Question about BOSS AUDIO SYSTEMS CH800 Car Amp
1600w 800rms boss amp,amp turns on but the goes into protect mode
I have a 1600w 800rms boss amp, amp turns on with start up of the car but, then goes into protection mode...i some body help me with how this problem can be solved ?...
4 Suggested Answers
  • 222 Answers
SOURCE: On a Boss D1200M mono-block amplifier what would
check your positive supplies, are they properly installed? and your ground is is properly grounded?
Posted on Jun 11, 2010
doron_c21
  • 387 Answers
SOURCE: hi i got a boss audio cw3500d,i have a problem
Hi
The protection led comes because the Amps internal part on the mainbaord burned or over heated
ecrdn@yahoo.com
Jack
Posted on Oct 19, 2010
demonsm
  • 253 Answers
Speakers can not handle the load so the coil in the speakers heat up and shut off your amp.
Posted on Mar 31, 2015
How do I fix my boss blade amp wen it stock in protection mode
You have to troubleshoot to find what caused it to enter protect mode. This can be caused by overdriving the output or failure of related components.
Aug 10, 2016 | Boss Car Audio & Video
MY soundstream LiL Wonder 4.620 is only going in protection mode
Disconnect all speakers Meter power, remote, ground at amp, if all is good move on, if not check main fuses
Turn amp on; If in protect mode then your amp is toast Turn amp on, if not in protect mode then start reconnecting speakers one by one until your amp goes into protect mode, then you'll know which speaker is bad.
Sep 19, 2011 | Car Audio & Video
Amp goes to protection mode. if the fuse is too small?
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. . Double check all connections. Good luck.
A thumbs up would be greatly appreciated if this answer is helpful to you. Worth fixing.
Jul 15, 2010 | Autotek MM125.2 Car Amp
My boss amp is on protection mode and it wont work its a 3500 watt chaos idk what is wrong with it
Likely one of the power amps has failed component(s) and does not achieve electrical balance which then goes to protect mode to prevent damaging your speakers.
You will need to have it serviced.
Dec 25, 2009 | BOSS AUDIO SYSTEMS Music
Best car amplifier
I've got a boss 1600 watt 4 channel amp ,720rms watts. up for auction on ebay right now that would work great. brand new in box. check it out. http://shop.ebay.com/?_from=R40&_trksid=p3984.m38.l1313&_nkw=boss+1600w+amp+4+channel+with+level+remote&_sacat=See-All-Categories
Oct 05, 2009 | Cars & Trucks
Speakers cut off when bass goes up
probably the amp going to safe or protect mode judging by the fact that you have 3 subs wired to it i would say it is not 1 ohm stable try disconnecting 1 sub and see if it still happens this will be running a 2 ohm load rather than 1 if it stops happening then you need to figure out a better wiring configuration that will work with your amp.
Jul 03, 2009 | Kicker ZX400.1 Car Audio Amplifier
Boss 3500 Watt Monoblock Amp stops putting out signal
What's the battery voltage across the B+ and ground terminals of the amp when the engine is running?
Does the amp go into protect mode when the engine is running?
Are you sure the head unit is still producing output when the engine is running?
Apr 09, 2008 | Car Audio & Video
Wiring up amp/installing amp
Disconnect all the wires and make sure that their all connected to the right terminals. If not positively sure trace all wires back to source. If you ground and power is swapped it will automatically go over to protection mode.
Apr 04, 2008 | Car Audio & Video
BOSS AUDIO SYSTEMS CH800 Car Amp Logo
50 people viewed this question
Top BOSS AUDIO SYSTEMS Car Audio & Video Experts
Jose Velazquez
Jose Velazquez
Jerry Umali
Steve Sweetleaf
Steve Sweetleaf
Are you a BOSS AUDIO SYSTEMS Car Audio and Video Expert? Answer questions, earn points and help others
