Question about Dell 3300 Print Server
Recently got two new laptops and have a existing Dell 3 in 1 photo printer all wireless. Loaded the printer software on the laptops I can print using the usb cable but it will not print wireless not sure what I need to do.
  • 52 Answers
Make sure that both your computer and printer are both on the same network. after connect them you are most likely going to have to add the printer to the laptops. go into your control panel where it says hardware and sound and click on printer. there will be an option to add printer up at the top, click that and a new window will open up, click on the add wireless or bluetooth printer and follow the steps.
Posted on Jul 30, 2010
I am trying to hook a Brother HL-2140 laser printer to a dell computer. I am unable to print since I've recently hook up the new computer. I hooked everything up like how it was on the old...
Re boot the computer with ,( wired or wireless printer?), the printer cable in the USB port in the laptop/desktop, the windows version you have will ID the device and try to load a driver, or Go to printer in the start menu and ADD a PRINTER the software will search for the attached printer. OR use the software that came with the printer, load into the Dell and follow the instructions.
Nov 10, 2012 | Brother HL 2140 Laser Printer
When I try to print the page comes out blank. My ink levels are at more than half
Hi, 1st check whether your ink cartridge includes ink or not.( this can b checked within the software came out with your printer; the ink level) and some times not all softwares have these feature. Another way to check is print a test paper and check the the visibility of the font or pic if exist. 2nd try to update printer''s drivers to the latest. Or re-install software+drivers again. 3rd May be you bought the cartridge along time ago or recently but you didnt print frequently or use it ; to avoid letting the ink dries , after all these trials you get new one, and I have another solution which I do not recommend and you can try on your own responsibility, ( uninstall the ink cartridge and put half of the cartridge(don't put it all) 10 minutes in hot water ,of course not boiling one, this may let the dried ink to melt again and you would be lucky if it worked. Again you should try to buy a new ones if the 3 ways I mentioned didn't work with you. And if they are expensive, I recommend buying a new printer because their price seems close to a new ink cartridge(black+color) in some countries. good Luck.
May 15, 2012 | Dell Photo 964 All-In-One InkJet Printer
Cannot print from laptop to printer using wireless print server
This is probably the Software Firewall on your laptop
you should probably tell your firewall software that you have an internal network (Laptop-desktop-printer) you should add the IP range of the wireless network as a trusted network.
May 25, 2009 | Lexmark X3550 ALL-IN-ONE InkJet Printer
I have had spooler problems and lost the HP Solutions Center.
I had many simular issues with my laptop, then it shut off one day and wouldn't come bacl on, after digging through tons of support forums on HP's support page I found that a know bios issue exists for this model laptop. As long as its still running down load the latest bios and flash the laptop. Let me know if this helps
Mar 05, 2009 | HP Pavilion dv6000z Notebook
Dell 3300 Printer Adapter and Vista
Vista is tricky when adding networked printers.
Add printer by using a local device, not a networked device.  Assume the printer is connected locally to the machine.
Feb 01, 2009 | Dell Inspiron E1705 Notebook
I'm not sure exactly what you have tried yet, but maybe type in Services in the Vista search box and open Services. Scroll down to Print Spooler and right click on it. Restart the Spooler Service.
Also, many people have had scanning problems when using all-in-one software in Vista. I usually recommend this:
The all in one solution software you used in XP doesn't work fully with Vista.
But you can still scan and copy by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (eg HP C3180) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Hope that helps.
Chris (ziraffa)
Jan 13, 2009 | HP C7200-69016 Network Adapter
C++ Runtime Error for Dell Photo AIO 962 printer dlbxmon.exe
I had the same problem and was able to fix it by following the instructions in this link:
http://forums.cnet.com/5208-7590_102-0.html?forumID=67&threadID=300180
Apparently, the regular uninstall procedure does not completely uninstall the software drivers. Then, if new drivers or software are installed, a conflict is created between the old drivers and the new drivers. You have to first run the DellXPCleanUpUtility to completely clean out the old software drivers. Then, you can install the new drivers successfully.
Jan 02, 2009 | Dell 962 Photo All-In-One InkJet Printer
DELL a920 (WITH VISTA)
**UNISTALL ANY DRIVERS YOU HAVE INSTALLED FOR THE A920
YOU WANT A CLEAN INSTALL
Go to Control Panel -- find your printer and uninstall
or
Uninstall the Existing Dell All-In-One Printer Drivers
  1. Click Start, point to Programs, point to Dell, then click Dell Printer Software Uninstall.
  2. Select the components to uninstall, and then click Next.
  3. Click Uninstall Now to proceed with the uninstallation of the printer drivers.
  4. Click OK after the uninstallation has been completed.
BEFORE YOU GO TO ANY DIRECTIONS BELOW---
IF YOU ARE RUNNING VISTA GO TO www.dell.com
At the top right side Search box type in the Journal Number
Journal ID: 08088J5HPH Article ID: 317175 Date Published: 2/19/2008 Last Revised: 3/17/2008
This will take you to a Page Printer Driver Communication Errors in Microsfot Windows Vista
Follow the instructions on the this page.
Printer Drivers for Vista are different than XP
For Vista you need Driver R153716.exe
and then you have a Patch R166244.zip
First you install the driver
then the patch
Specs for your computer
http://support.dell.com/support/edocs/systems/ins1501/multlang/dao_emea1/TM686am2MR.pdf
This is a wired printer, not a wireless printer, so it must be connected to the laptop.
  • There are up to three ways to set up your printer. You will need one of these three cables: USB, RJ-45, or parallel.
Next step
The cable you use connects to the computer
Next step
  • Turn your PC on, if it isn’t already.
  • Connect the cable you are using to the back of your computer or server here.
  • Next step
    • If the "Found New Hardware" wizard pops up on your screen, close it.
    Next step
    • Make sure paper is in the paper feed tray and the paper extender at the top is fully extended.
    Next step
    • Insert the software CD that came with your printer.
    Next step
    • The software should auto-run on your computer. If not, choose My Computer and navigate to the optical drive to start the software yourself.
    • Follow the instructions in the software and click OK and Next when prompted.
    Next step
    • Print a test page to see how your printer is doing.
    Now please read this:
    After everything above is done, MAKE SURE THE PRINTER IS ON!!!
    If you are running XP or Vista
    Click Start
    Right click Computer
    Click Properties
    Click Device Manager
    In the Device Manager make sure you do not see any yellow ! points
    Now in the Device Manager
    click on Imaging Devices---do you see your printer; IT SHOULD SHOW THE PRINTER NAME
    Now click the Portable Devices
    Do you see the printer ---- IT SHOULD SHOW THE PRINTER NAME
    THIS MEANS THE DRIVERS LOADED ---NOW CLOSE THE DEVICE MANAGER
    For all intense and purposes, if you loaded the right drivers, the printer should run fine.
    One other thing you can do is run Windows updates to see if it sends you any updates for your printer----
    In XP click custom
    In Vista it will automatically show you all the updates
    Any more questions, contact me.
    Please rate this advice. Thanks so much!
    Mar 20, 2008 | Dell A920 InkJet Printer
    Trying to set up a network printer with DELL TRUEMIBILE 2350...please help
    using windows xp on all the computers, when you connect to the printer windows should automatically install drivers.
    1. Goto My Computer, Click My Network Places (Explorer Bar).
    2. Click View Workgroup Computers (Explorer Bar)
    3. Find the computer that has the printer physically connected to it, open it
    4. Find the printer and right click it!
    5 Select Connect... and wait for the drivers to install.
    this should install the print drivers and install the printer on your computer. the printer should now be available in print dialogs i.e. word etc etc and from the Control Panel > Printers window.
    Nov 03, 2007 | Dell Wireless 2350 Router
    Dell 3300 Print Server Logo
    mukhtar21 shaikh
    mukhtar21 shaikh
