Question about KitchenAid KEYS750LQ Electric Dryer
Doesn't stop Hi I have a kitchenaid dryer , it doesn't stop , i did select timer mode and humidity sensor , same for all mode .the machine doesn't stop. it will stop when you open the door or you select off position . thanks PAT
  • Anonymous Feb 16, 2009
    I have the same problem...need to replace the timer module.
  • 903 Answers
The problem is probably the plunger switch that you press to start the dryer. If you select the OFF position and then move the dial to a cycle, does it start running without you having to press the start button? If so, that switch is your problem.
If you disconnect the dryer and remove the rear panel, you can unplug the switch and repair it yourself (the contacts probably just need to be adjusted) or you can replace it. Depending on the dryer you might be able to get the part number from the inside cover of the rear panel.
Posted on Sep 14, 2010
Admiral dryer timer not turning and no heat
It could be the high temp fuse on the element and the timer not turning depends doyou have it on the auto dry because it will not advance if it is not heating because the sensors are not detecting a decrease in the humidity levels because the element not working.
Mar 14, 2014 | Admiral 3.4 cu. ft. Top Load Washer in...
Maytag lsg7806aa not stopping
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Oct 25, 2008 | Dryers
The dryer does not pass 6 min mark and does not shut off. How would I test a humidity sensor? Thank you for help.
A dryer moisture sensor can stop working without notice, until you notice your clothes being over dried or still wet at the end of the cycle. It is a good practice to test the dryer moisture sensor periodically. There are two types of moisture-detecting sensors for dryers. Once you understand how they work you will see how to test each one.
1. Sensor BarThese sensors contain digits that protrude outwardly. They work on an electrical current and the moisture from the clothing.
The first step to test is to place completely dry clothes in the dryer and turn on the dryer; it should run for a few moments and then shut down right away.
Secondly, place damp clothes into the dryer, turn on the dryer and watch the timer. As the clothes begin to dry the timer will move and shut off.
2. ThermostatThe timer is regulated by the thermostat. The thermostat rests in a closed position. To test this type of moisture sensor, place damp clothes in the dryer. Watch the timer; as the clothes begin to dry, the thermostat should open and the timer will move forward ,eventually shutting off.
Sep 08, 2013 | Dryers
No heat when timer is in Electronic Sensor selections.
The electronic sensor needs to be replaced.
Sep 16, 2009 | Dryers
Hotpoint Aquarius Tumble Dryer TDL 31
Replaced with a new unit as not cost effective to repair.
Feb 16, 2009 | Hotpoint TDC32 Electric Dryer
Drying timer on auto dry
I called LG...they said to unplug the dryer for 5 min. to reset the timer ...this solved the problem.
They also said not to use dryer sheets during the sensor dry cycle as the coating on the dryer sheets causes the sensor to malfunction as it can't read the humidity level in the dryer.
Dec 28, 2008 | LG Dryers
Amana ALE643RAW Gas Dryer
.hi with gas dryers the parts to look for are . the blower . will take longer to dry and noisy .The venting very important. The coils on the gas valve .Will cause the flame to only come on for a few minutes . then nothing so for that problem . replace the coils. Thanks the appliance doc
Dec 05, 2007 | Amana ALG443RAW Gas Dryer
Will not start; makes no noise
check the humidity sensor this will prevent the motor from starting
Sep 22, 2007 | Maytag PYE2300AY Electric Dryer
KitchenAid KEYS750LQ Electric Dryer Logo
103 people viewed this question
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Oloyede Monsuru
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
