Hayward H-Series 200k BTU Millivolt Heater - Natural Gas burners will not ignite. Jumping th terminals /burners will ignite
    Guru:
  • 587 Answers
If the (th) terminals means the thermostat terminals then you have a bad thermostat and it needs to be replaced.
Posted on Jul 04, 2010
Hayward H200P1 Pool Heater- need to convert propane to natural gas
all the parts needed will be in the kit. usually, its the control valve and the jets that get replaced. my manual shows its the same part all units. HAXCNK0002
Aug 09, 2014 | Hayward H Series Pool & Spa Heater 200k...
No display at all after changing the board do to a ce code
make sure voltage going in if ok check transformer for voltage also check any fuses
Feb 03, 2014 | Hayward H-Series 200k BTU Millivolt Heater...
Hayward h-200 wont lite. it cycles thru the start up sequence. blower starts , gas valve opens (smell gas) ignitor glows cherry red... yet no flame. any ideas???
you may need to bleed the line to get fresh gas to the unit, you can use soapy water to check, that the fitting leak free, after bleeding at the block.
Oct 05, 2013 | Hayward H-Series 200k BTU Millivolt Heater...
You didn't say what terminals you jumped, but I assume it's the flow switch, or it could be the thermostat. The flow switch is located on the piping inside the heater. This flow switch is very important because if you didn't have water flowing through the heater it would oveheat. These do go bad or sometimes just get stuck depending on what type they are. If it's the thermostat, mounted on the front pane you're jumping, then either it or it's expansion bulb is faulty. GOOD LUCK Who needs a heater in JULY?
Jul 03, 2010 | Hayward H-Series 200k BTU Millivolt Heater...
My hayward h series minivolt heater works for about 1hour then shuts down and when started again shuts down after 1to 2 minutes
This is a fault in the control system...prob the high limit switch or pressure valve
http://www.laarsman.co.uk
Miles
Jun 05, 2010 | Hayward H-Series 200k BTU Millivolt Heater...
SF error
IDXLTER1930
I think you must be mistaken about your heater being a millivolt heater. They have not mfg these heaters for some time. And they probably would not give you an SF error. If you have an SF error, it is a newer model with a digital board. Millivolts usually have two analog temperature dials on them and no digital readouts. That should be the part. HTH
May 20, 2010 | Hayward H-Series 200k BTU Millivolt Heater...
I have sf and hs messagen o my hearter h series.
o daja vers hin on internet se osht gjyshi gjevat tung lanti
Apr 27, 2010 | Hayward H-Series 200k BTU Millivolt Heater...
Pool Heater with communication (CE) Error
Code "CE" stands for communication error and describes a fault between the mother board and the display. I doubt it's the relay causing it though...
Feb 15, 2010 | Hayward H-Series 200k BTU Millivolt Heater...
I can't get the pilot to light gas is present can I light it
hayward millivolt htrs are very difficult to light manually.i'm assuming your piezo ignitor is mal-functioning.use a grill lighter withn a goose neck and follow aluminu pilot tube to pilot hood
Jun 06, 2009 | Hayward H Series Pool & Spa Heater 200k...
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
