When i turn on my machine it stops without taking water
  • 269 Answers
Can you supply me with the model and product number of the machine.
Thanks.
Posted on Jul 11, 2010
Do washing machine water pumps some how can get that hot from something being already wrong cause the water pump to melt down?
pump running without water will get hot enough to melt plastic .and that would suggest a plugged filter to me
Sep 30, 2015 | Washing Machines
I have a sunbeam EM 6910 I have just replaced the seal. When I power it on it goes through the warm up then the power light stays red and the machine starts pumping straight away.
I had this same problem. Turns out that tons of crawling insects had been living in my machine and caused an electrical fault. On my machine, this issue stops when the machine senses the water is empty, so you can try just removing the water level magnet from the tank. If you do, you still get the low water beeping and flashing red light. I sorted that by disconnecting the beeper and light from the main board but I had to open the machine right up for this, so that will take much more effort. Didn't really FIX the problem, but did circumvent without much loss of function (except the low water warning). See if that works.
Jun 13, 2015 | Sunbeam Cafe EM6910
I cannot take off the lid of the Pro chef and manual is unclear. How do I unlatch it?
Manual Pro Chef PU 100
I have received the hot water boiler, but it does not stop boiling the water. Instead of going to "Keep Warm", the machine continues to boil the water indefinitely. We left the boiler on and came back after 2 hours, and it didn't stop heating the water. Therefore, I refilled the boiled, turned off the machine, unplugged it, plugged it back in, and then turned it back on. The water continues to boil without going to "Keep Warm". I require a solution to the issue or a replacement as soon as possible.
Apr 25, 2014 | Le Chef Electric Shabbos Hot Water...
I would like to be able to adjust the flow of the water my nuova simonelli maxi machine. The water flows out of the machine in about 10 seconds and stops which is way to fast. Seems as though the...
Take the cup warmer off the top and find where the water line comes into the machine, follow this line to a tap that has a screw in knob. If you turn the know clockwise it will slow the flow of water to the hot water spigot.
Sep 06, 2010 | Nuova Simonelli Premier Maxi Espresso...
Water on rinse cycle comes in very slow, >1 hr
The rinse cycle is cold water only. Your filter screen on the cold side is stopped up with sediment. Turn off the water. Remove the cold supply hose from the rear of the washer. The screen is located inside the water fill valve. Take a straightened paper clip and fish the screen out. Clean it and replace it. Do not run the machine without the screen it will ruin the valve. Some hoses also have screens. Check your hoses too.
Sep 19, 2009 | Kenmore Washing Machines
Bosch SHU3300 dishwasher stuck on hot water intake (w/ no power)
It sounds like the fill vlave is stuck open. This can happen if your pressure is low or if the machine is old. I would start by replacing the vlave.
May 12, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Washing machine wont fill with water-hoover performance 1100
check that the water inlet pipe is not blocked. it does have a filtewhich can get blocked with lime scale.
Dec 27, 2008 | Washing Machines
Estate washer, new, water will not stop, overflowing
you need to replace the inlet valve something is stuck in the valve not allowing it to shut.
Dec 23, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
