Question about Intel Pentium 4 , 2.8 GHz (SL77ND)
Regedit I'm having a problem with windows xp. The reedit is not working and I have been told the the only way to fix this is to back everything up on my computor and reinstall everything. Is here a way around this?
    Champion:
  • 207 Answers
You can refresh current installation without deleting old one although I'd back up important files even for that operation too, just in case.
Posted on Apr 17, 2008
AutoPlay - Windows XP
Autorun is a feature of Windows XP that brings up a screen with actions that the user can perform any time a storage device or piece of media is inserted into a computer. This feature can be disabled by changing a value in the system registry. If the Autorun feature is not working on your Windows XP system, fix the computer so that the Autorun options will be displayed when a USB device is connected.
Select the "Start" button and choose "Run." Type "regedit" (no quotation marks) and click "OK." Click on the key "HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer\NoDriveTypeAutorun" in the left side of the window. Right-click on the value "NoDriveTypeAutoRun" in the right side of the window. Select "Modify" from the menu. Enter "91" into the "Value data" box. Select "Hexadecimal" as the type. Click "OK" to enable Autorun on all types of drives, including USB devices. Close the registry editor and reboot the computer. Hope this helps.
Jan 10, 2013 | Computers & Internet
Drive is unable 2 read any disc
Hi, try going into control panel then look for device manager, once in Device manager it will show you all the devices that your system has in it, look for your CD/DVD-ROM/RW, right click on it try disabling and enabling it by right clicking on the device disable and enable the Optical Drive, then restart you computer.
Also if the above does not work try Doing this in the regedit
1. Click Start
2.if you have vista or win7 just type redgit on the space where you can type in on the start menu, if you have XP on you computer, click Run after clicking start then type in regedit then click OK or press enter
3. on the regedit Screen
4.select HKEY Local Machine
5.click SYSTEMS
6.Click Current ControlSet
7.Click Control
8.Click Class, You will see a long list of Items look for {4D36E965-E325-11CE-BFC1-08002BE10318} > this will be you DVD/CD-Rom
9.click the abovce CD/DVD-rom
10. on the right side will be a list of items look for upperfilter or Lowerfilters right click on both if both is present or one of them then click on delete then yes to delete the filters
11. Lastly restart your computer this may fix your concern.
but this fix is not 100% for a read issue you can also try reinstalling the operating system "Windows" on your system this will renew everything in your computer but NOTE that you will needto back up any data you have important on your computer this will reformat everything back to scratch.
Jul 07, 2010 | Lenovo 3000 Y410 Laptop
Cannot unstall game
use the #Run command
regedit
hkey_current_user
hkey_local_machine
go to software in both these folders and delete the black hawk down folders
got to program files and delete the blackhawk down folder.
thats how to manually uninstall.
be carefull wat you do with reedit. you could end up with a blue screen of death if you delete things you shouldnt.
Dec 28, 2009 | NovaLogic Delta Force: Black Hawk Down...
Windowx xp booting time no icons appear.
Changing the default shell (all users):
1) open regedit (start menu > run, and type in regedit)
2) go to: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon.
3) Change Shell from explorer.exe to the new shell path e.g C:\Litestep\litestep.exe
4) log out and log back in.
Changing the default shell (only current user):
1) open regedit (start menu > run, and type in regedit).
2) go to: HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Winlogon.
3) add a new string value (Edit > New > String Value) called shell. and set the value to the path of the new shell e.g C:\Litestep\litestep.exe.
http://support.microsoft.com/kb/228309
May 09, 2009 | Computers & Internet
Regedit
Admin734's Solution would work but mine may be quicker.
Put your windows cd in the drive and search it for regedit.exe, it should be in the d:\I386 folder. Once found copy and paste it to your C:\windows\system32 folder.
problem should be solved.
Oct 03, 2008 | Microsoft Windows XP Professional With...
Error 1719
Error 1719 occurs when the msiexec.exe program becomes disassociated with .msi files. Under Windows XP x32 this is usually fixed with rebooting into safe mode, renaming the msiexec and DLL's and letting Windows File Protection reinstall them. This doesn't always work in x64.
Error 1719 occurs in x64 when the 32-bit version of msiexec is registered as the msiserver. Here's the fix:
  1. Open regedit ( Start -> Run -> regedit.exe -> OK)
  2. Go to the following key: My computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\MSIServer
  3. Look at the ImagePath entry. For Windows XP x64 it should read:
CODE - C:\WINDOWS\SysWOW64\msiexec.exe /V
If it doesn't edit the registry to match that.
4. Restart the Windows Installer service from the Admin Control Panel -> Services CP
OR
Click on the below link or copy the URL and paste it in your web browser.. Follow the steps....
http://support.microsoft.com/kb/315346
Thank you......
Oct 01, 2008 | HP Computers & Internet
Direct X Registry File Missing
Hi RB - What operating system are you running please?
May 01, 2008 | Microsoft Windows Xp Home Edition English...
Windows xp pro windows explorer not showing any drives
do u know regestry?
follow my instruction go run give command regedit
then
[HKEY_current_user\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer]
"NoDrives"=dword:3ffffff
else write in notepad save as ..reg execute it.
for more help call me +919441133420
ur's kishore chowdary.
Apr 04, 2008 | Microsoft Windows XP Professional With...
Omg HELP system back up
If she did a system recovery, then your hard drive was formatted, right? Everything is gone unfortunately.
Jan 29, 2008 | Microsoft Windows XP Home Edition
Computers & Internet Logo
35 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
