Question about Hayward H-Series 200k BTU Millivolt Heater - Natural Gas
Hayward H-Series 200k BTU Millivolt Heater - Natural Gas burners will not ignite. Jumping th terminals /burners will ignite
  • hobbyaddict1 Jul 04, 2010
    I did mentioned which terminals "th"
    trouble shooting..
    TH terminals jumped/burners ignite-leaving jumper on burners stay light and heat pool.
    Remove jumpers
    trying jumping pressure switch,burners do not ignite
    Remove jumper
    try jumping from thermostat burners do not light.
    Without heater in July (Michigan) the pool is @ 70 still...
    Unfortunatley my wife will not go in, except for quick in and out.
    Thanks
  • 760 Answers
You didn't say what terminals you jumped, but I assume it's the flow switch, or it could be the thermostat. The flow switch is located on the piping inside the heater. This flow switch is very important because if you didn't have water flowing through the heater it would oveheat. These do go bad or sometimes just get stuck depending on what type they are. If it's the thermostat, mounted on the front pane you're jumping, then either it or it's expansion bulb is faulty. GOOD LUCK Who needs a heater in JULY?
Posted on Jul 03, 2010
Testimonial: "Thank you, Yu have given me plenty to look into..."
  • Tom W Jul 05, 2010
    Ok, there should only be one TH temrinal and one THPP terminal. If you jumped these, you bypass every safety limint on the heater. I'd either test with a millivolt meter, or jump each safety one at a time. Again do not operate the heater with a safety bypassed. The thermostat should be Gy and BK wires, jumping these didn't work? y and gy is the system switch, the r and y is for a remote control r and v is limit switch, v and BL is limit switch, BL and R is pressure switch, R and BK is temperatrue limiter switch, bk and p is temperature limiter manual switch. If this doesn't help, then here is a link to hayward and the complete manual with wiring diagram and troubleshooting tips are here: http://www.haywardnet.com/inground/produ...
No display at all after changing the board do to a ce code
make sure voltage going in if ok check transformer for voltage also check any fuses
Feb 03, 2014 | Hayward H-Series 200k BTU Millivolt Heater...
Hayward h-200 wont lite. it cycles thru the start up sequence. blower starts , gas valve opens (smell gas) ignitor glows cherry red... yet no flame. any ideas???
you may need to bleed the line to get fresh gas to the unit, you can use soapy water to check, that the fitting leak free, after bleeding at the block.
Oct 05, 2013 | Hayward H-Series 200k BTU Millivolt Heater...
If the (th) terminals means the thermostat terminals then you have a bad thermostat and it needs to be replaced.
Jul 03, 2010 | Heating & Cooling
My hayward h series minivolt heater works for about 1hour then shuts down and when started again shuts down after 1to 2 minutes
This is a fault in the control system...prob the high limit switch or pressure valve
http://www.laarsman.co.uk
Miles
Jun 05, 2010 | Hayward H-Series 200k BTU Millivolt Heater...
I have sf and hs messagen o my hearter h series.
o daja vers hin on internet se osht gjyshi gjevat tung lanti
Apr 27, 2010 | Hayward H-Series 200k BTU Millivolt Heater...
Pool Heater with communication (CE) Error
Code "CE" stands for communication error and describes a fault between the mother board and the display. I doubt it's the relay causing it though...
Feb 15, 2010 | Hayward H-Series 200k BTU Millivolt Heater...
I can't get the pilot to light gas is present can I light it
hayward millivolt htrs are very difficult to light manually.i'm assuming your piezo ignitor is mal-functioning.use a grill lighter withn a goose neck and follow aluminu pilot tube to pilot hood
Jun 06, 2009 | Hayward H Series Pool & Spa Heater 200k...
Hayward H-Series 200k BTU Millivolt Heater - Natural Gas Logo
286 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
