Question about Philips GoGear ViBE Digital Media Player
GoGear, water damaged, flashes when plugged into computer...?
My GoGear has been put through hell-- was washed by my folks with my jacket when I was sick. This was months ago. Now, months later, I've plugged it into the computer, and it does turn on, showing the welcome screen because it was reset. Only, this screen shows for just a second, then stops, and flashes every second or so to that screen and off.
So would anyone know what part would be the damaged one? My guess would be the battery doesn't hold a charge, but I can't be sure-- it hasn't given itself a chance to charge because of this. So maybe it's some kind of hard drive issue?
Not sure myself, so would anyone else by chance have an idea of the problem?
  • 476 Answers
SOURCE: philips mp3 player sa6045
This player shows the "Do not disconnect" message when it is doing something critical such as transferring tracks or updating firmware, which could corrupt the player if disconnected part way through.
The player shows the "OK to disconnect" when it is idle. As the message says, it's ok to disconnect, as the player will not corrupt if disconnected when it is idle.
These messages mean that the player does not need the "Safe to remove" procedure.
It is ok to disconnect part way through charging. Also the player will condition the battery once it is fully charged, so it's ok to leave it charging.
Occassionally batteries can "memorise" when constantly disconnect and reconnected without fully charging and discharging. To help prevent this, fully discharge the player (leave on until dead) and fully charge and condition (leave charging for about 12 hours) every couple of weeks or so.
Posted on Feb 12, 2008
SOURCE: Philips GoGear 2GB MP3/Video Player LOCKED ?
you have to look at the side and shift the lock button
Posted on Sep 21, 2008
  • 5 Answers
SOURCE: Philips GoGear just says "initializing"..
cd de intalacion
Posted on Nov 13, 2008
SOURCE: I have a GoGear device that won't charge
Hi, I had the same problem with my SA31xx, when I plugged it into my PC it made the normal usb sounds and then a flash symbol appeared over the battery on the screen. It would not charge at all, I replaced the usb cable and it now works perfectly. Hope this helps.
Posted on Mar 30, 2009
  • 484 Answers
SOURCE: 've had one of these
Try doing a soft reset.
Insert a small pin or unfolded paperclip into the reset hole located at the back of the player.
Hold until the player shuts down.
Power on the player again by using the Power on/off key.
Your songs and data will not be lost or corrupted by a soft reset.
If soft reset does not work, then you may have to use the Device Manager to recover your player.
How to do it is described on the manufacturer's web site:
I hope your player will work fine again.
Posted on May 04, 2011
How do you wash a j whistler jacket?
Usually most of the people can people give their jackets for dry clean because some times if we wash clothes from normal washing powder then your jacket will shrink, rough and loose its shine. It is better to wash your jacket with mild gel liquid which are used to wash the woolen cloth or you can give it to dry cleaner.
Carharrt Jackets Buy Pants Outerwear by Carharrt Here
Dec 24, 2014 | J. WHISTLER Down-filled Snorkel with Faux...
The Philips GoGear belonged to my mom, I was waiting for her to get a new iPod Nano so she could give her Philips GoGear to me. But my mom told me it didn't work anymore because she got it wet. I tried...
Hi brianrodr242...
If you ever find that you have to deal with a wet device, don't just abandon it.
Instead, try the following method to repair the water damage:
Take it apart as much as you can. Take out the battery, the memory card and whatever else can be easily disassembled. (Just make sure you can put it back together.)
Store the parts in an air-tight container covered with either dry rice, silica gel packets or kitty litter. These will absorb the moisture from your electronics device, leaving it water-free.
If no rice, gel packets or kitty litter are available, try using a vacuum to **** the water out.
DO NOT blow-dry the parts, it will only force the water farther in and cause more damage.
Please take time to rate me thumbs up.
Sep 18, 2011 | Philips GOGEAR SA6045 MP3 Player
I wish to wash my Marmot down jacket- what products should I use and what is the best way to wash it?
you can buy specific detergent for down based products to clean and retain the insulation properties of teh jacket. I use NikWax down wash which works really well for my mountain hardwear down jacket. Follow the instructions which are usually:
put washing machine on clear cycle to flush all residue detergent out of the machine, use 1-2 capfulls of down wash and wash on a low heat 30-40 degrees. Then either air dry or my preferred method is to put it in the dryer by itself on a low heat with some clean tennis balls in the dryer - hey presto lovelly and clean jacket ready to go out and get mucky again
Jul 10, 2011 | Marmot Mountain Down Jacket
The father in law assisted in putting in our DD605 Fisher and Paykel dishdrawers and inadvertantly hooked the cold water feed to the hot water supply.It ran through a rinse on both draws okay and then when...
Jun 15, 2011 | Dishwashers
How to put pictures from my computer to my philips go gear mp3 player
plug in the philips gogear go into pics choose the picture right click copy go back to my computer click on the philips drive and paste
Oct 18, 2010 | Philips GoGear Flash MP3 Player
Washing machine overfills and wont cycle to agitate
It is possible that the water level sensor is not working to switch off the inlet valve. So drain out and check the water level sensor, it is a pressure switch and can be checked if the diaphragm is damaged.
This sensore is fitted on the drum and works as the water fills, the water enters the jacket and pushes the switch on.
Hope this tip helps you.
Aug 22, 2010 | Roper Washing Machines
Where can you find from the engine block the water jackets of my 300m. It suspect that these waterjackets are already coroded causing water leaks. Is it advisable to put solution on the water reservoir the...
the water jackets are part of the casting of the engine block they surround the cylinders water jackets dont corrode away they clog or if they are leaking u have a cracked engine block if u are getting antifreeze into oil and steam out of exhaust more than likely its a head gasket-- because if u crack a water jacket that usually means a blown engine and need to replace or rebuild ---and the additive usually works for radiator leaks and some minor head gasket leaks
Mar 07, 2010 | 1999 Chrysler 300M
Buttons won't work
Take a small thin object such as a staple or paper clip and insert it into the reset hole on the left side. GENTLY push the staple in as far as it will go, hold a couple of seconds, and pull it out. Now plug the GoGear into your computer and press and hold the Play button until the unit turns on.
If this doesn't work, your unit is probably damaged and will need to be replaced or sent to Phillips for repair if under warranty.
Apr 23, 2009 | Philips SA3025/37 Flash MP3 Player
LG front load washer/ clothes still wet after final spin
The heavy jacket prevented the washer from spinning at a rapid pace, so I added a heavy bathrobe to absorb some of the water and to balance the load. The washer then spun very quickly and drained out all the water.
Jan 07, 2009 | LG WM-1832C Front Load Washer
Philips GoGear ViBE  Digital Media Player Logo
173 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
