Question about EdgeStar Portable Air Conditioner Heater
The water light keeps coming on and kicking off the machine even after we empty it.
  • 29 Answers
The float switch which sits down in the bucket may be stuck, try and find it and give it a wiggle to free it up.
will probably find it by removing the bucket and looking in the space where it normally sits.
cheers
Posted on Jul 05, 2010
Hi I have problems with my mitsubishi dehumidifier Oasis Elite MJ-E-142NX-A1 The water tank full light stays on even though the tank is empty. I have emptied the water and replaced the container care
Sounds like your float is stuck in the full position, or the sensor that shows full is stuck on full.
If tank is empty but shows full, problem lies where full signal is coming from.
Aug 19, 2014 | Dehumidifiers
Empty water light, empty condenser
I experienced the problem with a hotpoint TCYM 750, with the red empty water light failing to switch off. After removing the filter and cleaning it, cleaning the condenser and drying anywhere I had access to the machine still didn't heat and the light remained on. Reading the post about the machine having 3 reservoirs it struck me that one of the reservoirs may be hard to access. So I unplugged the machine and tipped it onto its front. The reservoir drained, I pushed the machine back upright and cleared up some water around the condenser. The drier now works properly and the empty water light is off - job done!
Feb 04, 2014 | Hotpoint Dryers
Whirlpool doesnt empty drum after washing
Remove the bottom kick plate and clean the filter. Have some towels handy! There will be some water that will come out when you open the filter. Keep me posted.
Nov 28, 2012 | Whirlpool Washing Machines
My whirlpool front loader washering machine is not draining properly, could you give me a reason why it is not draining properly.
check the discharge hose in the rear make sure no kinks or there could be something in the pump. if it drains slowly i'd say check for kinks. a whining noise while it's draing cloged pump
Feb 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Water keeps overflowing, dont know how to clean the filter or where it is .
hi, read about your problem. The filter is located at the bottom of the front of washer. If its not visible, remove the bottom kick panel. Three screws at bottom. Take a shallow pan and place under filter. Slowly turn counterclockwise and water will slowly start to come out. When pan is partially full, empty. Be sure to close filter before doing this. Keep up with this procedure until no more water comes out, then unscrew filter and remove and clean. Reinstall and put kickplate back on. Hope this helps.
Jan 19, 2011 | Hotpoint Aquarius WD640 Front Load...
LG condenser dryer, TD-C70040E. Empty water warning every 3mins!
Did you repair this problem? If yes, how?
Thank you.
Dec 11, 2009 | LG Dryers
The dishwasher pump will not shut off. Keeps going even after the dishwasher has been emptied of all water. Then the beeping sounds starts and will not shut off.I took it out thinking that I could get to...
depending on the model, your float is off the switch
it is a round piece in either corner, that should float up and down
if you remove your toe kick and look at the bottom of that, you will see where the float comes through it may be off the micro switch telling the machine that the water still has water and should continue to drain, then after you reahc the 2 minute drain cylce it goes into fault
Oct 21, 2009 | Dishwashers
EdgeStar Portable Air Conditioner Heater Logo
158 people viewed this question
Top EdgeStar Heating & Cooling Experts
Donni Steen
John Tripp
John Tripp
James Coghill
Are you an EdgeStar Heating and Cooling Expert? Answer questions, earn points and help others
