Question about GPS
Alpine Navigation system malfunction
After removing battery, and allowing system to install the software, the screen to enter my code does not appear. This system is in a 2004 Honda!
    Problem Solver:
Don't know how the wife did it, but the screen just came up,she entered the code and all seems fine now! Don't know if what caused the problem in the first place will return, but it works for now! Thanks, am glad I found your site for future problems Helpman!
Posted on Apr 18, 2008
How to replace the starter on a 2007 honda civic
Starter Removal and Installation
Removal
1. Make sure you have the anti-theft code for the audio system and the navigation system (if equipped), then write down the audio presets.
2. Disconnect the negative cable from the battery first, then disconnect the positive cable.
3. Remove exhaust pipe A.
4. Remove the intake manifold bracket.
5. Remove the harness clamps (A) and harness connector (B) from each clamp.
6. Remove the two bolts securing the starter, then remove the starter from the engine.
7. Disconnect the starter cable (A) from the B terminal. Disconnect the connector (B) from the S terminal, then remove the starter.
INSTALLATION
1. Install the starter cable (A) and connector (B). Make sure the starter cable crimped side of the ring terminal faces away from the starter when you connect it.
2. Install the starter, then loosely install the upper mounting bolt (A) and lower mounting bolt (B).
3. Tighten the upper mounting bolt, then tighten the lower mounting bolt.
4. Install the harness clamps (A) and harness connector (B) to each clamp.
5. Install the intake manifold bracket.
6. Install exhaust pipe A. Use new gaskets (B) and new self-locking nuts (C).
7. Connect the positive cable to the battery first, then connect the negative cable.
8. Start the engine to make sure the starter works properly.
9. Enter the anti-theft code for the audio system and the navigation system (if equipped), then enter the audio presets.
10. Set the clock.
Dec 22, 2016 | Honda Cars & Trucks
Tip
How do I delete a MySpace profile navigation bar
<p>MySpace has a navigation bar at the top of each page. The links make it easy to navigate to different areas, such as your home, your e-mail, music or even to leave. If you choose to remove the navigation bar and you have the original MySpace - known as "MySpace 1.0" - or even the next release, "MySpace 2.0," code you can create a cascading style sheet in your profile. CSS code sends the web page or hides page elements as shown. However, the latest version of MySpace, "MySpace 3.0," you cannot edit the CSS code. <br /> <p><br /> <p>MySpace Instructions 1.0 <br /> <p>1. Go to MySpace. Log into your account, click the blue "Login" link in the left corner of the site. Enter your e-mail and password in the box that appears, as shown, click the box "Login". You're on your MySpace homepage. <br /> <p><br /> <p>2. Place the cursor on the word "Profile" at the top of your homepage. Finding the "Edit Profile" from the menu that drops under the cursor. Click here to enter your profile in edit mode. <br /> <p><br /> <p>3. Click the Edit link next to a part - no matter what you choose. Select "About Me", for example, and a box appears, allowing you to enter your code. <br /> <p><br /> <p>4. Right-click to copy the following code: <br /> <p>&lt;style type="text/css"&gt; div.profileWidth {margin-top:-30px! important;} div.profileWidth div {filter: alpha (opacity = 0); opacity: 0.0001;} div.profileWidth div.clearfix, div.profileWidth div {filter: none; opacity: 0.9999;} div. clearfix div.profileWidth {position: relative; top: 30px;} div.profileWidth ul li {display: none;} &lt;/ style&gt; <br /> <p><br /> <p>5. Use the right mouse button on the mouse to click in the edit box you opened. Select "Paste" that appears on your cursor. The CSS code that you copied to the section you are editing. <br /> <p><br /> <p>6. Go to the bottom of the page and click "Save Changes". Your navigation bar will no longer appear on top of your MySpace profile - although the navigation bar appears on other pages. <br /> <p><br /> <p>MySpace Instructions 2.0 <br /> <p>1. Go to MySpace and log into your account, click the "Login" blue in the left corner of the site. Enter your e-mail and password in the box that appears, as shown, click the box "Login". You're on your MySpace homepage. <br /> <p><br /> <p>2. Move the mouse cursor over the "Profile" link at the top of the homepage in the navigation bar. Click the "Customize Profile" that appears. The box "Profile 2.0 - Edit Profile" results. <br /> <p><br /> <p>3. Click View in the first column of the box; select "CSS" in the second column. A text box for the CSS code will appear. <br /> <p><br /> <p>4. Right-click to copy the following code: <br /> <p>. MSc {hide the top navigation bar new} <br /> <p>gbltopnav # div {display: none;} <br /> <p><br /> <p>5. Paste the code using the mouse to right-click the text box and select Paste. The CSS code that you copied to the CSS box. <br /> <p><br /> <p>6. Click the "Publish" button at the bottom of the box. The navigation bar will disappear from your profile, even if the other MySpace pages. <br />
on Jun 26, 2011 | Computers & Internet
Alpine SD navigation system VIE-X05 update loading file free download
ALPINE VIE-X05 SD NAVIGATION SOFTWARE file need. my sd card is dad's plzz solution for me.
Jan 04, 2014 | Alpine 7-inch Double-DIN GPS Navigation...
How to change a starter on a 2004 Acura TSX
Removal
  1. Make sure you have the anti-theft codes for the audio system and the
  2. Disconnect the negative cable from the battery.
  3. Remove the
    intake manifold, '04-05 models,
    '06-08
    models.
  1. Disconnect the starter cable (A) from the B terminal, and disconnect
    the BLK/WHT wire (B) from the starter solenoid S terminal.
  2. Remove the harness clamp (C) and the harness holder (D).
  3. Remove the two bolts holding the starter, then remove the
    starter.
  4. Installation
    1. Install the starter, then connect the starter cable (A) to the B
      terminal, and connect the BLK/WHT wire (B) to the starter solenoid S terminal.
      Make sure the crimped side of the ring terminal faces away from the starter when
      you connect it.
    2. Install the harness holder (C) and the harness clamp (D).
    3. Install the
      '06-08
      models.
    4. Connect the negative cable to the battery.
    5. Start the engine to make sure the starter works properly.
    6. Enter the anti-theft codes for the audio system and the navigation
      system (if equipped), then enter the audio presets. Set the clock (on vehicles
      without navigation).
rjaai003_204.asp?menuid=rdbawh030000&sessionid=b23b61ec-6b2d-41dc-8d50-15026d64c21a&dbkey=sea7a00a46500056901kdad01
Nov 02, 2013 | 2004 Acura TSX
Radio code will not work though it is code that goes with serial number that showed on screen on unit when i did like tech. explain on code site
If you enter the wrong code three times then the audio unit will lock. you'll have to disconnect the battery for a couple of minutes. Make sure its the right code and try again. If its a Navigation equipped system 03-07 Accord these audio codes are 4-digits. Make sure the tech performed the anti-theft code inquiry correct. I've also seen a preset button malfunction which won't register when pushed. -hope this helps.
Mar 06, 2010 | 2002 Honda Accord
Replaced battery and navigationn propt me to put a code. inputed the code and it shut off.
If you replaced your battery, you probably lost your audio system code as well. You should put that in first or your navigation system voice will not work. I assume you have the code for your audio system.
After you get your audio system working then you should be able to put the code in for you navigation system as follows:
Enter the four-digit navigation system security code, then select Done. If you have entered it correctly, the display changes to the Disclaimer screen. You have ten chances to enter the correct code. If all ten are incorrect, turn the ignition to OFF, then back to ON (II) to have ten more chances to enter the correct code (I would try this is your unit has turned off and doesn't come back on).
If you have other questions on this, leave a comment and I will investigate further.
Hope this helps you.
Nov 18, 2009 | 2006 Honda Accord
Navigation system
Unplugging or rebooting won't solve the problem. Call Alpine Electronics. They are the manufacturer of the Navi System. They will replace it for about $160. Check their website online for their phone number.
May 30, 2008 | 2004 Honda Accord
GPS Logo
131 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
