Question about Maytag Atlantis MDE7400AY Electric Dryer
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, If one is blown, the dryer may still operate but not heat. Alternatively, the dryer may heat, but it may not heat up as hot as it should. Replace the Fuses or reset the circuit breaker.
Another common cause of a dryer failing to heat is a faulty Heating Element. You will need to replace it.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Posted on Jul 04, 2010
Dec 11, 2014 | Maytag Refrigerators
Feb 08, 2013 | Refrigerators
Air
Temperature Control Blend Door Failure No Heat or no AC (dependes on
where door sticks)
In
all modern cars there is a tiny DC electric motor driven gear drive
that moves a plastic door that blends heated and cooled air from the
AC and the heater core, this is called (interestedly enough) the air
temperature control blend door actuator. The motor that moves this
door fails because the door starts sticking from warping, most common
complaint is no heat but it can be no AC as well. To replace these
parts (blend door and blend door actuator) you must remove the entire
dash from the car. Always have this problem confirmed by a dealer or
qualified repair shop as it is a very expensive repair.
Other causes of no heat in the cabin are engine thermostats that are stuck open (engine runs cold) or air bubbles in the cooling system.
Jan 03, 2013 | Cars & Trucks
Nov 17, 2012 | 2004 Chrysler Pacifica
Mar 13, 2012 | Maytag MZD2766GES Side by Side...
Oct 25, 2010 | Amana ABB1927DE Bottom Freezer...
Aug 19, 2010 | Chevrolet C1500 Cars & Trucks
Jun 02, 2009 | 2000 Chevrolet Blazer
Jan 13, 2009 | Conia DVD8500 DVD Player
Sep 16, 2017 | Chevrolet Tahoe Cars & Trucks
486 people viewed this question
