Question about Canon Office Equipment & Supplies
Dismantle the Canon PC6 copier to remove paper fragments.
Which screws to open up the Canon PC6 copier to get to the paper fragments stuck in the outfeed.
  • 1,219 Answers
Try to dismantle it by the look, you need to remove leftside covers.
If you want I can send you service manual.
emma.servis@gmail.com
Posted on Jul 03, 2010
HOW DO I CLEAR PAPER JAM ON KODAK ESP.5
It's probably a fragment or small piece. Look at paper path with a lot of light very carefully. You may need to dismantle to clear it.
Aug 08, 2014 | Kodak EasyShare Office Equipment &...
Without paper jam, the system is showing paper jam ? why ?
try to run Maintenance from windows control panel, also open all compartments on teh printer and look to see if there is a fragment of paper stuck there.
Jul 22, 2014 | Canon LASER SHOT LBP-2900 Printer
Left side paper jam and the paper has been removed, but it still says paper jam. What should we do?
Use a flashlight and inspect as much of the paper path as you can see. You are likely to find a torn piece or even just a fragment left over from a previous jam. You may need to use tweezers for fragment removal and aoolication of compressed dusting air may help.
Sep 11, 2012 | Canon Imagerunner 1025IF Grayscale Copier
It keeps telling me there is a paper jam but I see no paper in printer??
Check for the paper fragments inside. It is also likely that while removing the paper either some fragments are stuck or the pick up roller pivot is broken.
sonsunny
Jun 24, 2011 | Canon PIXMA iP1600 Printer
Welll its not a canon but ew are in dire need. Our 16 month old OKI b4600 wont print.Error message says clear paper jam. cant find a jam swapped tray, cartridge/drum etc. No luck. Any suggested
Hi There and Welcome to Fixya,
Usually, paper jams can occur at the input location right at the bottom of the printer - always remember that even a tiny piece of paper can cause halt in printing, hence, the error message.
Here's what I'm suggesting for you to do :
  • Start with pulling out the tray from the printer and look for ANY crumpled/pieces/fragments of paper that could be tucked in.
  • At the bottom of the printer is the feed area - do the same thing and remove any pieces of paper.
  • Ensure that it's absolutely "paper fragment free" before returning the tray back at the printer.
  • Next, is to open the top cover and carefully remove the drum.
  • Remove any pieces or fragments of paper that you find.
  • Carefully slide back the drum, ensure that everything snaps into place.
  • Close the top cover.
  • Restart your printer.
I most certainly hope this helps.
Thank you for using FixYa.
Mar 25, 2011 | Canon PC-940 Black and White Copier
Small piece of paper can not be found, which the jamming the printer, someone in forum recommends to unzip the printer. May someone please tell me how to unzip the printer.
By unzip, i believe you mean dismantle the printer. Dismantling the printer can (and most probably will) void your warranty. So please consult either Canon themselves or where you bought the product from.
However if the warranty of your device has already ended then remove the screws of the panels one by one, removing each panel and placing the screws with them so they don't get lost or mixed up. Make your way to the cartridge carriage and try to get them to the center for easy removal. After which inspect the roller or carriage for any small pieces of paper that may be jamming the carriage. Remove if found, otherwise try using canned air to blow at the most probable places where the paper might have gotten stuck.
Proceed to re-assemble the printer and try to see if it works. If it does then great, otherwise please go to your nearest canon certified repair shop.
Mar 20, 2011 | Canon PIXMA MX310 All-In-One Printer
It says remove jammed paper whene there is no paper in it
There might be a fragment of paper that is holding a sensor switch in the armed position, otherwise theswitch is stuck and needs to be freed. Careful inspection is required as it does not take much togive this fault.
Jan 16, 2011 | Canon PIXMA MP160 All-In-One Printer
Problems retrieveing stuck paper
First open toner door, remove two screws, open fixing cover remove screws, on copy glass remove plastic covers, screws are under small stickers, then from right sideway of lcd panel remove two screw. Then you need to dismantle it how you see, where you have problems there is plastic nose wich you need to unloose.
If you want service manual, send me mail on emma.servis@gmail.com
Jul 01, 2010 | Canon PC-D340 Black and White Copier
Paper jam in fix unit of canon image runner 1670F. How do I get fixing unit out.
canon will tell you the fixing assy. is not to be serviced in the field from experiance I know customers can break these very easily
but if your careful you should be ok
open left hand door
remove front corner panel 2 screws
you need to remove the 2 screws on the black tabs and the 2 large vertical screws 1 front and 1 rear
also there is an earthing screw and the connector block disconnect the 3 connections and remove the unit complete
but be carefull this is were most people go wrong and end up damageing the fixing film or thermistor neither of whitch can be repaired
damage these and you will need a new unit
once you have all the paper out reverse the process to refit assy.
good luck
Jul 11, 2009 | Canon Office Equipment & Supplies
CANON 6085 PROBLEMS
Was it working before the problem? Did the user have a paer jam? You may have a jammed pice of paper in the paper feed unit
Jun 08, 2008 | Canon NP 6085 Copier
124 people viewed this question
old marine
old marine
