Question about Whirlpool Duet GHW9150P Front Load Washer
I have the 9150pw4. Is it normal for water to stay in the discharge pipe at the pump when the wash cycle is over? Or should all lines be empty?
  • 259 Answers
Yes it is normal for some water to remain in the drain hose. As the pump drains all the water out of the machine and begins to draw air, the water that cleared the pump will not have anything behind it to push it out. You should not have any water remaining inside wash tub however.
Hope this helps you!
Posted on Jul 03, 2010
Hotpoint WMA76 - been on a normal wash cycle but wont spin to drain water - cycle finished, drum full of water and cant empty. How do we empty it to open machine?
Remove drain outlet hose from point where it discharges into waste pipe, and lay the hose down into a bucket or bowl, this should let the water syphon out, enabling you to open the door.
Dec 29, 2010 | Hotpoint WMA76 Front Load Washer
I have a problem with my Kenmore Washer. I have tried everything in this article, and although I got the washer back up and running for a load, it's starting to show the same problem again. The water will...
If a coin goes in the drain line and is the same diameter it can stay in and sometimes flip and act as a flapper. One time it may be open and the next flip and close the line off. Take the line off and try and see if it is obstructed.
Oct 27, 2010 | Kenmore 44072 Front Load Washer
During a normal washing cycle the machine stops at "rinse"
see if it takeing water out it will not let any more water in if there is water in try puting on a drain and see if its emptying if not there is a blockage in your wast pipe or your pump as gone i would try and clean your waste pipe1st and see if your pump works if your pump as gone and you need to get your water out try and move the washer near a door to the out sie and lie the waste pipe flat this will let the water go hope this is some help stuart
Jul 02, 2009 | Fisher and Paykel Fisher & Paykel Washer
Dishwasher not emptying
either the pump is not working or the discharge hose is clogged, if you have an air gap on the sink take the hose off and hold it down see if the water comes out by tself if so the pump is bad if not the drain is colgged take out the bottom tray you will need a 1/4 inch nut driver take the plastic screen cover plate off clear it of debris, there is a sharp metal blade in there so be careful, after cleaning it out turn on to rinse and see if it drains if not you will need to either replace the dishwasher or the pump, dollar for dollar new dishwasher time
May 30, 2009 | Westinghouse 24 in. MDB421 RF Built-in...
Does not pump water during the wash cycle.
It sounds like you are on the right track.
Open the dishwasher, remove the bottom rack, then remove the thumb nut in the middle of the unit that secures the lower wash arm and housing. Look for debris and clear any you find. Try again. If no joy, you will have to repeat the first step and also remove the wash pump upper housing that is secured with torx head screws. Same thing after you remove it - look for debris in the impeller area and remove it.
If you have to remove the wash impeller, you will need a 1" offset box wrench and as I recall a 1/4" socket. The 1" offset box wrench is needed to keep the impeller from turning while you remove the center nut. You will also need to remove the upper discharge line retainer clip to get that out of your way. Inspect the impeller for any debris and especially cracks or missing blades. If the impeller is damaged it will need to be replaced.
While you have this thing apart, check the lower wash arm and upper wash arm discharge pipe assembling for any obstructions.
I am assuming the motor runs ok and the timing cycles seem normal.
May 03, 2009 | Dishwashers
Pump constantly emptying
make sure that the drain line is higher than the water level in the tub. If it isn't the water will just drain
Mar 30, 2009 | Washing Machines
Ashing machine not emptying
check the drain pipe is not blocked, to empty the machine manualy get a bowl on the floor and lower the drain pipe into it and fill to stop water flow lift pipe up in air and lower to start draining again when empty if pipe not blocked i would suggest a new pump located under the drum and easy to fit
Feb 05, 2009 | Hotpoint WMA46 Front Load Washer
Maytag discharge into wastepipe backs up, floods laundry room.
best approach is be sure to clean drain pipe build up over the years may have created partial blockage
Apr 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Aeg 72630 update will not rinse during rinse cycle
If the drain lines were plugged, there may have been enough pressure on the pump to fault out. Make sure the sewer line is completely open, as well as the lines at the pump.
Jan 14, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
41 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
