Question about Aiwa Car Audio & Video
WHEN I PUT THE POSTIVE BATTERY CABLE ON THE BATTERY IT SPARKS HOW DO I FIX THIS?
    Guru:
  • 200 Answers
I'm guessing that you mean the car battery, this is normal on most cars
Posted on Jul 03, 2010
Replaced starter in xc90 volvo now can not put terminal on battery sparks
Sounds like start wire is touching ground with would be frame motor or metal
Jan 31, 2015 | 2003 Volvo XC90
Car dies when postive cable is left on
Check the postive wire to the starter and to the fuse box there is a fusable link in there that is burnt or a wire that is burnt in half causing a short.
Nov 28, 2012 | 1999 Ford Contour
I have a 1984 toyota not charging battery, i put on a new Alternator ,i took postive cable off battery it dies.
A Toyota will not run with the battery disconnected, it doesn't mean an alternator problem only a voltage and load test can determine that, it is unique to S\some Japanese cars and light trucks.
Jul 13, 2012 | Toyota Cars & Trucks
Dome lights do not work and new batterey goes dead over night
charge your battery.make sure car is turned off.put your battery in and connect the ground and then put your postive cable to the postive terminal and see sparks if so you have a short some where/hope this helps
Mar 03, 2012 | 1997 Ford Expedition
Battery does not hold charge battery is good
How do you know the battery is good? Have you had a load test performed on the battery? Just because a battery reads 12 volts when using a volt meter doesn't tell you anything. You need to have the battery load tested. If it tests good, charge the battery to full charge. Put it in the bike and connect the negative battery cable. Using a good Digital Volt Ohm Meter that will measure amps up to ten amps. Set the meter up to measure AMPS. and put it in it's highest scale. Put the postive lead of the meter to the postive battery post. Put the negative meter lead to the postive battery cable that is disconnected from the battery. If you have a current drain, lower the scale range until you get a stead readable value. Then, disconnect the voltage regulator from the battery and read the current drain. Since you bike is ECM controlled, it will draw a little current but not over one amp.
Good luck
Steve
Jul 12, 2011 | Harley Davidson FLHR-FLHRI Road king...
When you hit the automatic door lock the jeep wont start and you will have to unplug the postive battery cable for about 15 min then it will start how do i fix this
This vehicle has a factory alarm system. You will Seemamsecurity light flashing when it doesn't start. Put key in the drivers door and turn it to the unlocked position to disarm.
Jan 20, 2011 | 1997 Jeep Grand Cherokee
New altenator new battery but battery light stays on and car wont start without a jump and then dies while driving after a few minutes. i drive an 89 acura legend
Hi!!
Your best bet is to remove the battery or the negative battery cable, charge it and drive your vehicle to an AutoZone, Checkers or similar Autoparts store to have your charging system checked. If the engine is running, even if you disconnect the negative battery cable it should stay running, if it dies, the alternator is not working, probably the voltage regulator. If you just bought the alternator, try to take the vehicle to that place so they can check it. If you don't think the car would make it to the auto parts store. Remove the alternator and the battery to have them tested. It is not unusual that an alternator fails when just out of the box. Good Luck!!
Don't forget to rate this post!!
Sep 28, 2010 | 1989 Acura Legend
How to replace a starter
take postive battery cable lose at the battery jack the car up! put a jack stand under it and crawl under neath where the battery cable goes to the starter then remove the starter mount bolts and drop down remove the battery cable from the start as well as the solenoid exciter wire
Jan 22, 2010 | 1996 Toyota Corolla
Replacing 2003 toyota battery cable (postive cable) Both battery post are covered with acid and the cable (postive cable) running from the car to the battery is slightly loose and I was told it would...
disconnect battery cables, clean all components with baking soda and water mixture, use wire brush, corrosion could be in side cable under plastic coating
Sep 13, 2009 | 2003 Toyota ECHO
Car Audio & Video Logo
81 people viewed this question
Top Aiwa Car Audio & Video Experts
Greg Cann
Greg Cann
fordexpert
Are you an Aiwa Car Audio and Video Expert? Answer questions, earn points and help others
