Onkyo TX0SV454 When I turn it on, after a few seconds it powers itself off
  • btmrmom Apr 18, 2008
    No habla espanol - can any one tranlate for me??
    Genius:
  • 1,550 Answers
Tu aparato se esta protegiendo contra un mal mayor ya que los circuitos amplificadores de audio estan quemados por eso se te apaga.
Posted on Apr 17, 2008
  •  Francisco Mauricio G
    Francisco Mauricio G Apr 18, 2008
    Your audio amplifiers ICs are damaged that's why the device protect himself from a larger damage.Good luck
Onkyo TX-NR515 will not stay on
pls. check speaker wires for any open cracks. try the speakers to another amplifier and if it works from there your onkyo must be in trouble. open the unit and check for any blown fuse, if found any replace it w/ the same value, do not replace fuses w/ higher value.
Jun 30, 2013 | Audio Players & Recorders
Won't turn on.standby light on,fuse under cover is good.what next? onkyo tx-sr605
The only thing to test would be to disconnect all speaker wires at the receiver then turn it back on. If it still won't turn on, it's an internal power supply issue and will need service. If it turns on, post a comment and I can walk you thru further troubleshooting. Hope this helps
Dec 19, 2009 | Onkyo TX-SR605 Receiver
Onkyo HT-SR800 won't turn on
If you call Onkyo directly, 201-785-2600, there is a procedure to "reset" the system, something like holding the power button on and holding down another button for a few seconds. Can't remember which, so I can't be sure, but try giving them a call.
Jan 02, 2009 | Onkyo HT-SR800 System
My Onkyo Receiver TX 601 is turning itself off
Several things can cause this: Loud signal passages can momentarily draw high currents at the mains, especially if you have unit plugged into power stripe with other equipment. Or if unit is plugged into isolation transformer, current draw may exceed output of transformer. Too many speakers hooked to output or if one is bad (partially shorted due to overheating)
Apr 04, 2008 | Onkyo HTR500 Receiver
Onkyo receiver (HT-R430) cutting out after a few seconds
This problem is related totally to the remote control.Pres the CRL button rapidly during that 3 sec interval and get the nunmber down
Nov 12, 2007 | Onkyo HT-S680 System
UNIT TURNING ON BY ITSELF
check and see if the power button is not binding tightly on the body of the set.if everything is okay call a tech you are having a short in the power supply good luck.
Apr 11, 2007 | Onkyo TX-SV535 Receiver
DR-C500 problem with turning the system ON
Make sure all power connectors, cords and plugs are inserted securely and that the outlets are in good working order Be sure to select an audio source (CD, AM/FM, etc.) For powered systems, unplug the power pack for a few seconds, and then reconnect it. This allows the unit to reset itself after a power surge or power interruption. good luck!
Jan 07, 2006 | Onkyo DR-C500 Multi-disc DVD Player
 Grubhead
Grubhead
