Question about Alpine CDA-9883 CD Player
No sound in the Front & Right left Speakers of my 92 525i
After i replace the original radio of my 525i for a Sony CD Player, my new radio has power but no sound so i plug the blue/withe wire from the new harness adapter to a blue wire form the radio plug and the sound come but just on the right speakers; "before to plug the blue wires by mistake i touch the blue/withe wire whit a speaker wire"............. some body can tell me if this mistake is the reason for the no sound in the right speakers????? and also what's the solution????????
Um could b u did it right but u need ta check ur radio click dat big button in middle n go thru them play wit it n even out ur sounds could b its set to only one side
Posted on Sep 19, 2009
I installed a new Sony CD player in my 1996 Toyota Forerunner and the speakers won't work. The player has power but there is no sound. I did not use a wiring harness but I did have the wiring diagram for...
Be sure that the wires are connected correctly. If no sound comes out could be speakers are bad, but highly unlikely that all four would be. Could be the stereo amplifier is out. You could try using an amplifier to connect the speakers. One other option run new wire to each speaker to make sure wiring is still good. Constant 12V+ Blue/Yellow or Blue/Black Switched 12V+ Gray Ground Brown Illumination Green Dimmer n/a Antenna Trigger Black/Red Antenna Right Front Front Speakers 6 1/2" Doors Left Front (+) Pink Left Front (-) Purple Right Front (+) Light Green Right Front (-) Blue Rear Speakers 5 1/4" Rear Doors Left Rear (+) Black Left Rear (-) Yellow Right Rear (+) Red Right Rear (-) White
Feb 14, 2011 | Car Audio & Video
Need a wiring diagram for a 99 hyundai accent tape deck
1999 Hyundai Accent Car Stereo Radio Wiring Diagram Car Radio Constant 12V+ Wire: Red/Yellow Car Radio Ignition Switched 12V+ Wire: Blue/White Car Radio Ground Wire: Black Car Stereo Illumination Wire: N/A Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger Wire: N/A Car Stereo Amplifier Trigger Wire: N/A Front Speakers Size: 5 1/4′ Front Speakers Location: Doors Left Front Speaker Wire (+): White/Red Left Front Speaker Wire (-): Black/Red Right Front Speaker Wire (+): White/Blue Right Front Speaker Wire (-): Black/Blue Rear Speakers Size: 6 1/2′ Rear Speakers Location: Rear Deck Left Rear Speaker Wire (+): White/Red Left Rear Speaker Wire (-): Black/Red Right Rear Speaker Wire (+): White/Blue Right Rear Speaker Wire (-): Black/Blue
Jan 02, 2010 | 1999 Hyundai Accent
I just hook up an after market cd player up in my 2001 chrysler 300m and the radio play but the cd player want play, it turns on and everything just no sound. do anyone have any ideas of what i did wrong?
DOES THE RADIO PLAY? HERE ARE THE FACTORY WIRING COLORS FOR THE RADIO HARNESS, RECHECK YOUR WORK. IF U FIND NOTHING THEN IF THE RADIO PLAYS THE CD PLAYER IS DEFECTIVE, IT HAPPENS BELIEVE ME.
2001 Chrysler 300M Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis or Strap
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange
Car Stereo Antenna Trigger Wire: Orange/Red
Car Stereo Cell Phone Mute Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: Located under the rear deck in the trunk.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Nov 05, 2009 | 2000 Chrysler 300M
New Radio too powerful for 15 Watt speakers?
Hello mike_mccuske,
The OEM speakers will still work OK with your new Pioneer. Just don't turn it up too loud. Of course you'll get improved sound if you replace the speakers. Your Pioneer's RMS power is 14 watts, and the peak (maximum) power is 50 watts. The door speakers in a 2000 Honda Civic are 6.5" and you can get a set of Pioneer speakers, the TS-G1642R's, from Crutchfield for less than $50. Their RMS power range is 2-30 watts and they can handle a peak power of up to 180 watts.
Hope this helps.
May 22, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
I Need the Wiring guide
1992 Saturn SL2 Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Orange
Car Radio Ignition Switched 12V+ Wire: Yellow
Car Stereo Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Front Speakers Size: 6 1/2′
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
May 21, 2009 | 1992 Saturn SL2
I need to hook up cd player
something i found today on google. hope it helps.
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Illumination Wire: Blue/Red
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
May 09, 2009 | Sony CDX-CA400 CD Player
Need to know how to hook up a sony cd player
see if this helps bro.
May 09, 2009 | Sony ATRAC MPS/CD/AM/FM Personal CD Player
Diagram on what wires go were for 2003 chevy cavalier / gm radio interface to sony xplode cd player
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Illumination Wire: Gray
Car Stereo Amp Trigger Wire: Pink
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Negative Wire (-): Light Blue
Apr 29, 2009 | Car Audio & Video
Install new cd player please help
HERE U GO.
2002 Pontiac Grand Am Car Audio Wiring Diagram
Car Radio Ground Wire: Black/White
Car Stereo Amplifier Location: Mounted behind trim in the left side of the trunk.
Feb 05, 2009 | 2002 Pontiac Grand Am
Install a cd player
HERE YOU GO ALL WIRES U NEED PLEASE RATE ME GOOD LUCK WILL WORK GOOD!!!!!!!!
2003 Ford Focus Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Orange/Black (Thick Wire)
Radio Switched 12V+ Wire: Yellow/Green
Radio Ground Wire: Black/Yellow and Black/Green
Radio Illumination Wire: Orange/Black (Thin Wire)
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: N/A
Radio Amp Trigger Wire: None
Left Front Speaker Wire (+): White/Black
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): White/Red
Right Front Speaker Wire (-): Gray/Red
Left Rear Speaker Wire (+): White/Purple
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (-): Gray
Aug 14, 2008 | 2003 Ford Focus
Alpine CDA-9883 CD Player Logo
74 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
