Question about Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas
I have a a Laars LX250-L and it appears the ignite switch is faulty. We have had nothing but problems with this unit since installed. Any idea on how to replace the switch? Thx
    Top Expert:
  • Jandy Master
  • 6,465 Answers
Check wiring if 120 volt you have to change wires to the ignitor its not getting hot enough
Posted on Apr 29, 2016
2 Suggested Answers
adamh294
  • 310 Answers
SOURCE: how do you tell if
On the nameplate inside the cabinet where it lists the model info, it would say loNox
Posted on Jan 13, 2011
Laars LX Heater not starting
blower gets 120 vac. ensure proper voltage to blower to start
Jun 20, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Tip
Laars LX250 Manual Download
Laars LX250 Installation & Operation Manual
Models: LX250NL / LX250PL / LX400NL / LX400PL
Models: LT250NL / LT250P / LT400NL / LT400P
Have you lost your Users Manual / Owner's Guide for your Laars LX250 Pool Heater?
Would you like a digital copy of the Installation / Operation Manual for easy searching of terms and quick reference?
Click here to download your pdf version of the Laars LX250 Pool Heater guide.
I hope that helps.
on Apr 19, 2010 | Jandy Laars Lt 250,000 Btu Heater
Jandy LX250 natural gas pool heater will not start heating. Turns on but no heat. Low Pressure Flow
if filters are clean check pressure switch see if 24 volts ac on both sides if not check copper line for clog if ok bad pressure switch you can jump just to check
Mar 27, 2012 | Jandy LAARS LX250 - PROPANE, DIGITAL...
I have a Laars LX250 pool heater. The pump and heater are tied in with a timer that has a fireman switch. When operating properly the switch disables the heater for cool down before the pump shuts off. I...
If this answer does not fix your problem, pleasecomment with additional details prior to rating the answer. Positive feedbackis appreciated once your problem is solved! Thank you.
Aug 17, 2011 | Jandy LAARS LX250 - NATURAL GAS, DIGITAL...
The burners will not ignite
if the unit is used you might have to removed the burner and clean the pilot sometimes rust built in the hole and need to be clean out. I had the same problem.
Apr 11, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Jandy LX250 LT Pool Heater High Limit Switch
Jump the High limit switch. If it fires the switch is bad
Jul 16, 2009 | Jandy LAARS LX250 - NATURAL GAS, DIGITAL...
Jandy lx250 heater is giving me service code ags
AGS automatic gas shut down
which means you have ignition failure, which can be from low gas pressure, or volume. if the heater fires then goes out the signal is not going back to the control module check all wiring.
Jun 16, 2009 | Jandy LAARS LX250 - NATURAL GAS, DIGITAL...
Laars lx 250 fault code "AGS"
make sure safety circuit is ok that cuts off fan and check pressure switch and hi limits
May 22, 2009 | Jandy LAARS LX250 - PROPANE, DIGITAL...
Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas Logo
78 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
