Question about Gigabyte GA-8I915P Duo Pro Motherboard
I switch on my system and nothing happens The cpu
I switch on my system and nothing happens The cpu fan works power light and hdd lights come up but there is no video signal output
I am running xp with to sata drives
  • Gigabyte Master
  • 11,800 Answers
So practically the pc starts but you don't have any image. Try using another monitor and another video card - one of them is dead.
Posted on Jul 03, 2010
  • 1 Broke Girl
    1 Broke Girl Apr 24, 2012
    Yea right, that's the easy answer, I found a little spring switch on the bottom of the unit when I opened it, it dropped off from somewhere, but where?
Everything was working fine, then one day I switch...
Try to check your CPU unit it maybe have a power when you turn it on. Or just check their power suppy at the back when it works. If you check that all and it works normal just check inside your computer and try to see the Power LED (Light Emiting Diode) of the motherboard if have a light. Because if it is have a light your motherboard is good and if it is no light in the Power LED of the motherboard that was damage. But if your motherboard does not have installed Power LED try to check the CPU Fan it maybe works properly it because the CPU Fan was conncected in the motherboard if did not works the motherboard is also damage and need to replace. But if the CPU Fan was working properly, try to hold the CPU Heatsink if it is very hot the damage is your micro processor.
May 20, 2010 | Intel D945GCNL Motherboard
Fans work green light shows on motherboard but cpu wont power up
Any HDD light on / if not could be failed HDD OR faulty IDE / Sata cable.
Did you get posting beep if not remove / replace ram / reboot.
If you did then either mobo / CPU may be faulty.
May 10, 2010 | Intel D845GVSR Motherboard
Hi. my CPU (system) does not start. When i press the power button, the light turns on for a second then nothing happens.
Does the power supply fan spin when you switch it on ??
Do you hear a"posting" beep??
Does the CPU fan start to spin??
If no to all of these probably dud mobo.
Dec 21, 2009 | Intel CPU
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
DG31PR Won't Boot
you ight have a BAD CPU, try checking it out on another pc or friends pc.
Jan 08, 2009 | Intel DG31PR Motherboard
Not booting
remove battery and try again (on mains). If it works then battery may be too far gone!
Aug 03, 2008 | Acer Computers & Internet
Abit av8
Ensure that you got the cpu fan connected to the correct place, the board has 2 one for the cpu fan andt the other for a system controlled case fan.
If that dont work check to see you got the power supply connected to the board propperly, there is a seperate 4 pin connector using 2 yellow and 2 black wires ensure it is correct.
Check your power supply
unplug the power supply and bridge the green wire with the black one next to it to see if it comes on. OR JUST CHANGE THE POWER SUPPLY TO SEE IF IT WORKS.
YOUR PROBLEM IS A POWER PROBLEM EIGHTER FROM A BAD CONNECTION OR A WRONG HOOK UP AND IF NOT THAT A BAD POWER SUPPLY
Jan 03, 2008 | Abit AV8 VIA K8T800 Pro Socket 939 DDR 400...
Serious problems with an Asus M2N E SLI motherboard.
try the board with out memory and hard drive.
Do fans run?
Anything?
Nov 21, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
A7V8X NOTHING HAPPENING,
When a power supply goes out the way yours did, it's going to fry the MB 99% of the time. So you're going to need a new MB. It's possible that you CPU is ok, but that could also go too. I would replace the MB first, then the CPU if that doesn't work.
Nov 07, 2007 | ASUS A7V8X Motherboard
My laptop powers on but won't boot, fans start and nothing happens?
I just had same problem with 2 laptops. Power light came on and fan ran a few secs but nothing else. I replaced motherboard and CPU in one. The other just had to reseat CPU and it works like a charm. I thought it was AC adapter or LCD but it just had to be reseated. I would try that before I bought anything.
Oct 29, 2007 | Compaq Presario V5102NR Notebook
Gigabyte GA-8I915P Duo Pro Motherboard Logo
159 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
