Question about Sixsixone Peak Mountain Bike Shoe
Sixsixone mtb ratchet power strap - how to undo?
2014 bmw 1200rt rear suspension went solid when pulled down with straps it freed of is it safe to ride? thank you for any info.
Why did you ratchet it down till it was hard you only need to ratchet it down enough to stop it moving around
if it returned to the normal height after releasing the straps and when you sit on it and bounce on the seat and it compresses and rebounds ok it should be safe to ride
I have had my gs strapped down multiple times with no I'll effects
Jul 03, 2017 | BMW Cars & Trucks
1999 gmc envoy fule tank strap broke
use a nylon strap with ratchet latch
Feb 17, 2013 | 1999 GMC Envoy
Outback Bike Rack Side Straps?
use your own or get strap / webbing and buckles from any upholstery retailer
Aug 20, 2017 | Cycling
My daughter has K2 Debut snowboard bindings which are REALLY hard for her to put on, and especially release. Even I have a hard time. It seems like the black strap with the teeth is just a bit too wide...
Try changing the black straps. You can get them in almost every Sports shop. Just take one off the ratchets with you and try out the different sizes they have.
Good Luck
Apr 18, 2011 | K2 Cinch Cts Snowboard Binding
How do you replace the fuel pump in a 99 ford e250 van
First, you will have to drop the tank. Tools you will need are ratchet and socket set, an impact wrench would help.
Put the van up in the air on a lift. Undo all brackets holding the fuel tank to the van. While undoing brackets, also disconnect fuel lines and electrical wires from the tank/fuel pump. When the brackets/straps are taken off, have a jack ready to lower the fuel tank down on. Now you can easily remove the fuel pump and put a new one in.
Mar 07, 2011 | Ford E-250 Cars & Trucks
How do you adjust the memory anatomoic fit ******** the boot of the Roller Derby Spartan Z-9-9 mens inline skate?
You have to lock the silver tab all the way back (it will click and lay flat). You have to keep that down with your thumb. There are two black plastic levers which hold the ratchet strap in place. You have to press them down towards the boot (not together towards the strap). When they are new this is a bit difficult. You may have to do one side at a time (just remember to keep the metal tab in its laid back position or it will snap shut and you will have to start all over again). Once you have the lever stop checks above the ratchet bevels of the strap, you will be able to pull the strap back out. Open and close the strap a few times to get the "new" out of it and it will function fine.
Jan 02, 2011 | Roller Derby Mens Spartan 9.9 InLine...
The easiest way to remove a fuel pump off a camaro
Drive the rear of the Camaro onto a set of ramps and secure the parking brake. If the Camaro no longer runs due to the fuel pump, place the rear end of the vehicle onto jack stands.
Use a socket and ratchet to disconnect the negative battery cable from the negative battery terminal. This removes power from the electric fuel pump.
Place a jack under the gas tank and raise the jack so it butts up against the tank. This applies pressure to the tank and prevents it from falling while you remove the retaining bolts for the tank straps.
Use a socket and ratchet to remove the retaining bolt from each of the two straps located closest to the rear of the vehicle. These are the rear strap bolts. Pull the straps down.
Lower the jack to lower the tank from the vehicle. Because you left the front of the straps attached, the tank rests at an angle under the vehicle. This prevents the need to unhook all of the hoses connected to the tank.
Place the cam tool (J-24187) onto the retaining cam on the top of the tank and turn it a quarter turn counterclockwise. Take the sending unit cam off the tank.
Disconnect the fuel pump from the sending unit cam and plug the new pump into the sending unit.
Place the fuel sending unit cam onto the tank and turn it clockwise a quarter turn with the specialized tool.
Use the straps, bolts, socket and ratchet to jack the tank back up under the Camaro and secure it.
Use the socket and ratchet to reconnect the negative battery cable to the negative battery terminal.
I hope the above helps.
Good luck.
Dec 03, 2010 | 1995 Chevrolet Camaro
How to loosen strap of roller derby's spartan 9.9 rollerblade. I can open the first strap but can't undo the second strap. I can only make it tighter.
You have to pull the metal tab back all the way. It will click and lay flat, but you have to keep it pressed down for it has a tendency to snap shut. There are two ratchet stop check levers (black plastic pieces on the side of the strap). The way they look it would seem that you would have to squeeze them together, toward the strap, but you have to push them down towards the boot. Remember to keep the metal tab depressed so it doesn't snap shut on you. Once you push both levers down and clear the bevels on the strap, you can pull the strap back out. Open and close the strap a few times to get the "new" out of it. With more use, you will be able to squeeze the levers together (like you couldn't do the first time) and depress the levers in one motion making the taking off of your skate a lot easier. Hope this helped.
Apr 01, 2010 | Roller Derby Mens Spartan 9.9 InLine...
Install a gas tank in a 94 toyota corolla
Raise the car.
Loosen the fuel filler neck rubber hose clamp. Remove hose from tank. Insert tubing into tank and siphon out all fuel.
Undo the brake line bracket blots and move brake lines out of the way.
Undo the exhaust to muffler flange bolts. Exercise extra care if they appear rusted as they will shear off.
Remove rear seat and undo fuel pump cover. Undo fuel pump bolts.
Disconnect the fuel and return lines.
Support tank with a jack. Undo tank strap bolts. Remove straps.
Lower tank and remove fuel pump.
Drop tank and slide out over exhaust.
Nov 02, 2009 | 1994 Toyota Corolla
Yard machine rototiller has a flat tire.
You may have to bring it in to a tire mounting service station, as these small tires can be hard to re-seat. You need enough air pressure to seat the tire bead in the rim.
May 06, 2009 | Mtd Products Yard Machines 158CC Tiller
Sixsixone Peak Mountain Bike Shoe Logo
94 people viewed this question
Top Sixsixone Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Sixsixone Cycling Expert? Answer questions, earn points and help others
