Question about NAD S200 2-Channel Amplifier
How to add a remote 12V trigger to turn on the NAD S200 Amplifier? Thanks
  • JAABGA Jul 03, 2010
    There's nothing related to my question on this link
  • JAABGA Jul 04, 2010
    I want to have the remote 12V trigger inside the Amplifier, like on the S250
  • 3,083 Answers
Here is a blog of people discussing that. There is some interesting info that might help you. Sorry, I've never done this or would tell you a simple way, although these solutions seems easy enough:
http://www.avsforum.com/avs-vb/showthread.php?t=1053542
Here's some similar info:
http://www.hometheatershack.com/forums/system-setup-connection/1711-stupid-question-s-regarding-12v-trigger.html
Looks like the 12V adapter into a switched outlet is the easiest way, but there are other options.
Hope this helps, and good luck!
Posted on Jul 04, 2010
  • 2,069 Answers
I hope i got your issue well. the option I can give you is to use a 12v wall wart or power supply plugged into the switched outlet on your amp. it should do the trick.
Regards
Posted on Jul 03, 2010
    President:
  • 1,561 Answers
I advice you see the information on the below link,
http://www.6moons.com/audioreviews/stello/stello.html
Type the above link on your web browser to see information therein.
Take care.
    There's nothing on that link related to my question...
Recently my sub has stopped woking due to not having enough power i have checked all the fuses and tested the amount of volts running through and found that when the head unit was on the power was...
The remote cable only brings a low current 12v trigger supply to turn on the amplifier,because it is remotely mounted with out any on / off switch or its own . Use heavy cables for the Power + and power - of the sub woofer. And make sure the + red wire of the Sub module is directly connected to the battery terminals of the car and the - black wire is bolted well to the body of the car ( make sure the nut is not painted or insulated ).
Mar 14, 2011 | Car Audio & Video
Does the rmt hook up to ground or power
Hi the RMT is short for remote and is connected to a 12v feed taken from the remote output from the cd player, it provides the 12v needed to turn the amplifier on when required & turns it off when the player is turned off. Do not connect this to a permanent 12v feed as the amp. will be on all the time & you will have a flat battery every morning! Cheers, acbva.
Nov 16, 2009 | Jensen LXA400 Car Audio Amplifier
Every time i turn on power it snap the reset breaker. and won't power up.
unplug everything but the 12v power/remote power and ground. turn on and see if it triggers the safety. if it does you have a short in the amp. if it turns on and stays on, plug one cable in at a time to see whats making it trip.
Sep 24, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Does not turn off and drains the battery
do u have the amp hooked to a switched terminal of the igntion switch?
Jul 22, 2009 | Insignia 600W Bridgeable Amplifier with...
Can not get power to my pyle amplifier
Usually On Car Amplifiers, there is a Connector/Wire called "Remote On".
This is where Headunit supplies 12V to trigger the Power on the Amplifier.
(Of course, head unit usually has Remote Wire also in order to turn the Amplifier on).
If this wire is properly connected and still does not turn on, then try to supply 12V directly from the battery. If it turns on then your head unit has problem, If it does not turn on then your Amplifier has problem.
Jan 27, 2009 | Pyle Audio Players & Recorders
Nad c350 no power at all
check your output stage for bad speakers cable or bare wire of cable touch the body of amp----short circuit speaker cable----bad speaker it self------ bad input cable or defective input device .
disconnect all and check if it is ok---start to connect one by one from input to outputs------if all above failed you must contact service center for help.
Aug 22, 2008 | NAD C320 2-Channel Amplifier
KD-G801
Your radio should have a blue wire with white stripe on it - this is the 12v remote turn on lead. You didn't leave the amplifier model in your post, but most any aftermarket amplifier will have only 3 power connections. One is 12v constant (battery), one is 12v negative (chassis ground), and the third should be a 12v triggered lead (either from a head unit or from ignition). If you are having trouble with this, I would recommend checking with a local stereo shop as they can assist you.
Aug 08, 2008 | Car Audio & Video
Nad s200
It is most probably a dirty speaker protection relay. gently tap the relay(the one that engages shortly after turning the amp on) when the fault is occurring and see audio returns. This should ascertain the problem. Replace it if it is a sealed type, or if it has a "lid" you can get off, burnish the contacts with a white business card, and give it a spray with contact cleaner/lubricant. Good luck and a "fixYa" rating would be great for my profile :)
Feb 06, 2008 | NAD C370 2-Channel Amplifier
Unable to connect to amplifier
Hi, Your post "Is there any way I can connect it to an amplifier?" yes, but that would require that you open your unit and attach a pair of shielded wire to the inputs of the built-in amplifier. Left, right and 2 X ground. The other end of the shielded wire can be terminated with a pair of RCA females. The "blue" slot can be replaced by a manually operated remote on/off switch. This however will void your warranty, probably it might be to your advantage to return the unit for a replacement model that has line outs. Good luck and kind regards. Post back should you need further information.
Aug 22, 2007 | Sony CDX-GT210 CD Player
NAD S200 2-Channel Amplifier Logo
87 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
