer, then select "Format". When the Format window appears, make sure to select "FAT" as the File System type, and also make sure that the "Quick Format" checkbox at the bottom of the Window remains un-checked. I hope this info helps. Enjoy your M230. :)
Apr 25, 2007 | SanDisk Sansa m230 MP3 Player
Help..!!!
sandisk have a upgrade to fix connection problem download, install it ,plug it and upgrade it via internet. works for me.
Mar 14, 2007 | SanDisk Sansa m230 MP3 Player
Sansa e130 cant open
On not being able to detect any files when viewing Sansa in windows: try changing the format mode on the Sansa device - on mine I go to Settings and then USB and then changed it to MSC. I was then able to see the files in Windows and delete a bunch of them and then resynch in Windows Media Player.
Dec 20, 2006 | SanDisk Sansa m230 MP3 Player
San Disk Sansa m 230 512 MB
Your problem is probably beacause you accidently deleted "AudibleActivation.sys" from your "Audible"-folder. Format the sansa and then use "reset to factory settings" to make the file appear again. It might be a good idea to make a backup on your hard drive, just in case, and make the file hidden.
Oct 31, 2006 | SanDisk Sansa m230 MP3 Player
417 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
