Question about Kenmore Dishwashers
I need new racks for our Kenmore dishwasher... Model 16529000. Serial # FM4649602. Stock 16529. Type 280-1
eagle338
  • 4889 Answers
SOURCE: kenmore dishwasher touchpads
Yes you can surely do it yourself..its just unplugging a few wires remove the old one and just install the new one..
I couldn't find the model number you have specified, but you can give these guys a call and specify ask for a new touchpad for kenmore 16372. They will ship it out for you.. I advise you call their toll free number that you can find on their site so that you can get it done real quick.. http://www.laundryparts.com/sunshop/index.php?action=category&id=bestsellers
Posted on Mar 14, 2008
tzweeb
  • 318 Answers
SOURCE: Kenmore ultra wash dishwasher model number 665.158.5090
the only way you can tell if the upper rack is not getting enough water is to turn a glass right side up in each corner. then run for 2 minutes and see if there is water in each cup.
if you still dont get water, then you have checked the pump, the only thing left is that you are not getting enough water into the unit.
start the d/w at a normal cycle, let it fill and go into the wash cycle, takes about 3 minutes, then check to see if the water level is just below the heating element. if so then it has to be the wash pump being plugged.
if not enough water then you should change the water inlet valve. some times they do get plugged but also make sure you are getting full water pressure to the unit as that could cause not enough water into unit. the faucet under sink could be at fault i have seen valve work but not let enough water in, so dont be surprised if you need a new valve.
Posted on Jan 06, 2009
  • 10865 Answers
SOURCE: Dishes on top rack don't get clean
The following suggestions will greatly enhance the ability of your dishwasher to clean all of the dishes thoroughly:
1. Rinse all of the food off of the dishes before you put them in the dishwasher.
2. Run the hot water into the sink until it is as hot as it gets before you start the dishwasher.
3. Do not pack the dishes into the dishwasher, just put in a reasonable number without crowding or stacking them on either shelf.
4. Pull the top shelf all the way out to be sure that the water connection at the rear of the top shelf is connected. Sometimes, this connector comes disconnected preventing the water from entering the top spray assembly.
THese things should make a huge difference.
Good luck with this and please rate my answer. Thanks. Joe
Posted on Feb 03, 2009
  • 423 Answers
SOURCE: Water not draining and not clean
When dirty water is left in the dishwasher the pump assembly is a primary cause. To assure that the dishwasher gets fully repaired and you are going to do the work yourself, I would order and install this part:
http://www.repairclinic.com/SSPartDetail.aspx?s=t-16529000-%3d%3dc261i1065702&PartID=1065702
Also, check that the heating element is working. Many people replace the heating element whenever they replace the pump/ motor.
Good Luck!
Posted on May 04, 2009
  • 54 Answers
SOURCE: need replacement dish rack
Check out sears parts department online. Put in your serial number and they seem to have a lot of Danby parts.
Posted on Aug 14, 2009
Need to find location for a 1972 mercedes 280 sel
I think the Bosch W230T30 were stock. new Bosch # is W5d1.
If you've updated the original plug wires to a non-resistor type, you may need a resistor type plug instead of the stock plug.
Oct 22, 2014 | Core New Core One Bullet Spark Plug...
How to replacement the upper dish rack on Kenmore dishwasher
On the front end of the rails, there should be plastic or rubber stoppers. Remove these and the rack should roll right off as if youre pulling it out to load it.
Feb 06, 2010 | Dishwashers
A Kenmore model 15522000 type 280-1 dishwasher will not drain
I scooped out the water and found a spoon jammed in the drain area. Works like a charm now.
Feb 04, 2010 | Kenmore Dishwashers
Leftover food is still on glasses in the top rack
Check that wash water temp is HOT from beginning of cycle to end (140 to 160 is best). Check that rinse aid dispenser is full and set to your water hardness level. Check that holes in spray arms are not blocked and that unit has enough water. Use a good, fresh detergent.
Nov 30, 2009 | Kenmore 16529 Built-in Dishwasher
My dishwasher serial 1410879 type 280-2model iku5866 can i change front panel door from white to stainless steel
the is in fact a stainless panel available
for this model
call appliance parts pro at
1-877-477-7278
ask for part number
AP3126206
Oct 13, 2009 | Whirlpool 24 in. DU920PW Built-In...
Good Luck!
Mar 27, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore dishwasher touchpads
Mar 14, 2008 | Kenmore 16372 / 16374 / 16379 Built-in...
Kenmore dishwasher model #665-16751791
nickysoma What ever you found does not belong to the dish washer. Keep use your machine. It is nothing to worry about. Gendos...post back
Mar 22, 2007 | Kenmore 18 in. 14432 / 14439 Built-in...
Dishwashers Logo
61 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
