Question about Sony PlayStation 2 (PS2) Console
NO signal to tv
HI - I can hear the unit powering up and spinning the disk, but I get no signal to the tv (audio or visual). The configuration browser does not appear on the screen either - just a black screen of death . . .
  • ZANAAF1 Nov 07, 2008
    When i connect my ps2 it powers on but no video signal is detected to tv. i checked the cable i am sure the cable is ok.
  • Sony Master
  • 1,183 Answers
There could be two problem ,
1. the cable you are using to connect the station to the box is faulty.
2. the video card signal may be bad, try connecting a computer flat panel
Thanks
Mandeep
Posted on Apr 17, 2008
There is no image or light coming from my projector
Hi Sane,
Multimedia Projectors uses a high power lamp to project the image onto a screen. These lamps have a typical life of 2000-3000 hours. It is quite possible that it may have blown.
  1. Confirm that the unit itself switches on. You should have some sort of visual feedback from the projector that the unit is switched on, ie. the power light comes on, if it doesn't, check your power chord.
  2. If there is power on the unit, but no image/light, check the unit for a fault indicator/light. Cross reference this with your user manual.
  3. If you are unable to verify or do not have a user manual, "google search" your make, model and fault-code, else
  4. approach a sales consultant at your nearest Audio & Visual retailer for advise.
My take is that the lamp has blown and needs replacement. These can be obtained from a Audio & Visual Retailer and can be self-installed with a little technical knowledge.
Everything You Need To Know About Replacement Projector And TV Lamps.
Here is what it looks like and what it typically costs:
multimedia projector lamp life Google Search
Dec 28, 2014 | Office Equipment & Supplies
The playstation's audio and visual is not working
Hello,you will want to reset the video output.First make sure the unit is off,the yellow video and red and white audio cords are connected to the tv then press and hold down the power button till you hear the second beep.The unit is now reset.
Jan 15, 2011 | Sony Playstation 3 (PS3) Console
Stereo will not play sound when CD is inserted. tuner works fine and the stereo says the cd is playing but there is no sound... HELP!!!
hello sir hi, If the CD is playing, but is no sound coming out from the player, this may be the likely trouble. sorry there are no quick fix for this.
  • check for selector switch contact, a faulty switch with poor contact does not connect the correct circuit where the signal of the CD should go to be amplified.
  • dirty or loose CD lens contact, a visual circuit inspection is needed here.
  • signal break from the CD lens to the power amplifier is needed to be checked, this requires to be checked by a technician with an oscilloscope to trace where the signal got lost. this is the best way to find the trouble.
  • The spindle is not spinning or spinning fast to properly read the disk. OR
  • Bring it to a Car stereo dealer and ask for service. They have in-house tech guys to analyse the trouble.
If the price of service is higher or very close to a new one, i guess its time to buy one.
Sep 13, 2010 | Alpine CDE-9852 CD Player
How do I connect my Yamaha RX-V463 surround sound system to an analog tv? The tv only has the three RCA jacks for audio and video. the RX-V463 has many jacks, and the manual is no help. the manual does...
Actually, the Quick Start Guide on page 6 of the manual shows the TV connection.
Consider that the TV is simply a visual element in your entertainment system and the rest will sound easy.
Run a single RCA cable from the receiver to the TV's Video IN so you can use its menus and view whatever video comes into the receiver.
Manage whatever audio you want to hear in HI-FI directly from its source to the receiver and NOT washed through the inferior audio electronics and speakers of the TV.
Jul 18, 2010 | Yamaha RX-V463 Receiver
Unable to play DTS-HD & True-HD
What do you hear? Do all other modes work ok?
If Audio Select (Page 44 and 98) is set to HDMI you will hear silence if no HDMI signal is present. I think AUTO is the best choice here.
On Page 98 of the manual it says a bunch of things concerning automatic signal detection and input selection.
Initial configuration D) INIT. CONFIG
Use this feature to select the settings of the audio input jack select, active decoders and extended surround when you tum on this unit.
Audio select AUDIO SELECT
Use this feature to designate the default audio input jack select setting (see page 44) for the input sources connected to the DIGITAL INPUT jacks when you tum on the power of this unit.
HDMI set E)HDMI SET
Use this feature to select the component to play back HDMI audio signals.
Support audio S. Audio
Use this feature to select whether to play back HDMI audio signals on this unit or on another HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = RX-V663
FUNCTION
Plays back HDMI audio signals on this unit. The HDMI audio signals input at the HDMI input jacks of this unit are not output to the HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = OTHER
HDMI component connected to the HDMI OUT jack.
NOTES
This unit transmits audio and video signals input at the HDMI input jacks to the HDMI out jack only when this unit is turned on even if "S.AUDIO" is set to "OTHER".
I'd look in these areas for specific guidance.
Apr 22, 2009 | Yamaha RX-V663 Receiver
No audio output
Were you playing it very loudly when it died?
The manual is here for reference...
http://www.docs.sony.com/reflib/docget.asp?manualid=11654&template_id=1&region_id=1&DL=',600,560,10,10,'Manuals'
It discusses troubleshooting this problem on page 50.
When you turn the receiver ON does you hear a light click in about 5 seconds? That would be the protection circuitry turning OFF to allow the amplifiers to function. The delay is to allow the circuitry to stabilize before it sends any output to the speakers. If you don't hear a click the unit is Protecting the speakers due to malfunction somewhere.
If no click and no apparent messages try turning the speakers OFF using the Speakers button directly below the Power button (1/0). This will eliminate or point to external shorts as the cause.
Does the unit click after 5 seconds of Power ON with the speakers OFF? Isolate your shorted speaker or wire problem.
Still no sound at the speakers when you turn them ON?
We need to establish if there is any programming flowing through the receiver.
A quick basic check would be to tune an FM station, if you have a tape deck attached, place it in Record or Record/Pause mode so it can display the input signal levels. You should see the record meters fluctuating with the level of the program selected. If you don’t have a tape deck, run an RCA cable pair from the audio output for a tape deck to an analog audio input on your TV. Select that input on the TV and you should hear the FM station, or anything the receiver is configured to play. If it's silent then there is no audio signal circulating in the receiver to get out to the amplifiers.
If you hear the program on the TV but not through any attached speakers, then the amplifiers are all disabled for some reason.
If there is no audio flowing through the receiver the problem could be a switch in the wrong position, source not selected, muting on or a multitude of other things.
Let me know how this turns out.
Apr 03, 2009 | Sony STR-DE695 Receiver
No Audio no video on an Element FLX3710
Bad control board. ~$300. Take TV back to wherever you bought it if still under warranty or Purchase new TV.
Mar 13, 2009 | Element Electronics FLX3711B 37 in. LCD TV
Ibm 8303-21g front audio pin configuration
Manual usually has diagrams and pin configuration for your system.
If you don't have the manual go to their web site and take a look.
Feb 06, 2009 | IBM Computers & Internet
Need instruction to hook up dvd player
You will need a TV or monitor with audio/visual inputs. The better ones have what is known as an S/VHS input, which separates the TV picture signal for better color reproduction. You will need to be able to switch your TV, usually by the channel selector, to the proper input for audio visual signals. Sometimes this is known as Video 1, Video 2, A/V etc. These are usually below Channel 2. Maybe your remote has that option. You will need an a/v cable. This is a three-connector cable with RCA plugs on each end. Connect the DVD player to the TV as follows: 1. Yellow cable, from video OUT on the DVD player, to video IN on the TV. Video is ALWAYS yellow. 2. Red and white cables from audio OUT on the DVD player to audio IN on the TV. 3. If you have S/VHS capability, buy an S/VHS patch cable which will have the three plugs mentioned, plus a round 4-pin plug. Select S/VHS OUT on the DVD player, and S/VHS IN on the TV. When using S/VHS, ignore the yellow connector. It is for composite video and not needed. Here's a hint: Your YV audio/visual inputs will usually be on the back of the set. Some better units have a/v inputs in front. What if my TV doesn't have a/v inputs? If your DVD player as an RF output, connect an RF "f" cable from that output to the antenna in cable on your TV. Otherwise buy an RF converter (about $20 or so at Radio Shack). Connect your a/v cable (yellow, red and white) from the DVD player to toe converter, then connect an RF cable (like the kind your cable box is connected with) to the antenna input on your TV. This signal usually comes in on Channel 3. Let me know if your problem is more complicated, It seems like a lot of wires and connections, but it is really straightforward, Remember, yellow is ALWAYS video. The two audio cables can be connected without worrying about color.
Dec 13, 2008 | Televison & Video
Ps2 slimline.
You mean A/V ( Audio /Visual)cables.  This could be several things.  Motherboard bad. A/V Socket on back of Slim has a bad connection to the motherboard.  Try it on another TV, you may have a bad input on the TV.  You selected the wrong input on the TV. The channel is not set properly on the TV.
The first two can be repaired by a Technician that knows about Playstation Repair and has plenty of Current experince.I run the website www.playstationclinic.com, and will charge up to $51 to repair this, if it is related to the first two possible problems.
Oct 19, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
109 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
