Question about Whirlpool GH8155XJ Microwave Oven
The handle is broken on my Whirlpool Microwave Hood MH2155XPQ1. I ordered a new handle but am unable to remove and replace handle
    President:
  • 1,070 Answers
Welcome to FixYa
  • Remove screws on top at front in order to remove plastic front vent grill. Some times thin screwdriver or small knife and carefully insert along the inner panel and pry the plastic up.
  • The door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Your Diagram here[Number 7]...
For Detailed Parts here[Click on each diagram and -There also Providing parts name by Numbers given in Diagrams]
Still if you can't figure out -then Check this Thread too here[Providing some more Details -Read it carefully ]
Hope you got an idea...Thanks for Contacting FIxYa
Posted on Jul 03, 2010
Need to Replace Door Handle for KitchenAid Over Range Microwave Hood Combo KHMS147KSS
can u send me the pic of door and the handle of ur oven at khader_abu@yahoo.com........
Jun 01, 2008 | GE Advantium SCA1000H Convection /...
Broken handle on whirlpool model MH7140XF. how do I remove the face of the door with out breaking it?
The door handle can easily be replaced on most microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle usually averages about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. If the model number you have this question listed under is correct, the part number for a replacement handle is available at appliancepartspros.com. There are several part numbers listed, based on the color of your oven, so make sure you order the correct handle. Here is the parts listing:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=260444&diagram_id=93877#d93877
If you have any questions, please post back and let me know. I hope this helps you
Apr 13, 2010 | Whirlpool MH7140XF Microwave Oven
Need help replacing handle on whirlpool microwave model MH1150XM
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2009 | Whirlpool MH1150XM Convection/Microwave...
How to replace the door handle on a mod. MH 1170XSY-0 mico wave
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions, please let me know. I hope you find this information helpful.
Jul 09, 2009 | Whirlpool MH1170XS Microwave Oven
My door handle is broken. Is it posssible to
You should be able to buy only the door handle and avoid having to replace the entire door. Appliancepartspros.com carries the handle. Just type in the model number you provided and look for item #3 under the parts listing. The part number and price varies based on the color you need. Make sure you order the correct color. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
Jul 06, 2009 | GE JVM1640 Microwave Oven
Broken vent grille for a Whirlpool microwave hood combination
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical grille in seconds.
Jun 06, 2009 | Whirlpool GH8155XJ Microwave Oven
Replacement of Door handle
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Sep 05, 2008 | Whirlpool MH1150XM Convection/Microwave...
The handle broke on a stainless steel whirlpool microwave
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
May 05, 2008 | Microwave Ovens
Door handle
I recommend that you do not remove the door or hinges to do the job because if it's not aligned exactly, you can have microwave leakage.
Apr 20, 2008 | Whirlpool MH3184XP Microwave Oven
Whirlpool GH8155XJ Microwave Oven Logo
131 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
