Question about Matrix 226R (VPR226R) PC Desktop
Dear Sir, I have a Problem In Matrix 605T Home theater Audio Input selection is not working and we misplace Manual. Please send message for guide line at vinupatel1953@gmail.com
I have the btt350 home theater system connected by a hdmi cable from blu ray player connected to a panasonic 50" plasma 3d tv when playing a disc or listening to the radio from the blu ray player the...
Page 22 in the Manual details the required input to be selected dependent on the connection type.
To enjoy sound from the TV (Page 29)
AUX*1: When using an Audio cable
ARC*1: When using an HDMI cable
(Available when using an ARC
compatible TV)
DIGITAL IN*1: When using an Optical
digital audio cable
And from Page 29
Turn on your TV and select the appropriate audio input mode
[AUX, ARC, D-IN] to suit the connections to this unit. (Page 22)
Page 30 details how to set the audio link.
Setting the audio link with the TV
With the remote control;
Select the actual TV audio connection on the main unit.
1 Press [START] and press [3, 4] to select "Other
Functions" and press [OK].
2 Press [3, 4] to select "Setup" and press [OK].
3 Press [3, 4] to select "TV / Device Connection" and press
[OK].
4 Press [3, 4] to select "TV Audio Input".
5 Press [2, 1] to switch "AUX","ARC" or "DIGITAL IN".
Select "AUX" or "ARC"*1 in "TV Audio Input" when the
DIGITAL AUDIO IN terminal is used for the STB
connection.
Whenever the connection or settings are changed, reconfirm
the points above.
Please leave feedback
Cheers
Andy
Apr 26, 2011 | Panasonic SCBTT350 Theater System
Tip
Kramer VS4x4ycyl Manual Download
Download Kramer VS4x4ycyl Video Audio Matrix Switcher Manual
Have you misplaced your Kramer VS4x4ycyl Video Audio Matrix Switcher Owners Manual?
Would you like a digital, searchable, pdf version of the VS4x4ycyl Video Audio Matrix Switcher User Guide?
Follow this link (& click FREE) to download a pdf version of the VS4x4ycyl Video Audio Matrix Switcher installation instructions.
I hope that helps.
_______________________________________________
on May 09, 2010 | Audio Players & Recorders
I purchase a Panasonic Blu-Ray Home Theatre SC-BT330PCK with the intent of using it as a surround sound system for my TV and having a Blu-Ray as a bonus. Is it possible to have them work independently?
Hello there,
Yes it is possible and relatively simple to do. I suspect you have only connected an HDMI cable from the Home Theater system (HT) to the TV. This cable only sends audio and video to the TV from the HT system - it can't be used to receive the audio from the TV back to the HT.
To get audio from the TV channels through the HT speakers, you will need to connect a separate audio cable from the AUDIO OUT sockets on the TV to the HT. This can be either a Digital Optical cable (connects to socket ringed in green) or an RCA type stereo audio cable (connects to AUX sockets ringed in red).
If you are using a cable or satellite receiver, you should connect the receiver directly to the HT rather than the TV. You would also need to select the correct INPUT on the HT when you want to use the speakers for the TV channels. This will be DIGITAL 1 if using the digital optical cable or AUX if using the RCA stereo audio cable.
The audio connections are explained on page 16 of your user manual and input selection is explained on page 23. If you don't have a manual, please let me know and I can supply one.
I can draw you a diagram showing how to connect your TV to the HT and provide step-by-step instructions for setting it up, but you will need to let me know the brand and model number of your TV. If you are using a cable or satellite receiver, please let me know the brand and model number of this receiver as well.
Hope this helps.
Regards,
BElectric
Mar 22, 2011 | Panasonic SC-BT200 Home Theater Systems....
I have an RCA home theatre...model rt2910. I have hooked my PS3 via HDMI to the TV for the video and used an optical cable for the audio. I set the PS3 to send video via HDMI and audio via optical cable....
You should have the HDMI plugged into the Home theater unit. The theater unit then is attached to the TV using the HDMI out.
The home theater unit passes the HDMI through to the TV while playing the audio for you.
You will likely need to select the correct source on your RT2910.
Here is a link to the manual.
http://www.1800customersupport.com/productdocuments/RT2910_RCA.pdf
See the section entitled "Connecting to HDMI Components" for an illustration of what I have described above.
Feb 28, 2011 | RCA RT2910 Theater System
I hooked up the Panasonic sa-ht800V Home Theater Audio System SA-HT800V to an old tv the only hook up is the coaxial cable i turned TV to channel 3 and i get picture from the dvd is the a setting a need to...
Look at Page 12 if your TV only has RF coaxial antenna input...
http://www.retrevo.com/support/Panasonic-SA-HT800-Home-Theater-Systems-manual/id/312bh741/t/2/
Add in the Video cable (included) if the TV has an input for it and you'll be able to manage the SA-HT800 through the TV.
Make all the other necessary selections prescribed in the manual.
Jan 23, 2011 | Panasonic sa-ht800V Home Theater Audio...
Samsung ht-c550 dolby pro logic II mode does not work.
1. Go to the DVD input.
2. Select menu
3. Settings
4. Audio
5. ASC
6. Turn OFF the Auto Sound Calibration
7. Exit the menu
8. Go to the DVD input and retry the pro logic II button and switch to MATRIX.
(Also you have to enable the "matrix" setting each time on all of the inputs you use.)
Jul 07, 2010 | Samsung HTC550 Theater System
Compatibility fo TV and Sound system
TV has audio outputs, the RCA cable type. If you connect the audio output (red,white) from the TV(look on the back), and connect the RCA cable to Input of home theater system,you should get TV sound from home theater system. You may have to set the audio on the TV for external source. Go to menu, to audio setup, to options. On the Home Theater system, you may have to select the audio source, i.e. audio input 1, etc.
Aug 09, 2009 | Samsung Theater System
No surround sound through tv
May be you have to set the Pro-logic option soundfield, this will matrix a 5.1 surround sound effect, unless of course you are sending a Dolby Digital 5.1 audio signal from your TV broadcast into the Home theatre system, also have to check the TV audio output to send audio output to a Home theatre system in other than 2 channel stereo.
Feb 09, 2009 | Insignia NS-H2002 Theater System
No Audio Out through the Optical OUT jack
just press the DVD button on the remote contol and you will be ok.. :)
Jun 16, 2008 | LG LHT734 System
Does not play multichannel audio (5.1) input through optical digital audio
Hi try this.
in the dvd player make sure you just leave it default (bitstream) but in the home theater receiver don't select 5.1 b/c that will only give you a virtual 5.1 not a true 5.1. In fact don't select any sound field at all just select dolby digital or dts depending on the source of the movie then you should be ok.
The only other problem i can see is that hdmi sends both the sound and picture to the tv. You will need to see if there's a function on the dvd player to only send the picture via hdmi and the sound via the optical out of the dvd player.
good luck
smeags.
Jan 06, 2008 | Panasonic SC-HT920 System
Matrix 226R (VPR226R) PC Desktop Logo
Top Matrix Computers & Internet Experts
David Payne
David Payne
Are you a Matrix Computer and Internet Expert? Answer questions, earn points and help others
