Question about Zanussi Washing Machines
When i turn my machine on it seems it starts and then stop without taking any water or any round
  • tas_me Jul 03, 2010
    hai i have washing machine ZANUSSI ZWD16270W its creating problem it is actually washer and dryer the dryer system is working normally but when i put it on washing it creat sound that its starting but in couple of second it click and stop without taking any water without drum moving and when i try to put it on drain it works and drain but it doesn't rinse or spin i would be looking to solve the problem please thanks
  • tas_me Jul 04, 2010
    i have ZANUSSI ZWD16270 W washing machine when i turn it on it buzz and click and stop doesn't take water doesn't move drum doesn't spin
    President:
  • 1,891 Answers
Make sure both hot & cold water is on . and on some models if it does not drain completly . you will not get more water .. ck the drain filter if it has one as i didn't get a brand or model # i don't know what were were working with . hope this helps **** ..
Posted on Jul 04, 2010
  • 4,070 Answers
The wash or rinse cycle won't start until it's filled with water to the selected level. It should run the spin cycle with out any water in it. Try the spin and if it don't work the problem is the timer/on/off switch. It it does spin it's probably a water problem.
The water inlet valve is on the back area where the water hose connects to the washer. It may not be working. You should be able to hear it buzz when it's turned on. Try it with all different temp selections on the washer.
Your pressure switch stops the water and allows it to start the next cycle. If it's stuck on it won't allow the water to start. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Posted on Jul 03, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with check the door switch and then check the water inlet valve. If they seem to be fine then it means that the Lid Switch is defective as when this happens then washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
  • 4 more comments
    thanks for your solution the dryer is working fine but it only washing when i turn the button on 90 or 60 or cotton or any and then press start button it sounds that it starts working but in couple of seconds it clicks and stop same click and stop just like it stop washing but they dryer is working fine
  • Rylee Smith
    Rylee Smith Jul 03, 2010
    Please post back with the manufacturers name and model no# for your washer
    it is ZANUSSI ZWD 16270 W kindly let me know its only more than one year old but waranty is expired it was working fine till yesterday and my 18 month old boy moved the knob couple of time i explain again when i set it to any wash then press start buton it sounds that it starting but stop by clicking without taking water or moving drum but i tried and dryer is working fine
    thanks
  • Rylee Smith
    As dryer is working fine, it means the issue has been resolved.
    Thanks
    Rylee
    the issue is not resolved because the washing is not working its not starting washing
  • Rylee Smith
    Ok then please switch off the washing machine; take
    out the power cable from the power socket and mains. Now let the washing
    machine sit for more than twenty minutes without power and replace the power
    cable and switch it on. The washing machine will be reset and should start
    working normally. If still the issue is not resolved then please check the
    timer and replace if required. Please do accept the solution if the issue is
    Thanks
    Rylee
My samsung top loader will only drain
Very easy repair. By dropping the hose gravity takes over allowing the water to run out. The buzzing noise is the propeller on your pump jammed.(Brawires,coins,hairpins) < common causes.. STEP 1:Drop hose down to remove water from machine STEP 2:Lean machine forward on a 45,rest machine on a chair. STEP 3:Bottom left of machine is a round black cap,remove the cap(turn anti clockwise) STEP 4: Put your fingers in the pump and pull out the coins,hairpins etc from pump. STEP 5:Turn propeller to make sure it turns freely,put the round cap back on then your done. Thanks
Jun 20, 2012 | Washing Machines
Zanussi zwf1421
Thermostat or heater most likely causes. Does timer button move round without doing anything? Timer knobs on Zanussi notorious for breaking off inside.
Apr 28, 2012 | Zanussi F1245W Front Load Washer
Hi, my switch keeps going around and around without stopping
Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
regards
Michelle
Jan 24, 2009 | Indesit W 123 Front Load Washer
My washing machine will not stop filling up. When you switch it on and set it to run on a normal wash, it will start ok and pump out some of the water but then it doesn't seems to stop filling up with...
possibly no part at all.
take top off and locate the pressurestat. this is usually round with up to 9 elec connections and a small diameter pipe as well.
take pipe off and blow down hard and check no split in pipe.
to check pressostat itself, put on a piece of pipe of the same diameter. put machine on fill and gently blow into the pipe ie pressure. you should hear a click and the water will stop coming in
Jul 15, 2008 | Washing Machines
Washing machine keeps taking water in even after programme has stopped
poss moisture on your control module causing tracking . unplug your machine from the mains and take the back panel off, you can try blowdrying the module down in the bottom left hand corner or you can take it off (noting where all the leads go to),get an old toothbrush and clean the solered side around the bottom of the board failing that you will most probably have to change it
Jul 07, 2007 | Indesit WA 115 Front Load Washer
Broken machine
these machines are a pain. the dial is supposed to click round when there is a fault in a component such as the pump etc but in my experience it is just as likely to be the module. all you can do is to check the pump and heater and whatever else you think you can check and if all ok its the module. not worth repairing in my opinion
Apr 05, 2007 | Indesit W 123 Front Load Washer
Maytag Neptune stops during rinse cycles
from what you say it doesnt sound like a water valve. does it fill to correct level the first time round?
Mar 27, 2007 | Maytag Neptune MAH7500WH Front Load Washer
Indesit W123 s UK water overflows from the detergent draw
My machine clicked round, although I did not have the water overflow. I managed to unlock the pump filter, on the front of the machine under the lower panel. This was fiddly. I removed a coin. The machine worked again, but two cycles later starting clicking round the timer. I called an engineer - it worked when he was here, he checked the element and pump and said it was OK. When he had gone, it clicked round the timer again! He came again, and once again it worked perfectly when he was here. Eventually I checked the pump filter again, and removed another two coins. At the moment - it is working!
Oct 11, 2006 | Indesit W 123 Front Load Washer
Washing Machines Logo
44 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
