Question about Samsung LN-T4661F 46 in. LCD HDTV
Samsung ln t4661f picture issues. Screen is divided into 4 horizontal quadrants with the right side of all 4 blurry and shadows/ghost images. Just over 2 years old.
We have the same problem. I am afraid it is a defect that is occuring in the samsung tv's
Posted on Aug 04, 2010
Right side of Samsung LN T4661F 46in LCD is blurry
hi this could be a tab/ribbon fault, there are ribbons attach to the screen at the top there's chips installed on them. when one is faulty they heat up and make the ribbon start to flex and move causing this fault, hope it helps
regards
shaun
May 16, 2014 | Samsung LN-T4661F 46 in. LCD HDTV
My samsung SX07 series is a little messed up. The sreen is divided into 2 sections one takes up about 2/3 the screen, and the shows the middle third of the screen. How do i fix that?!
Turn on the menu and if it is messed up also then you have a bad panel,...very expensive. If not, then it may only need a T-Con board. These are only available for versions SX07 & 8 and for SS03 & 4. Look at the right side for a sticker with your version number on it. I highly suggest you take it to a shop.
Aug 14, 2010 | Samsung LN-T4661F 46 in. LCD HDTV
When I trun on TV (Samsung LN-T4661F 46 In), it start with half scrren dark from Right Side, time goes by being normal screen. I want to know what the problem is.
Samsung made a bad TV, the new part is $1200 I have the same issue. it is a blurred picture from left to right after about 10 min it goes away. (18 month old tv) it is only going to get worse.
Jun 05, 2010 | Samsung LN-T4661F 46 in. LCD HDTV
Picture issue on start up
T-Con PCB. It is attached to the panel, under a metal shield. The LVDS ribbon cable runs to it from the Main PCB. It can be purchased separately for this model. For version SS03, the PN is: BN81-01312A
Mar 15, 2010 | Samsung LN-T4661F 46 in. LCD HDTV
Samsung LN-T4661F with black shaded area.
The back light is beginning to fail, thats why it goes shaded but you can still the picture on one side, do a google search for back lights for your make and model, there a few how to's to help you with changing the back light.
Feb 17, 2010 | Samsung LN-T4661F 46 in. LCD HDTV
Lines across screen breaking picture into 4 sections
Based on reported problems with Samsung LCD tvs, It is probably one of three problems:
Separation of layers of the LCD panel;
A defective LVDS cable connection;
A defective T-Con circuit board.
If light hand pressure on the affected area on the LCD panel changes the problem, its the defective panel. If not, manipulating the LVDS cable will reveal the cable defect. If not, coolant spray applied to the T-Con circuit board should reveal if it is defective by temporarily alleviating the problem. Dont remove the back cover if you dont know how to protect yourself from electrical shock hazards. There can be more than 1000 volts in the backlight inverter area.
Jerry S
Jul 28, 2009 | Samsung LN-T4661F 46 in. LCD HDTV
Offset picture
You need to change the Display menu for picture mode to 16:9
no wide fit or scan fit.
Jan 28, 2009 | Samsung LN-T4661F 46 in. LCD HDTV
LCD picture distortion.
This is caused by a failure of the main board. The failure causes the refresh rate of the unit to be off creating a trailing or ghost effect. This will require a technician to replace that board though. Hope this help.
Feb 14, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung LN-T4661F 46 in. LCD HDTV Logo
977 people viewed this question
Jerry Greenberg
Jerry Greenberg
