Question about Canon PIXMA MP150 All-In-One InkJet Printer
After replacing ink I am still getting an error that the ink in low.
  • 979 Answers
Hello guest, try cleaning the ink cradle, usually it has dried up ink on it, if you can disassemble it, you can use warm water to soften the ink. once cleaned assemble and test.
Posted on Jul 03, 2010
New ink cartridge and still getting error UO41
Error U041 is strictly a low ink error message, so it's strange that replacing the ink would not resolve it. Make sure the ink cartridges are inserted properly and the protective tape has been removed from the cartridge. If not, there might be an issue with the ink cartridges not being locked in place.
May 04, 2012 | Canon PIXMA MP460 All-In-One InkJet...
Why do I continue to get the E error message and blinking light on cartridges
The 'Ink Alert' or 'Low on Ink' message displays on the computer or on the product control panel.If the cartridge has been refilled or re manufactured, 'Low on Ink' or 'Ink Alert' or error messages appears on display panel.Replace with the new genuine cartridge which is showing error on display..
Nov 24, 2011 | HP PSC 1315 All-In-One InkJet Printer
Canon pixma mp272 printer. replaced black cartridge for the first time and now it wont print. getting error p08 on the printer and error 5200 on my laptop screen
Hello Hellen,
the error P08 is error for abnormal temperature in print head. Aa possible cause the ink cartridge is faulty and needs to be replaced.The same error description is for 5200 on your PC.
I recommend that you try to replace ink cartrigde under warranty in store where you bought it. If after that you still have error, take the printer to the service center because they logic board ( pcb ) is faulty.
Hope that helps!
Aug 25, 2011 | Canon Pixma MP270 All-in-One InkJet...
I have an hp deskjet 940c. I don't know if this is the same model as deskjet inkjet. Anyway what light is on or off on the front when a new ink cartridge(s) is needed?
For the HP 940c, there is only one light to indicate a possible low ink cartridge. The LED above the cartridge symbol (the only one without a button) will flash. (Note: this LED is the second from the left.) When you see the error code, open the printer's top cover. If the error is a low ink issue, the LED will stop blinking.
With the cover open, the cartridge carrier will move until the yellow arrow lines up with an icon on the printer itself. These five icons are in order from left to right (as you look at the cartridges) : tri-color ink cartridge problem, black ink cartridge problem, tri-color ink low, black ink low and cartridges OK. If both cartridges are low, replace the one indicated by the arrow. Then the cartridge carrier will move to indicate the other cartridge is low. (If only one has a problem, after you replace it, the carrier will move to the cartridge OK symbol.)
If HP offers the full-feature software for your OS, then install the software. Use the HP Deskjet Toolbox to get exactly which cartridge needs to be replaced without needing to be ready to replace both (or to monitor your ink level (approximate ink level)).
The manual for the Deskjet 940c is available as a PDF from HP: http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=125&prodTypeId=18972&prodSeriesId=35985 .
I hope this helps.
Apr 11, 2011 | HP DeskJet 940c InkJet Printer
I keep getting System Error 0A0000 00000002
The error indicates low air pressure to the ink supply station. There is either a leak or the Air Pressure System (APS) is bad. Check for ink inside the rear door to the Ink Supply Station (ISS) and at the print head locations at the carriage.
If there is ink leaking at the ISS, replace the ink cartridge that is leaking. If there is a leak at the print head, replace the ink tube system. If there are no leaks, replace the APS. See the following link for parts: http://www.lpscomputer.com/c-654-designjet-1050c-1055cm.aspx
Apr 14, 2010 | HP DesignJet 1050c InkJet Printer
We have a Dell 944 showing Error 1102 consult user guide...cannot find the user guide. We just replaced color ink cartridge with a re-processed one ordered online. Please advise...many thanks!.
Hi there
Dell Printer 944 error message 1102
Please unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Now plug everything back in. This will reset any error messages the printer has. Now open the printer with the power on and the cartridges should go to the center to be replaced. Take out both Dell Series 5 ink cartridges and make sure the tape is off the cartridges and insert both back in and make sure the seat properly and latch. Close the printer and it should print an alignment page. If you still get the error message
Why does my Dell ink cartridge level still show up as "low ink" after refilling them?
Dell ink cartridges have a sensor that reports the ink level as low once it reaches a certain level. The sensor can not
be reset. If you refill an ink cartridge that previously reported low ink, it may print fine, but the sensor will always
report low ink. Buying or replacing ink cartridges with new Dell cartridges will resolve the low ink message.
Dell discourages ink refills. Refilling ink may lead to print quality problems, and even eventual hardware problems.
This post is in no way a validation of refilling ink cartridges.
Why my printer is reporting “low ink" after using refilled/remanufactured ink cartridges?
Most ink cartridges have sensors that report the ink level. The “Low Ink” is usually the last sensor (fuse) before
running out of ink.
Since the sensors are fuses that open when the ink level drops, they cannot be reset. If you are using refill or
remanufactured ink cartridges, the best thing to do is to disable “ink alerts” on the printer’s software so you don’t keep
getting “low ink” messages.
To disable “Ink Alerts” on Dell inkjet printers:
1. Open the Dell printer software (All-In One Center, Tool Box, etc)
2. Go to Settings
3. Advanced
4. More Options
5. In the “Appearance Mode, window, check “Never display the Printing Status window” and “Display the low
ink alert only when the cartridges are almost empty.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 23, 2010 | Office Equipment & Supplies
Dell a940 error code 50c
From doing my research, I have found that the 50C Error message comes from the cartridge, usually if it has been refilled. If this cartridge is new, please return it to the place of purchase for a new one or a refund.
Here's what happens when you refill the Dell Series 2 ink cartridges. There is a sensor in them that cannot be reset.
Dell ink cartridges can only be purchased at Staples, Walmart or Dell's website.
Dell ink cartridges have a sensor that reports the ink level as low once it reaches a certain level. The sensor can not be reset. If you refill an ink cartridge that previously reported low ink, it may print fine, but the sensor will always report low ink. Buying or replacing ink cartridges with new Dell cartridges will resolve the low ink message.
if u have not refilled ur cartridge and u still get this error i suggest u buy a new cartridge.....
good luck
have a nice day
Jul 08, 2009 | Dell Office Equipment & Supplies
Wont print with all new ink cartridges
If the error message is only "magenta/cyan low", it doesn't cause any error. The low message stays after replacing ink cartridges if they're replaced too early (before they're indicated as actually empty), it doesn't cause the printer to not work.
However, some other problem might be faulty, or there might be another error message. Try emptying printer queue and print from Ink Management -> Menu/set (twice) to check wether the problem is with communication from pc or if the printer actually is unable to print.
May 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
Installed new ink cartridge/ still saying low color
try calling 1 800 421 6699 for US.
solution
try to remove inks, then reseat it..
then remove printhead, by pushing the latch on the upper right, then put it back in. be sure that it will snap. close the door with no inks. try to look at the message, if it has the same error, put the inks on it and close the door again.. then if you still have the error message, call the hotline no. and I'm Afraid that you need a Printhead replacement or defective ink issue...
they will replace it for free..
Feb 09, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Overiding Empty Cartridge error for Dell A10 962
I would take out both cartridges and put them in again. Realign the printer and the error codes should remove themselves. Try turning the printer off and on before puting the cartridges in again. That may make a difference. You can let your computer know not to tell you when the ink is low too. Let me know how this work for you.
Cynthia Charczenko
Dec 26, 2007 | Dell A940 All-In-One InkJet Printer
Canon PIXMA MP150 All-In-One InkJet Printer Logo
old marine
old marine
