Question about Refrigerators
I have a Kenmore refigerator with the freezer on the bottom. The freezer is cold but it isn't freezing anything. It is about as cold as the top refrigerator.
    President:
  • 1,561 Answers
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if not OK replace defrost timer.
Usually this is a sign of the defrost is no taking place. On base of refrigerator behind the kick plate grill is a defrost timer. Turn the timer clockwise until compressor stops. Leave in that position for up to 30 minutes. The refrigerator should restart on its own after that wait. If not turn the timer again until compressor starts and replace timer. During the time off this should have put the refrigerator into defrost and inside the freezer compartment you should hear crackling and sizzling as the defrost heater melts the ice and water drops down onto the defrost heater.
Take care.
Posted on Jul 03, 2010
2 Suggested Answers
SOURCE: Top freezer Freezes/ Bottom not cold
defrost problem. advance defrost timer to defrost (till it shuts off) . remove freezer panel, check voltage and amps to heater,if heater is hot, replace timer, if heater is cold and no voltage, replace defrost limit switch. defrost all ice, carefully! with hair dryer, no poking with screwdriver.
Posted on Nov 05, 2008
I have Kenmore Elite 59673503201 freezer fan went out replace then it started freezing at the bottom of the refrigerator put in new vent control at the top of refrigerator still doing the same thing
The temperature control thermostat, alson known as the colds control thermostat has gone bad and basically isn't converting electrical/temperature signal properly and needs to be replaced.
May 17, 2012 | Kenmore Refrigerators
The top of my refigerator is freezing in the back
Hi, the problem you are having is the defrost timer not going into defrost mode when the timer says to. They are normally located in the bottom back of the unit and will have a screw driver slot on it. It may be stuck in the off position. Turn it a click with a screwdriver and see if this starts the defrost mode and other problems. Is the evaporator fan in the freezer up and running? If not, this motor must be on. Keep me posted on this and we can get to the bottom of the problem.
Sincerely,
Shastalaker7
Mar 03, 2010 | Refrigerators
Hot to touch
there is another fan at the bottom, rear, of the refigerator. remove the bootom panel and look at the cooling fins to make sure they are not bent into the fan blades. Caefully bend the fins away from the fan. this should improve the cooling of the refrigerator and get rid of the hot spot on the rail between the refrigerator and freezer.
Apr 26, 2009 | Kenmore 53542 / 53544 Side by Side...
Freezer is not freezing properly and the refigerator is not cold
You have a defrost problem. The fridge gets cold air from freezer, if ice blocking from no defrost, no fridge temperature.
Apr 26, 2009 | Kenmore Refrigerators
Oct 26, 2008 | Kenmore 53642 / 53644 Side by Side...
Freezer staying cold but defrosting on Kenmore Refrigerator dripping into bottom frig
I bought kenmore refigerator 21 cu.ft. year ago, but recently on top of freeze door side produces ice would you please tell me what's happen and how to prevent.
Sincerely,
Tim Kao
Jul 09, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
My refigerator and freezer are not cooling enough
Is the fan in the freezer running?? Is there frost on back panel of freezer??
Oct 03, 2007 | Kenmore 50522 / 50524 Side by Side...
Kenmore Refigerator
Is your fan in the freezer blowing, condenser need cleaning, condenser fan working, any frost build up in freezer? controls set in the middle?
Aug 26, 2007 | Refrigerators
Refrigerators Logo
23 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
