Question about HP OfficeJet 7310 All-In-One InkJet Printer
Wrong paper size message
Everytime a fax is sent to our machine, a blank sheet of paper feeds through, and the error message "wrong paper size..." appears. We must then press OK button to receive the fax.
Thanks for your help, Greg
  • aramini May 15, 2008
    I have the same exact problem. The fax is received in the 7310xi memory, but it will not print out the received fax until we press OK to the Paper Mismatch message. I notice that this doesn't happen when using the printer feature of the HP 7310xi...only when receiving a fax.
    The exact error message on the 7310xi LCD screen is:
    "Paper Mismatch"
    "Paper detected does not match paper size or type selected.
    Change paper and press OK to continue job."
    I tried changing the paper size setting in the fax setup menu:
    1. Press "Setup" button on the 7310xi
    2. Select option #4 "Basic Fax Setup"
    3. Press "OK" button
    4. Select option #5 Paper Size
    5. Press "OK" button
    6. Select paper size that matches the paper you have loaded in the tray
    7. Press "OK" button
    For some reason, even though I have Letter size paper loaded in the tray, if I set the paper size settings in the 7310xi (procedure mentioned above) to Legal, then the error msg doesn't come up anymore and I can receive normally without having to do anything. I don't know if this is just a fluke or what? May help you, may not...try it and see...nothing to lose.
  • Anonymous Jan 07, 2009
    I changed the paper size to legal and then back to letter. There isn't a menu option for paper type "plain" in the fax menu. There is one in the copy mode so I will try that.
    Problem Solver:
  • 7 Answers
Choose the correct paper size from the setup and change the paper type to 'plain paper'.
Hope this help.
Posted on May 30, 2008
I get plain paper or double when I received fax from my uf5300 laser fax.it print one page from 5 pages that sent and I got empty pages and double somtimes
Paper feed rollers and sheet feed pad dirty. Feed roller on top pad should be just below. Clean with alcohol. Papers have clay in them. Recycled is worst. It will glaze the pick up roller and pad.
Sep 21, 2014 | Panasonic PanaFax UF-8000 Laser Fax
Why is my Brother Intellifax 4100e error says check paper size?
your paper error message means you probably received a document that wasn't the size of paper in the paper tray ,try legal sized paper,to dump the job stuck in your faxes memory ,this
problem happens a lot, theres reall nothing wrong with the fax/printer
Aug 13, 2014 | Brother IntelliFax-4100e Fax
I have a Laser Class 710 and the error light keeps blinking. There is a message that says "incorrect paper size received in memory". How do I get rid of this?
Someone has probably sent you a fax on 8 1/2 x 14 inch (legal size) paper. Pull down the manual hand feed tray which is located above the regular paper cassettes and place some legal size paper in it. Hopefully the fax will be outputted and the message will go away. Good luck.
Jul 15, 2011 | Canon LaserCLASS Fax 710 Printer
We can send faxes with no issues but when we receive a fax that has multiple pages after the first couple of pages we get half pages, partial prin or blank pages. We were told it was a possible system...
Is it pulling two pages at once? Sometime a machine will start to pull a sheet normally, then the page below it will get dragged along by the friction between the two sheets. One page's print gets divided between the two. If that looks like the case, pull out the paper drawer, remove the paper, and lightly sand the little rubber or cork pad at the front, then wipe the dust off with a damp cloth and let it dry. Before putting the paper back in, grasp the stack at one end, and "fan" the other, allowing air to get between all the sheets.
Get into the machine's Paper menu to see what size is programmed for the tray. If you have Letter size in there, but it's set for some other size, all kinds of feeding problems can occur, including false jams.
The paper feed roller is controlled by a magnet lever inside the right side of the machine. It should click once to start each sheet feeding. I've seen one Fax 4100e that clicked over and over, feeding extra sheets, just like you described. It turned out to be the system board. Worse yet, Brother had switched factories in mid-production of this model, and the replacement board they sent us fed paper just fine, but wouldn't do anything right on the phone line. Couldn't dial, couldn't answer. They sent another replacement, and it was exactly the same. Brother eventually broke down and sent a replacement machine.
Oct 06, 2010 | Brother IntelliFAX 4100 Laser Fax
Everytime I receive a fax, the first page prints out then I get a "Check paper size" error
Sounds like you have the paper size in the tray set incorrectly. For example, it may be set to legal, but you have letter size in the tray. This would cause that message to display. Check your setup options for the paper setting.
Jul 14, 2009 | Brother IntelliFAX 4100 Laser Fax
Panasonic KX-FL511 fax machine always prints blank page
make sure that "autoreduction" is set to on. should be in your owners manual. also, make sure your paper size is set correctly.
razors
Apr 13, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Paper
If you see this message on the front panel of the HP PSC 2210 when you are receiving a fax, check that the paper size is set to match the paper size in the paper tray. (You cannot receive a fax on 4 x 6 paper or on an envelope.) Checking the paper size setting
  1. Press Setup .
  2. Press the right arrow until you see 3: Basic Fax Setup .
  3. Press Enter .
  4. Press the right arrow until you see 4: Paper Size .
  5. Press Enter .
  6. Press the right arrow until you see the paper size that matches the size of the paper in the paper tray.
  7. Press Enter .
Aug 28, 2008 | HP PSC 2210 All-In-One InkJet Printer
Error message *346 with HP7310
since you have a 4 in 1 what i would do is go to your fax / printer settings and select spool to hard drive. There could be a possibility that all the data is not being stored on the fax machine. By sending your data to your hard drive first it will spool the data according to the performance and needs of your fax. Also check your time out feature on your fax machine. If the time out is set low it will send blank or only one sheet at a time. Because before the data is sent through the fax the system has already timed out. Another thing i found with the 4 in 1 is that as soon as you have your first paper going through you will want the second one right there ready to load. Sometimes if you wait to long before adding another sheet it will time out thinking you are done with your transmission.
Sep 17, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Fax Machine Jams Everytime I Try to Load Paper...
Is it jamming at the document feeder, or in the blank paper tray? You may need to clean the feed rollers. Use a lint-free cloth (not paper) and some alcohol.
Dec 27, 2006 | Sharp UX-B20 Plain Paper Inkjet Fax
HP OfficeJet 7310 All-In-One InkJet Printer Logo
1,252 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
