Question about Miele Washing Machines
Hi,i have a washing machine miele w 3000 tech fault f63.what i can do?
  • alinastanimi Jul 03, 2010
    i need to know what is tech fault f63
Mine is W3844. Miele's technician said the Wather Path Control Unit (part # 6271992) need to be changed.
Total Cost: (HKD)
450 for todays check cost
1100 for the part
250 for the labour to change the part.
Posted on Jul 16, 2010
How do I fix this myself: Miele Softronix W 1734. Reports Error: "F63" When I look up that error I get: "Contact Miele technician"
either the controller is not working or the inlet valve is bad .could also be the pressure switch that tells the machine when it is full enough
Jun 05, 2016 | Miele Washing Machines
Fault F63
Roger
Depending on the model number - (guessing its a W48XX series) F63 is a water path fault - This is the control unit that directs the water flow to the proper path (pre-wash, detergent, fabric softener ect..... ) Sometimes and audible clicking can be heard when this unit fails as it trying to switch to the proper path as per the program being ran.
Dec 08, 2013 | Miele Washing Machines
Miele fault F63
F63 on certain washers is an indication of too much soap is being used. If you live in an area where the water is hard and your not using too much soap you have a clog in one of the hoses used for air. Try to do a hot cycle with white vinegar. On other models the F63 is indicating that the water intake valve didn't find it's position. If this is the case just run an additional cycle.
Jan 21, 2012 | Miele Washing Machines
My Miele 1374 washing machine just had a fehler f63 error. What does this mean and is it fixable?
heres your problem..
3.33 Fault code F63, water path control unit In normal operation mode the display shows Technical fault. The Check inlet LED flashes rapidly. The programme is interrupted. The drain pump is activated for 120 s. Cause Water path control system faulty. The power-programme module (ELP) cannot register a valid position of the water path control unit within approx. 80 s of it being switched on.
Note: Water intake monitoring is not active if a valid position of the water path control unit cannot be registered.
Remedy Check the water path control system. tool1.gif?leaf=true Check the water path control system circuit for an open or short circuit, and correct insulation.
Jun 05, 2011 | Miele W 4800 Front Load Washer
Hello, i'm facing the following issue technical default F63 on the W5794 washing machine thanks in advance for your precious help regards
Hi vianney_dupa,
Your water path control unit is not registered by the PC Board. This is the Pressure switch / Water Level Switch. I'd kindly suggest you get a qualified technician to come and check your machine. If not well diagnosed it may lead to further damaging the machine.
Sorry, no quick fix here - This is were Miele machines get complicated O.o..
No need to vote my answer, I'll understand.
May 12, 2011 | Miele Touchtronic W1213 Front Load Washer
Miele front loader washing machine W3275- error code F53- what does this mean?
hi,
this is a tachogenerator fault or the drive motor brushes are faulty. you will need a Miele service tech or a Miele service agent to look at this.
May 21, 2010 | Miele W865 Front Load Washer
Miele w3033 tech fault f63. what to do?
i have washing machine miele gala grande w 3000.and i have a tech fa ult f63.what is this?
Jul 04, 2009 | Washing Machines
Washing Machines Logo
1,187 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
