Question about GE Microwave Ovens
Ge sca1000DWW microwave - how do I remove the grill (above the door) to give it a good cleaning?
  • GE Master
  • 9,098 Answers
See the video at our site or the service manual.
Posted on Jul 03, 2010
When removing the grill to replace the interior bulb I can't get the left side past the upper left door just above the hinge. PVM1970Sr1SS
sometimes you may have to remove all the screws on top to allow the cabinet metal to be a little more loose. then you'll just have to carefully, but forcefully, pull the grill loose from the left side first, then the other side. good luck.
Nov 28, 2015 | GE Microwave Ovens
Can a GE microwave door handle be replaced?
Is this an over-the-range microwave oven? If so, you can usually remove the door by first removing the grill vent above the door (by removing 2 or 3 screws first). With the grill vent removed, you can usually remove the door by opening it and lifting it up off its hinges. Place the door down on a blanket. Using a putty knife, you can pry out the black plastic RF shield (or door gasket). This is the most tricky part, and if you are not experienced, you may break that plastic since it is rather brittle. And if you do break it or crack it, then it must be replaced or the microwave oven will leak microwaves. But once you've got that removed, then you should be able to see and remove the screws that hold the handle to the door. After you replace the handle, it's a simple matter to push the door gasket back into place and re-install the door.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 12, 2014 | GE Microwave Ovens
The interior bulb of my ge spacemaker oven jvm1490sh01 has blown out. How do I go about replacing it? Thanks
HI,
I looked up your model and found that if you remove the grill above the door, you can ***** the bulb area. With the grill removed, in the middle left side, you will see either a black or metal looking cover, if I remember correctly you slide the cover back toward the wall and lift up. There is where your bulb should be.
If you would like unplug the micro way before you enter this area for safety only. I normally don't but I know what I am looking for.
Good luck, be safe
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 23, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I need to replace the interior bulb on my GE profile model jvm1850dm2vv microwave oven. Can I access it from the area where the replaceable filter is?
The oven interior bulb is on the top. Look closely at the grille above the door. There are two recessed screws that hold the grille in place. Remove these and carefully pull the grille straight out. You may have to wiggle it a bit - it's a tight fit on most of those I've serviced. Look in the center of the oven above the door. There is a sheet metal cover held in place with one or two screws (usually one, plus a plastic tab going into a slot in the sheet metal). Remove this screw and pull out the sheet metal. You will see the light bulb and the microwave stirring plate motor. Note that the instructions say you should unplug the oven before changing the light bulb. GE's lawyers are afraid you'll stick your fingers in the wrong place and somehow get shocked if you don't have the power removed.
Jan 31, 2011 | GE Profile Over-the-Range Microwave
Ho should I install a replacement microwave door for the GE Profile microwave JVM1660SB005?
You should notice 3 plastic tabs on top an3 3 on bottom, and 2 on each side. You will need to carefully work the metal out of those tabs until it seperates. It is a whole lot easier if you remove the door from the oven first. Take off the grille above the door, it is held in by 2 screws up top, then just lift the door off the hinge.
Jul 23, 2009 | GE Microwave Ovens
GE Profile microwave remove top grill
1. Unplug power.
2. Remove two screws holding grille, either on top of the front edge of the outer case or in the grille itself.
3. The grille should lift right out. In not, you may need to pull it to the left about 1/4".
You can download GE owner's manuals and installation instructions here.
Some models have them on top.
Feb 04, 2009 | GE JVM1750SMSS Microwave Oven
Microwave mcd11e3b
Hi, This is the info I gave another user yesterday:
Hi, Remove the 2 screws in the grille, the grille pulls straight out (with the door open is a little easier). Then above the light is a cover plate which is removed by the two screws on the plastic frame. You will see a little tab that allows you to lift that cover plate out gaining access to that bulb. As always you should be safe and turn off the power before you repair any electrical device. Good Luck!
Feb 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Light replacement
Feb 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Howv do you remove plastic grill above the door on a GE 1400 spacemaker to dust of the fins
Your owner's manual should cover this, but if for some reason you don't have your owner's manual, you can download GE owner's manuals and installation instructions here.
Usually you just remove the two screws on the front of the top cover of the microwave (or in the grille itself) then lift up/out on the grille, as shown in the drawings below.
Dec 09, 2008 | GE JVM1440 Microwave Oven
Microwave Ovens Logo
55 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
