Question about Samsung SCX-5115 Fax Machines
We have a Samsung SCX-5315F printer that now has a drum warning light on. Is that hard to fix?
    President:
  • 3,085 Answers
Just replace the drum.
Posted on Jul 03, 2010
Blank copy print is good
you are check the cartridge or laser scaner
Apr 01, 2014 | Samsung SCX-5315F All-In-One Laser Printer
I need samsung SCX-3201G Mono Laser Multifunction Printer driver
i need a samsung mono laser printer SCX-3201G DRIVER DOWNLOWD MY PC
Feb 27, 2012 | Intel Computers & Internet
Samsung SCX-6322DN power to display "system
Dear
Try to re assembly all harness terminated at main board, Test the machine on toner cart and drum cart opened. System not initialized, check the main board.
Thanks.
Apr 02, 2011 | Samsung SCX-6322DN All-In-One Laser...
Scanner lock error
just open the scanner unit clean strip cable and end position sensor on the logic board and start the printer :)
Mar 22, 2011 | Samsung SCX-5315F All-In-One Laser Printer
Have a Samsung SCX-5315F All-In-One that has a line running down the page when you copy using the document input tray. Clean copy when using the flatbed. I have cleaned all the glass thoroughly.
It sounds like it is dirty where it feeds through and not on the flat bed glass. Try and gently lift up the top section where the paper feeds through. If it resists you may need to locate clips or screws but generally the thin strip of glass under the top feeder is easily accessible. Good Luck
Feb 18, 2010 | Samsung SCX-5315F All-In-One Laser Printer
Samsung scx-5315f printer giving error paper jam 2 inside .
If you have taken apart the printer and checked where all the paper could have jammed up, use compressed air first on the printer. Then, check your toner cartridge. I know on my HP I had a sample toner cartridge and I put another one into the printer. It either was damaged or scratched, etc. and it caused the printer to not respond.
Sep 01, 2009 | Samsung SCX-5315F All-In-One Laser Printer
Samsung scx5315f printing black smudge along edge of page
The fact that it's printing anything suggests that it is not a Toner problem. Remove the toner, and have a look at the run inside the printer, checking for any excess toner which is in there. Also, check the Drum and Imaging Unit for damage, wear and tear etc. There will also be a static strip near the imager, with a little tab which you can sweep across the unit to clean it.
Mar 05, 2009 | Samsung SCX-5315F All-In-One Laser Printer
Error code
I believe your error message is "Open Heat Error". If that's the case, your fuser unit is bad. I understand that it is a new unit, although you do no specify if is is brand new or refurbished.
Now see, the open heat error comes when the temperature sensors on fuser detect a higher temperature than normal. I f that's the case you can easily confirm that by opening the side door (as if changing the toner) and feeling the intense heat coming out. If the fuser was new, then most probably you got a bad power supply board.
This is truly bad news, because for the power supply board to get damaged, a voltage surge must have ocurred. In most cases, there is also a need to replace the main board as well, for the copier starts working erratically, and loses some of its functions (such as duplex copying).
If the unit is under warranty, call Xerox. If you plan to get it repaired, or fixed by yourself, you can buy cheaper Samsung parts, for Samsung is the real manufacturer of the unit. The Samsung model is SCX-5115 gor a non fax unit, and SCX-5315f for a fax capable unit.
Good luck.
By the way, if you happen to fix the copier, or buy a new one, the only way to TRULY protect it from voltage damage is with an Innovolt SVSS protector. This is truly new protection technology and we sell them a lot here in Puerto Rico. Price is $74.95 plus shipping.
May 28, 2008 | Xerox WorkCentre M15i Laser Printer
Samsung scx 4100 cleaning the roller
Roller Means Paper picker or you are talking about drum unit or fuser let me know.
Mar 25, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Samsung SCX-5115 Fax Machines Logo
194 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
