Question about Carrier 38CKC030 Air Conditioner
My Carrier air conditioner condenser unit model 38CKC030 doesn’t always start.
    Guru:
  • 415 Answers
Check the contactor........it is possible the contacts are wearing..........the contactor is considered a wear-n-tear item.
Posted on Jul 03, 2010
Problem with frozen coil
Hello, the evaporator will freeze from either low airflow or a low refrigerant charge. Check the air filter, blower whell to make sure it is clean and air is movimg freely. If the unit is clean and filter is clean then the unit is low on refrigerant due to a leak and will need to be rechaged.
Aug 08, 2011 | Carrier 38CKC030 Air Conditioner
I have a carrier 38ckc030 air conditioner. the unit outside is not turning on. it sounds like it wants to and if you manually spin the fan it will slowly build up speed, but the air coming into the house...
you are right replace the compressor/fan capacitor this helps compressor/ fan start its the round silver or oval part in the condensor ..let me know ..good luck/joe/
Aug 26, 2010 | Carrier 38CKC030 Air Conditioner
Air condition unit of sufficient size??
You currently own a 2.5 ton AC Unit
500 square feet equals a ton of cooling/ you need a 3.5 ton unit.
If your home is well insulated, good windows and doors and pretty good
shade that covers your house, then I can see a 3ton unit cooling your
house.
Thats another 6,000 btus you do not have and that is a best case for a
energy effcient home.
Jul 07, 2010 | Carrier 38CKC030 Air Conditioner
38cks is blowing air but it's not cooling
First thing, are the filters clean? If so then you have lost some gas from the system and need to find and repair the leak, and put in correct gas charge.
May 21, 2010 | Carrier 38CKC030 Air Conditioner
We require condenser fan motors for Interclisa Carrier package (rooftop) air conditioner model AAD 250 (1980's model) model. Air conditioner - supply voltage 380 Volts 50 Hz AC. Condenser fan motor voltage...
Hi, this is an odd voltage 380 volts. Is it a 3 phase unit? To get a 220 volt 50hz condenser fan motor, you will have to go through a refrigeration/air conditioning parts house and order this. 60hz you would have no problem finding one in stock. Carrier is a good unit, and have been around for many years. You shouldn't have any problems locating one.
Sincerely,
Shastalaker7
PS You will need to go through a wholesale parts house.
Jan 21, 2010 | Carrier Heating & Cooling
Ac sytem blows strong air but its warm
If the compressor and fan work in the outside unit, and the fan inside (air handler) works, probably the system is low in refrigerant which means there's a leak that has to be fixed and then recharge the unit.
Sep 04, 2009 | Carrier 38CKC030 Air Conditioner
The light on the control board if blinking 6 times, how do I get rid of it? the light is saying VH VC. David Stowers
I think that you need to turn off power to the unit and reverse the 240v wires that are on the transformer,I think that the polarity it backwards,I had a similar problom with 2 york units,good luck!
Jul 09, 2009 | Carrier 38CKC030 Air Conditioner
I have a central air conditioning unit in the apartment where I live. It is a split unit - somewhere outside is my outdoor unit (and everybody elses too). Anyway I seem to get way too much humidity in my...
the humidity problem is from the condesation drain. It is more than likely to be clogged up keeping water in the condensation pan causing the humidity problem. This can be cured by a wet vac put onto the outside drain for the inside condensation pan and turned on. this removes the algae that builds up in the a/c condensation pans. Also, an a/c unit is designed to last 25 to 30 years depending on the location of the outside unit. Inside unit being an apartment, has other issues, it just may need to have some preventive maintenance done such as coil cleaned filter changed, motor oiled, etc....
Jul 08, 2009 | Carrier 38CKC030 Air Conditioner
The upstairs unit is freezing up, full charge, no filters and all vents are open.
no filters hmmm. i suspect a dirty evaporator low air flow freeze up. Good luck Tom
Jun 25, 2009 | Carrier 38CKC030 Air Conditioner
Carrier 38CKC030 Air Conditioner Logo
218 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
