Question about GE 29888GE1 Digital Answering Machine
How do I hook up my answering machine to my phone working fine picks up after four rings but no one can hear the greeting? any Clues? It does have a brand new battery too.
SOURCE: Answering drops call when answering
I have had the same problem when trying to connect the GE-29569 to my PBX. The PBX manufacturer suggested the the answering machine might be pulling too much power, which would result in a dropped call. I have not resolved this problem yet. However, the machine works fine when connected to my home line, but still does not work with the PBX. Since both work fine separately, I can only assume that power requirement might be the problem. RFR-US
Posted on Jan 08, 2007
frankmann
  • 47 Answers
SOURCE: Answering machine doesn't pick-up reliably
I found in the manual that if the machine doesn't answer after the correct number of rings, then it may be the ringing system used by the phone company. But I have also heard of people with VOIP (such as Vonage) having problems with this as well.
http://telephones.att.com/docMgt/public/art/21714/1738_english_manualpart2.pdf
Posted on Dec 13, 2007
SOURCE: howto change ring times for audiovox answer machine
Press and hold the Play button and then press 'skip' button to change the display which will skip from Ar 3, to Ar 5, for 3 rings or 5 rings respectively. Release the buttons when you have the setting you want.
Posted on Jan 16, 2008
SOURCE: answering machine GE 29878GE2-b manual
have no manual for digital messaging system model 29878ge2
Posted on Sep 17, 2008
  • 32 Answers
SOURCE: I have a GE29869GE2 Answering
1. Press set button
2. Use next and previous buttons to select number of rings setting and press set.
3. Select the number of rings you want.
4. press set again to save setting.
I hope this helps. Here's the manual:
29869GE2 Digital Answering Machine
Posted on Dec 29, 2008
Answering machine will not pick up after four rings
What model Uniden 5.8GHz phone/answering machine? Exactly what does it do after four rings? Does it just drop the call or continue to ring? Is the answering machine turned on?
Nov 19, 2013 | Uniden 5.8GHz Expandable Cordless Phone...
How do I set up the voice mail on the 5.8 vtech phone?
Set up the answering machine that came with your Vtech 5.8phone. To activate your voice mail, press the "Answer on/off" buttonat the base of the main cordless phone. Press "Setup" and then usethe arrows to set the number of rings before the answering machine picks up Press the "Announce" key on your Vtech 5.8 mainphone base to listen to the greeting that people hear when they call you. Press"Record" to record a new greeting and then press "Announce"to listen to the greeting.Press "Play" on your Vtech 5.8 main phonebase to listen to your voice messages. Press "Delete" to erasemessages.
Mar 11, 2011 | Vtech 5.8GHz Analog Cordless Phone
THE ANSWERING SERVICE CUTS IN BEFORE I AM ABLE TO GET TO THE PHONE
There should be a switch towards the bottom on the right hand side
Setting ring time switch The ring time/toll saver switch allows you to set the number of rings the caller hears before the answering system plays your outgoing message. You can set the switch to answer af ter two rings or af ter four rings. Once the greeting has star ted, you can stop it when you pick up the call at the handset or base. In the TS (Toll Saver) position, the answering system picks up af ter two rings if you have new messages, and af ter four rings if there is none. This way, if you call long distance to check your messages, you can hang up af ter the third ring to avoid billing charges.
Feb 28, 2011 | Uniden Cordless Phone
Need answering machine with externally inaudible greeting
You could always simply turn the volume down? to the speaker, well as long as she uses the handset?
Feb 15, 2010 | GE 29871GE3 Digital Answering Machine
THE FAX ANSWERS BEFORE THE ANSWERING MACHINE. ALL ALONG THE FAX WOULD ANSWER FAXES AND THE ANSWERING MACHINE WOULD ANSWER CALLS. NOW THE FAX ANSWERS ALL CALLS. ON FOUR RINGS. WHAT SETTINGS DO I HAVE TO SET...
You have to set the fax to at least one more ring than the answer machine. When the phone rings the fax wakes up and listens after the answer machine picks up, if it hears a fax it will take over and print the fax.
Jan 13, 2010 | HP PSC 2210 All-In-One InkJet Printer
I have a Uniden 5.8GHz DSS8955+1 and it's connected to my phone and fax. The problem is: everytime the fax rings, the answer machine works as it works when is a phone call. How do I set up the machine not...
Set your answering machine to pick up after four rings2.gif . This will give the fax machine enough time to take the call if it senses that it's an incoming fax. Setting the answering machine to pick up after four rings would give the fax machine enough time to accept the fax.
hope this was helpful .
Nov 13, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
#1739 answering machine hooked up but keeps asking for "password"
The unit appears to be stuck in "message retrieval mode) and is asking for your password to give you access when you call in(remote answering). You need to return the unit to it's factory default settings. If you don't still have the instructions you can get them here:http://telephones.att.com/docMgt/public/art/309494/1739_manual.pt2.pdf. Hope this helps!
Mar 28, 2009 | AT&T 1717 Digital Answering Machine
Incoming faxes not received, all else works.
It is your phone answering machine that must pick up in three rings or less.
Therefore 4 is too much. I would not limit number for fax machine itself.
On receipt of fax sometimes seems like it will not work when answering machine picks up in the middle. However, leave it and it will work. Sometimes sender will hear your answering machine and cancel as well. So try to ensure they don't give up at other end as well.
Good Luck!
Feb 26, 2009 | HP OfficeJet 6110 All-In-One InkJet...
DXA18580 series
Increase the # of rings before the fax picks up so that it's greater than the # of rings before the answering machine picks up. When you're expecting a fax, turn off the answering machine.
Syskiyou
Jul 26, 2008 | Uniden Cordless phone EXS9950
GE 29893GE1-B Digital Answerer Problem
G.E.speaker phone model#29322GE1-a how to program other numbers in phone
May 17, 2008 | GE 29893GE1 Corded Phone
GE 29888GE1 Digital Answering Machine Logo
179 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Dudeman321
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
