Question about Samsung DV316LGS Dryer
I GET THE t0 code which tells me its the thermistor. What is a thermistor and how do I replace it
I have that t0 sign appears too, it just stops anytimw, without drying the clothes.
Posted on Jun 08, 2013
What does the error code "OP" mean?
OP - Open Thermistor - Replace thermistor.
Aug 27, 2013 | Washing Machines
I am getting a T0 code on my dryer. I have cleaned all the vents
Thermistor open
Check for restricted vent Replace Thermistor
If you need further assistance please feel free to comment
Jul 27, 2011 | Samsung DV218AEW Electric Dryer
My dryer will begin a cycle and less than a minute into it, it stops, chimes three times, and on the display screen, says "to." It does not turn off, or continue drying. How can I fix it?
t0 means that one of the thermistors have failed and needs to be replaced. There are 2 of them and it is recommended that they be replaced together. Good luck.
Jun 19, 2011 | Samsung Dryers
We are getting the code E1 on are Duet Dryer can you tell me the problem
HI, This code is in reference to the thermistor that is mounted on the blower housing inside the unit. The unit will not operate properly when the E1 code is active. The necessary actions are to replace the internal monitoring thermistor. Once that is replaced, the unit will return to its normal status.
Sep 26, 2010 | Whirlpool GEW9200L Electric Dryer
Car 500e lugs and misses at 40 t0 60mph have replaced plugs and spark wires also cleaned injectors could it be the coils
Yes it could but i would suggest checking the crank position sensor as it will not throw check engine codes. Also go to an auto store and have them pull the codes for you for free.
May 15, 2010 | 2003 Mercedes-Benz E-Class
Anyone know what code t0 means? Dryer will start but never finish drying clothes regardless what cycle you're on.
To = Thermistor Open error.
The Thermistor resistance is very high.
Check for:
- Clogged lint screen.
- Restricted vent system.
- Check Thermistor resistance.
Replace themistor if out of range.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 04, 2010 | Samsung DV337 Electric Dryer
On a kenmore dryer Elite modle #11071062000 i am getting an error code "E2" can you tell me what this means? Can you tell me how to fix it? The dry runs but will not ignite.
The E1 displayed indicates the thermistor is open and needs to be replaced.
The connections can be loose but the most likely cause of an E1 error is a bad thermistor.
The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
If you're comfortable and confident in your do-it-yourself skills and have access to a volt/ohm meter you can check and replace this part yourself.
The thermistor is available from the following: www.searspartsdirect.com
Enter your model # in the appropriate box to get a full parts break-down and diagrams.
To access the thermistor see the image below.
Remember to unplug the dryer from power first.
The thermistor will have a black and red/white wire on it.
You can check continuity across it with the meter and if the circuit is open then the thermistor needs to be replaced.
When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
When the thermistor circuit is shorted (
Normal thermistor resistance values:
60 degrees F. - 15.3K ohms.
70 degrees F. - 11.9K ohms.
80 degrees F. - 9.2K ohms.
The thermistor -may- check ok when cool and freak out when warm!
http://media.fotki.com/1_p,wkrsfrgsskrbttbxgtqsskgwtqkq,vi/wbsdwtgwgxwrgbbgsgs/1/1303472/5961857/image6767img-or.gif
HE3 Dryer: http://media.fotki.com/1_p,wbfbgrrwtrrkfttxgtqsskgwtqkq,vi/kgwgwwwdkxkfkkgwgqs/1/1303472/5961857/image7127img-or.gif
Jun 30, 2009 | Kenmore Elite HE4 Electric Dryer
Samsung DV316LGS Dryer Logo
116 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
