Question about Fujitsu 24C1 Air Conditioner
Timer THE TIMER LIGHT AND ON/OFF LIGHT IS FLICKERING, AND WE CAN'T GET THE HEATER TO WORK
  • 456 Answers
Turn the unit off, replace the battieries in the remote
power the unit on with the remote. On the remote see if there is a systedm reset and if there is reset it.
Posted on Jul 03, 2010
Just got this refrigerator dec. 2016 model number LGHT2046QPO THE refrigerator lights were flickering and now the refrigerator portion seems to be getting warm, the freezer works
If lights are flashing you mean the compartment light so you can see inside? This can be ice buildup in light switch which is caused by bad defrost timer or defrost heater or defrost thermostat. Go to many appliance parts sites on Internet and they have troubleshooting procedures along with repair procedures and will sell you parts at reasonable price.
Aug 01, 2017 | Refrigerators
What does a flashing heater symbol of a ford ranger diesel truck mean?
If this flashing goes away after a few minutes, this is normal. The glow plugs are on a timer and when the timer works a light should cycle on the dash. Often there may be a clicking noise and the lighting system may flicker when the glow plugs receive power.
Dec 21, 2014 | 2000 Ford Ranger SuperCab
Why do lights flicker
An electric water heater will draw a lot of electricity. Your house may not be wired well, and when the heater kicks on, your lights will dim some. If your house is over 25 years old, it's likely normal.
Nov 02, 2014 | Rheem RTE 27 Tankless Electric Water...
Ge timer 15131 buzzing
Copy following link to see array of GE analog timers, including 15131: Model numbers and designs change as products are updated to meet new marketing objectives.
http://waterheatertimer.org/GE-timers-and-manuals.html#15119
Information about 15131 analog timer:
Plug timer into different outlet to eliminate outlet-wiring as possible suspect.
If timer makes noise only when connected to one outlet, then test outlet for loose wires, and feel is outlet is warm, or circuit breaker is warm to touch to indicate electrical problem.
GE15131 is ordinary analog timer with small clock motor inside that rotates timer dial. Motor gears are plastic, and generally very quiet.
So the timer has small motor that could cause humming noise.
There is also a switch that could be partially burned, from use-and-age or overload, and that could be flickering, but you would expect that to happen only when light was ON, and light would probably flicker, or not turn on.
Buy another timer if noise is annoying. These timers have 1 year limited warranty, and can stop functioning within a year or two, just like a $10 Christmas toy might not function very long.
Analog timers sometimes work for many years.
Nov 20, 2012 | Hardware & Accessories
Installed 8 low voltage lights with a malibu digital 120w timer 2 months ago. The timer does not always work. I'll unplug then power up the system and then the lights turn on. Never had this problem...
Timer is not identified:
Open following link to see low-voltage digital timers and then add a comment if needed:
Page also has links to warranty information, and list of advisories so power pack lasts longer.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#digital
There are 2 likely suspects: Bad timer, or electrical problem.
There is no repair for bad timer, but timer has warranty through the manufacturer/ Malibu.
Electrical: Since power pack worked correctly before, then outlet probably has correct polarity, but I always suggest checking outlet with circuit analyzer.
Also plug lamp into same outlet and see if there is flickering that would indicate loose wire. Wiggle circuit breaker and see if lamp flickers. Move the outlet and see if lamp flickers.
Outdoor outlets get loose wires because of exposure to temperature and dust and moisture. Replace outlet and don't use the quick connects, instead use screw terminals.
If possible, move timer to different outlet on different breaker and see if problem persists.
Oct 05, 2011 | Hardware & Accessories
Have intermatic timer model et70215c. Interior lights flickering. Checked all connections and when circuit #1 on the circuit board is touched the lights flicker. Can the circuit board be replaced and...
1) If this timer was working fine before and stopped working, then timer is defective.
2) For warranty claims and parts:
Intermatic Inc.7777 Winn Road, Spring Grove IL. 60081
https://parts.intermatic.com/
3) If this is new timer or existing installation went bad, then check that circuit is clean.
Use circuit analyzer on outlet on same breaker.
Circuit problems can affect timer electronics.
4) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer, or any do-it-yourself project.
Dec 28, 2010 | Intermatic ET70215C Double Electronic 2...
Heater turns itself off after 2 minutes.
there might be timer setting or there coil is faulty.check it.
Jan 14, 2009 | Honeywell HZ-3220BW Compact Heater
Whirlpool gs6shexns00 fridge
I had a very similar problem- flickering light bulbs, shorting-out noises, electronic temperature displays not working. I had to replace a small circuit board (the "Electronic Control Board") accessed from the rear of the fridge. A relatively easy do-it-yourself job.
Refer to this link at PartSelect.com:
http://www.partselect.com/PartDetail.aspx?Inventory=2180152&SourceCode=1
Oct 26, 2008 | Refrigerators
Fujitsu 24C1 Air Conditioner Logo
386 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
