Question about Medical
Spacelab burdick eclipes II. lead v5 is having trouble connecting, sensing, print out flat line. not working by changing connecting clip. kent
  • cao777 Jul 04, 2010
    EKG machine, spacelab burdick eclipes II. lead v5 is having trouble detecting, sensing, print out flat line. not working by changing connecting clip. kent
  • 3,083 Answers
Although I've never worked on this exact machine, it sounds like the lead has a bad connection point inside the machine, and most likely the jack. The machine will have to be disassembled to effect repairs, and investigate whether the jack is bad, or if there's a broken solder joint, etc. Of course, the problem could be a bad sensing channel in the unit, but that's not usually the case. Good luck, hope this helps.
Posted on Jul 04, 2010
    President:
  • 1,070 Answers
Welcome to FixYa
i hope by following check-you can Clear it...Check line voltage
Check battery charge[Discharge battery charge by uplug and Charge again]
Faulty Power code
Check each cable Properly plugged in/Check for any damge{if needed Change it]
Check Paper Size...Loaded Properly....[Look your Manual for More Instruction]
Switch off unit and Restart it and try again....Still problem it may need Manual Repair...
I hope you got it...Thanks for Contacting Fixya
Posted on Jul 03, 2010
The down arrow wont move below dtv
check all your device connection leads if you are having trouble selecting things such as apps, DVD,VCR etc it suggests the TV cannot sense the connection to the device and so ignores the option and does not present it as selectable in the preferences.
Dec 18, 2015 | Televison & Video
My sizzix eclips won't turn on
Sizzix Eclips help please - Make The Cut! Forum
forum.make-the-cut.com/discussion/25227/sizzix-eclips-help-please
Jun 10, 2012 - 9 posts - ‎6 authors
I did email Sizzix but they won't answer until during regular business ... If you turnedoff the cutter, then start again, it should work properly. Turning off the grid lines and plus signs on the mat.
Nov 18, 2013
htv question
Sep 16, 2012
Plug In for the Sizzix Eclips, please!
Oct 8, 2011
roland blades
Jun 10, 2011
More results from forum.make-the-cut.com
[PDF]Help - Sure Cuts A Lot
Nov 14, 2015 | Saws
Burdick atria 6100 ecg machine is printing very faint prints each time i prin.
It's one of two things, either:
1) Your thermal printhead is dirty or going bad. Rub a pencil eraser over the printhead to clean it.
2) There's not enough pressure between the thermal printhead and the advancing assembly.
While printing, press the sliding door towards the unit, does the print get darker? If so, the mechanism might not be holding tight which indicates the clip may be damaged. If it stays light, clean the printhead with the eraser as mentioned earlier..
Feb 13, 2014 | Medical
Schiller AT-Plus, I cannot get all leads to print in sequence I avr v1 v4 II avl v2 v5 III avf v3 v6 not sure what a student did to change the...
The unit is apparently printing out in Cabarra sequence. To restore the correct lead sequence, do the following: Hit the ALT key followed by 7 then 1, hen the stop key. This will restore standard lead sequencing.
That is the start of the battle. If you desire a 3+1ryth format with a lead 2 at the bottom, which is our standard format, then you have more to do. For this format hit the ALT key followed by 1 then 0 followed by the stop key.to set the ryth lead to lead II at the bottom of the page, hit ALT followed by 3 then 8 then 2 followed by the stop key. If your filters are not enabled hit Alt 5 6 stop, alt 5 8 stop, Alt 8 3 stop, ALT 8 1 stop.Do a test print after all of this and be certain the unit is configured to your taste prior to a live patient.
Jun 14, 2011 | Schiller Welch Allyn Cardiovit At 2...
We have following errors on Siemens BURDICK E350 ECG apparatus: ECG machine not write properly on lead V2 Paper jam accurred skipped 2 ECG paper instead of 1 case. Please help how solve the errors on...
we have a burdick e 350 ekg machine i can put the patient info with no problem
but when it comes to doing the ekg i get an error across the screen that says u1 or uI please help thanks
Jan 24, 2011 | Medical
Epson 78900, black smudges on right end of each line printed ...
There is some '' absorbing pad'' at some strategic places in your printer, when you print too much after a while those pad, and head cleaning pad gets dirty and trouble start. Its a bit of a job, removing all the clip to open the cabinet, also dont place those pad in the water they grew like tampax. Replace it with dry sponge... Does it make sense to you?
Oct 09, 2009 | Epson Stylus Pro 9800 InkJet Printer
I need some pictures on problems of life perhaps i have to make a chart of it.......
You need to search the net for image on the problems of life, or if you want to be creative you could go ahead and make a chart.
I hope i have been helpful.
Jun 15, 2009 | Life Science 3 Lead Ekg / Ecg Cable W/...
Epson LX-300+II not printing in draft 10 cpi using visual studio .net
use courier font. it works just as draft font. no problem in VB-6 i hope it will also work with .Net as well.
tell if dont work.
asad khan
justasad@hotmail.com
Oct 27, 2008 | Epson LX-300 Matrix Printer
Schiller AT-2 EKG
Hello Genesis3kr, You changed the mode by selecting automatic for the 12 lead function rather that the manual. I suggest an operational inservice from your local Biomed Technican or education dept. If nether is available than contact 'http://www.schilleramerica.com' select 'Contact" and request a local company rep for one and bill your education or Biomed dept. (been there do that). Good luck. Please inform me of the out come.
Oct 23, 2008 | Schiller Welch Allyn Cardiovit At 2...
Medical Logo
Top Medical Experts
Electro Med Services...
Rhonda Webster
Rhonda Webster
Are you a Medical Expert? Answer questions, earn points and help others
