Question about Apex Digital Televison & Video
The volume on my Apex Digital flat screen tv stopped working suddenly. I have unplugged the powercord to try and reset the tv, I have unplugged all the cable from the cable box to the tv and I have reset the cable box itself. The picture is fine but I have no volume at all. I purchased the tv in 2006 (I believe) from Circut City in Irvine VA
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please check the audio with a DVD player. Also try using component cables if using a RCA component cable or vice versa. Check that all of the cables are plugged into the back of the TV & MUTE button is not pressed. Do a hard reset by unplugging the power cord for more than 4 hours and power it again, then go into the on-screen-menu and make sure the sap is off and stereo in on. Also try audio from Phone and 3.5mm jacks (if equipped). If this all didn't resolves the issue then it is an Audio IC or bad speakers/speaker connection. Please do accept the solution if the issue is resolved else post a comment for further assistance.
Thanks
Rylee
Posted on Jul 03, 2010
Apex apex tv
Just unplug the TV from AC mains wall socket, and re-plug it back after 10 minutes or so. This must make it a hard reset. If you wish to get more details, check the site linked here.
Nov 27, 2013 | Apex Digital AT2002S 20" TV
I have an Apex LD3249 LCD TV that the volume go up to 100 on it's own and won't go down, any suggestions on what could be wrong or how to fix it?
The digital volume control section circuit has the fault. You have to check its main digital board. Might need replacement.
Nov 27, 2012 | Apex Digital LD3249 LCD TV
Apex ld1919 power light just blinks instead of going on
Tries tv unplug,replug it back like about an hour later,for the tv to do a whole resetting itself back to the tv factory setting.The tv now should be working again.If the tv dosen't and the tv still having the same problems.Mean ur tv power supply board it is the causes and the problems.That the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Sep 28, 2011 | Apex Digital LD1919 19 in. LCD TV
I have a question regarding my Apex television set that I just purchased 4 months ago. The screen does not come on, there is only volume. I was advised that this TV is under warranty. Who do I need to...
Tries the place where u bought tv itself,tries get ur warrenty replacement from them for a replacement of a different tv.U look inside tv owner manual for 1-800... call Apex Corporation itself talk to their custumer service department find the close it repair center they have a contract with to do their repair work with.U come to them or make appoint they come to u.
Sep 01, 2011 | Apex Digital LD4088 LCD TV
I have an apex flat screen TV and I use direct TV as my cable provider. I was watching TV and walked out of the room and when I came back the TV said to run the channel auto scan in the TV menu...I did...
unplug the tv and the direct cable box reset the box by plugging both the tv and box back in. MAKE SURE the tv is set on the right input for the box first. if the tv said to do auto scan then you lost the connection from the box either by changing the input that box is connected to if by a cable its usually 3 or 4. if by hdmi or rca cables its an input channel. also make sure not cables are loose try that first before unplugging the tv let me know
Mar 13, 2011 | Apex Digital Televison & Video
I bought a apex tv from someone and they didn't have the remote and there is a parental control block on the cartoon channels how can i remove this if i dont no the pass code?
Try code 0000 or 1234 to reset it.
Otherwise try leaving the set unplugged overnight to see if the internal memory will reset.
Good luck and comment back if this was helpful.
Feb 03, 2011 | Apex Digital Televison & Video
Service menu
The volume on my tv just stopped working.
Apr 15, 2009 | Apex Digital GB51HD09 51" Rear Projection...
TV won't come on
unplug it for 10 minutes then turn it on at the console(not the remore) and hold the power button in for 15 seconds. this resets most apex tv's
Oct 06, 2008 | Apex Digital GB55HD09W 55" Rear Projection...
Apex LD-1919
I fixed the problem by taking the batteries out of the remote and unplugging the tv for 30 minutes. At the end of 30 minutes I replaced the batteries then pushed each button on the remote in order. I then plugged the tv back in and everything worked again.
Weird.
Aug 01, 2008 | Apex Digital AT2002S 20" TV
Televison & Video Logo
60 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
