Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Intex salt water witha 18x48 witha 2000/gph pump. my salt water system keeps saying low salt... my salt tested fine after adding more and ive cleaned the cell... it will stay on about 20 min then beeps low salt. could it be a bad cell or overheating??????
  • 297 Answers
Nothing is wrong that you cant fix
you must have your salt no lower than 2800ppm
and no higher than 3800
3000ppm is the best
make sure you run filter only for 24 hours once you have correct salt then start generating
one last thing test with strips that read #'s not the color strips
Posted on Jul 03, 2010
I have done everything the manual says, but my saltwater system will not stop blinking error code 91. The salt level is fine, and the cell is clean. Do I need to replace the cell. My pool is now green and...
Bummer!!! Looks like you checked both things that would cause the code 91 error for "Low Salt". Here's what I've done to solve my low salt "91 code in the past.. I overshoot by 1/2 bag = 20lbs of the recommended salt add quantity when the code appears. Calculate by using this formula..
.0067 X Pool Gallons. I have a 14,000 gallon pool and when I get the 91 code for low salt, I add about 110 lbs of salt. Manual says 93 lbs...let it circulate for 24 hours by running the pump only and then start the chlorination cycle.. Before doing this, you MUST make sure the cell in clean.. If any calcium buildup inside, it can give you a false "Low Salt" alarm.
I hope this helps!!
If this helps, please rate... Thanks
Jul 17, 2011 | Intex Automatic Salt Water System for ...
Hi i have a 18 x 48 above ground intex frame pool with a salt water pump /chlorinator system. i have put the required amount of salt in 75 kg and it has fully desolved. the alarm keep coming up on the pump...
the amount of salt that they reccomend in the book is just a starting point
You need to get a salt test kit that reads in #'s not colors
Get your pool to as close to 3000ppm as possible
lower than 2800ppm and you will not produce enough chlorine
any higher than 3500ppm and you can trigger high salt alarm, have bad tasting water, or even get cloudy water
Like you have done, when adding salt , filter only for 6 hours or so to fully disolve
Jul 18, 2010 | Intex Automatic Salt Water System for ...
My Salt water pump keeps saying it is low on salt. I have added plenty of salt.
What is plenty of salt? There is a specific amount that you need Can't guess at it.
You must be above 2800ppm and no higher than 3800ppm
3000ppm is the best
You will need test strips for salt that reads in numbers not color
High salt can also trigger a LOW salt alarm
Don't ask me, it just happens
Just remeber 3000ppm
Jul 03, 2010 | Intex Automatic Salt Water System for ...
Low salt alarm on Intex system
so what does the test strip say. Should be as close to 3000ppm as possible anything close and under 2700ppm will trigger a low salt also you must run filter only for 24 hours to thouroughly mix the salt before trying to turn on the generator
Jun 14, 2010 | Intex Automatic Salt Water System for ...
Code 91
91 means Low Salt. I have seen this occur if the salt level is actually too low as well as when the plates have a large amount of white crystals on them. If your plates look clean (I use a pressure washer to clean them), check the salt level using salt test strips you can get at a pool supply store.
Jul 02, 2009 | Intex Automatic Salt Water System for ...
Salt water system not working , alarm code 91 appeared and then the system shut off . after more salt was added (20 kg) and the electrolytic cell housing was removed and cleaned the system still isn't...
if this pump is less than 90 days old, call intex they will replace it immediately without you having to send in the old one in the mean time get a salt tester kit and get your ppm to 3000ppm nothing else and dont take no for an answer :-) this is a great ppm to be at and adjust your chlorine and ph to that
Jun 29, 2009 | Intex 2000 GPH Salt Water Filtration Pump...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
568 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
