Question about Itronix GoBook II Notebook
Im having problems with charging my battery, I got a another battery but for some reason it will not go into the charging mode and just tends to discharge. Can't seem to correct this problem. Not much use as a laptop if I have to have it on AC. Any advice would be appreciated
    Genius:
  • 1,354 Answers
Hi
you have problem with your charger try with other charger then only you come to know what the isuue
Posted on Jul 03, 2010
Grundig lcd tv standby stuck
Inverters use square wave voltage, which tends to stifle digital circuits. Leaving something stuck, or not working. Sure, the inverter will work for awhile, but then the rigid square wave eventually causes problems.
Feb 02, 2014 | Polaroid Televison & Video
ASUS EEE PC 1008P the system togggles between ac mode and battery mode when i try to charge..and the battery orange light tends to blink heavily Charging is done when the eee pc is powered off. On...
Maybe try cleaning the battery contacts on the netbook. If it happens with both batteries, then it may just be bad contact between the battery and the laptop. An emery board, or a small piece of fine sandpaper can be used to clean the contacts on the netbook. Clean both sides of the contacts - do it gently as you don't want to sand down the metal, you just want to clean off any oxidization or corrosion on the terminals. If this doesn't help, it may be a bad charging circuit on the board (new netbook). You could also try charging with a different a/c adapter and see if the problem persists.
Hope this helps!
Joe
Jun 04, 2011 | ASUS Eee PC 1000HD Notebook
I plugged in my battery to the charger, it showed red, charged for a couple of hours, showed green. i used the wg151 trimmer for about twenty minutes, batter went dead , trimmer stopped. i plugged the...
Sometimes, batteries tend to show charge but they are not completely charge. Reason is that they have got weakened and needs to be recharged properly.
For this, I would recommend you to use Nicad Battery Repair Manual. It would charge the crystals inside the battery completely and make them work like the new ones. Hope it would be useful for you. Take care.
May 31, 2011 | Garden
I have acer aspire 5740, purchased 10 months ago from us , what I facing that in a night time my battery completely drained out without any apparent reason b/c in normal working it give me reasonable back...
Are you turning it off at night or just using sleep mode? Turn it off!
Also if you use them on AC power most of the time the batteries tend to hold less and less of a charge as time go's by. You should use them on and off with just battery till it's almost dead, it will hold a better charge then.
Dec 22, 2010 | Acer Aspire 5610-4648 Notebook
I just got the htc hero and for some reason it says its charging but the battery never gets charged. once i take it off the charger (be it usb, car, or plug), it immediately tell me the phone is dying. ...
See if there is someone with a Hero and try their battery out. It sounds like your battery is not holding its charge anymore. If you just got it, take it back to the store and see if you can get a replacement.
Good luck.
Oct 05, 2010 | HTC Hero Smartphone
Canon 300d flash won't fire. Pops up ok but display just reads "busy" and camera locks up. Must turn on/off to get camera working. External flash works ok.
This may sound obvious, but have you tried to make surer the battery is fully charged and then see'ing if it still does this? The reason I suggest this is that I had a similar problem and when I fully charged the battery this problem went away. I tend to keep an extra battery (fully charged) plus the charger on hand at all times.
Dec 09, 2009 | Canon Digital Rebel / EOS-300D Digital...
8320 curve battery in not charging through any medium.
i have the same problem, the solution is to go to BlackBerry Service Centre or buy external charging device for battery.
Oct 09, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
F250 NEED HELP!!!
The only thing I could suggest is that if you bought a remanufactured alternater you may have gotten a bad one. It tends to be hit or miss with any remanufactured part.
Oct 31, 2008 | 1987 Ford F 250
3680 charging issue
ok " new batteries would be a cool Idea, but did ya know you can set your laptop for desk top mode and laptop mode, desktop uses more power , laptop conserves power .
go to control panel look for power management.
Jan 22, 2008 | Acer Aspire 3680 Laptop
Itronix GoBook II Notebook Logo
83 people viewed this question
Top Itronix Computers & Internet Experts
Steven Wander
Steven Wander
Larry Chandler
justwinwin
Are you an Itronix Computer and Internet Expert? Answer questions, earn points and help others
