Question about HP Pavilion a1330n (EL466AA) PC Desktop
No power to my desktop computer. Flashing green light on back near the power cord, I believe in the power supply.
    President:
  • 3,085 Answers
You have a bad power supply, easy and cheap to replace
Posted on Jul 03, 2010
No power to computer, flashing green light by power cord
reset the surge protector first!
then investigate the power supply
Mar 27, 2012 | Compaq Computers & Internet
Computer was shut down and power turned off. When i restarted the system the printer and monitor came on but the tower is not getting any power. cords are all plugged in and checked outlet works. seems...
If the outlet is good and the cord is good, you may have indeed blown the fuse in the power supply. That is the only fuse. The fuse in the power supply is usually "hard-wired". Not necessarily, but usually. You would need someone familiar with them to replace it if it is blown.
Some computers have a green LED on the back of the computer near the power cord. Do you have one? Is it on? You can also look to see if the small green LED is on on the motherboard.
If you get no indication of power, the power supply is probably gone. A new on is about $25 and pretty simple to replace.
Hope this helps.
Thanks for using Fixya.
Feb 20, 2011 | HP Pavilion a705w PC Desktop
Tower won't turn on. There is a green light on the back near the power cord that's flashing green.
Pull the power cord out and allow it to reset. If you still have issues you may need to replace your power supply.
Aug 05, 2010 | HP Compaq Presario Media Center SR1750NX...
Green power supply light blinking, computer won't start.
A lot of those E-Machines used a small power supply (150 to 180 watts) and were known to have a failure rate. There is a way to check them by jumping across a two connector wires on the end that plugs into the Motherboard. Let me know if you want try this.
Apr 25, 2010 | E-Machines T5026 PC Desktop
Green light flashing on back of unit near power cord also green light flashing on motherboard near power supply plug in.
I would suggest trying to replace the power supply. If that does not fix the issue, i would need to hear more about the computer.
May 06, 2009 | Sony VAIO VGC-RB40 PC Desktop
No power
Disconnect your power. Remove the batter (CMOS), unlplug the power cable harness to motherboard. Plug in your main power cable cord (to power supply) then carefully plug the power cable harness to motherboard while simultaneously holding the power switch on computer down. Be sure sweaty palms are not touching the motherboard. power leads, or any other items as not to short any components.
Happy Computing!
May 05, 2009 | Computers & Internet
When comp pluged in just a green flashing light
If you are sure that the 110 volt power is coming into the computer then the most likely problem is that th epower supply died. Obtain a new one of the same or larger wattagge as the one you are replacing . It does nto have to come from the manufacture of the computer.
Nov 26, 2008 | Compaq Presario SR1000T (568657) PC...
Won't Start
BLOWN YOUR FUSE NEED NEW FUSE IN THE POWER SUPPLY
Jun 30, 2008 | Sony VAIO RB30C (VGCRB30) PC Desktop
Flashing Green Light on Front of 73" Projection TV
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Oct 12, 2007 | Mitsubishi VS-50707 50" Rear Projection...
HP Pavilion a1330n (EL466AA) PC Desktop Logo
338 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
