Question about Refrigerators
I have an amana refrigerator model abd2233dew. What type of water filter do I need for the back so the ice maker will work?
    President:
  • 1,891 Answers
The factory filter is a ukf8001 cost 38.92 . the filter may not make the ice maker work but if will help .. . if water comes out of the foutain then filter will not help ice mker work .. mm
Posted on Jul 03, 2010
Ice maker is not making ice? Is their a problem with the water? Do I need a new ice maker?
Check to see if water is entering the ice maker.
Be sure the water valve is working and it is not clogged
Have you recently changed the filter ?
Oct 13, 2010 | Amana ARB1905C Bottom Freezer Refrigerator
Amana ARS2665AW side by side ice maker not filling
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Aug 27, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Ice Maker not working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
ghhjd
Jan 27, 2009 | Amana 22.6 cu. ft. Side-By-Side...
GE Ice Maker not working.....Water in the door is working......
the fill tube that runs into the back of the icemaker is most likely frozen up in the cabinet. use a blow dryer to warm it up and you should be back in business..
Dec 20, 2007 | Amana ASD 2624 Side by Side Refrigerator
Refrigerators Logo
77 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
