Question about Kwikset Professional Door Lock installation Kit
Rekey schlage cylinder without original key
Hey, I have schlage cylinders with spool pins in 4 out of 5 chambers. I can't pick them by hand or with the gun...I tried peeling the top off the cylinder to pop the springs, but now I can't get the top to wedge back in! So my questions are:
How do I replace the top, if possible.....
If i can't pick it, what can I do?
Are the levers with sideways keyways harder to pick in general?
Thanks much!
  • 10 Answers
SOURCE: Lost entry door key, need to rekey kwikset deadbolt
Unfortunatley you need to have the key to remove the cylinder. You can take it to a locksmith that can pick" it to remove the cylinder and make you a key but it may be more cost effective to replace it.
Sorry not to be mre help.
Posted on May 22, 2009
SOURCE: I bought 2 kwikset deadbolts.The first one worked
put the 'dummy key' that came in with it, turn it a 1/4 turn right, put smart key in, pull out smart key. pull out the key and insert the key that you would have as a desired key and turn left 1/4. thats it!!!!!!
Posted on Jul 20, 2009
rsmith972278
  • 160 Answers
SOURCE: I have Kwickset door knobs on my outside doors. I
The instructions they send are almost always generic and cover more than one subject.
If you insert the key and turn it all the way clockwise, you should be able to insert the tool tip they sent you into the hole on the shank part of the handle. Pull straight out and it should come off. Some times it takes several attempts to do.
Next turn key counter clockwise back to starting position and remove key. Dump lock out of handle, paying attention to orientation. Turn lock 180 degrees and reinsert back into handle. Put lock and handle back on to door and reinsert the key. Turn key clockwise and push.... remove key.
Hope this Helps,
RSMITH972278
P.S. PLEASE RATE MY ASSISTANCE
Posted on Jan 21, 2010
SOURCE: we tried to rekey our kwikset smart key, but
I had mine do the same thing right before I was leaving to the airport [re-keying for the house-sitter]. I was setting the lock and I hear a spring-type ping and the keying was lost.
The tumbler can be reset to your key. However, it involves disassembling the device and has small parts.If you are feeling lucky, you can do this yourself or take it to a qualified person.
If you are feeling lucky:
A: Disassemble the lock from the door
B: Remove the door handle from around the key side.
C: Remove the U retaining-clip from the outside of the lock that is securing it to the shaft.
D: Remove the lock from the shaft
E: Remove the U retaining-clip from the tumbler body and the case
F: You will have to press the five fingers down evenly on the length of the case to slide the cylinder out of the case. (I cut a plastic card with small wire cutters to make a tool, but you could probably use thick card-stock and some scissors.)
Be careful; you will have to watch for and secure the check ball on one side of the tumbler and the finger lock bar on the other side as you slide this out.
G: Remove and store the check ball securely as well as the finger lock bar. (careful with the plate surrounding the fingers that the finger lock bar resides in)
H: Remove the finger locking plate. Carefully, make sure the fingers are still inside and oriented correctly and the spring at the back of the finger locking plate is left in place.
I: You will notice a u channel groove in the fingers and the finger locking plate. Align the fingers in the finger locking plate evenly so that the grooves in the fingers match the groove in the finger locking plate.
J: Replace the finger locking plate with fingers aligned evenly with the u channel groove back onto the tumbler body and hold back against the spring left on the rear of the tumbler body. This puts the tumbler into re-key position.
K: Replace the finger locking bar onto the finger locking plate while holding the assembly against the spring and tumbler body. (If this is done correctly, the finger locking bar will now be flush with the side of the finger locking plate and not raised as normal.)
L: While holding the tumbler assembly together and maintaining the locking plate pressed against the spring, Insert your new key into the tumbler body.
M: While holding this assembly in this position, add the check ball to the tumbler assembly.
N: While holding the assembly in position, slightly depress the black plastic block at the back of the finger locking plate and slide this tumbler assembly back into the tumbler case taking care to rotate the case 90 degrees clockwise from normal. (Note the U channel groove inside the tumbler case that normally receives the finger lock bar and use that for orientation.)
If the tumbler does not insert cleanly, verify the finger locking bar is flush. If it is not, redo while maintaining proper pressure to keep the finger locking plate firmly against the spring in re-assembly. Also, verify the fingers are not protruding from the tumbler body. If they are, redo the procedure taking care to align the fingers properly on assembly and maintain proper force on the finger locking plate against the tumbler body during re-assembly and new key insertion
O: Rotate the key and tumbler body in the case to the normal position (counter-clockwise 90 degrees).
P: While holding the tumbler body firmly against the case, remove the key.
Q: Re-insert the key and verify smooth rotation.
R: Align the tumbler body and case back to the normal position and while holding the tumbler body firmly against the case, remove the key.
S: Replace the U retaining-clip that belongs on the back of the tumbler body to secure it within the case.
T: Replace the tumbler body in the main lock shaft and secure with the shaft U retaining clip.
Posted on Nov 12, 2010
snowghost1
  • 784 Answers
SOURCE: How do I rekey smartkey when original keys are
the only way to fit a new key to the ' smartkey ' lock system is to use the Kwikset smartkey reset tool, then after the cylinder is reset - you can put a new key in it for alignment.
this tool is availible at most lockshops and they will reset the lock for about 5 dollars.
c...
Posted on Jan 14, 2011
How do i remove the plugs covering the screws on the schlage deadbolt?
Schlage FAQs Schlage
The double cylinder deadbolts are keyed on both sides. On the interior side of the home there are drive pins (sometimes called screw covers) covering up the screws. Recommended method: Indent the center of each drive pin with a nail punch. Then use a carbon tip drill bit (about the size of a pencil lead) and ONLY go down 1/8". The drive pin will disintegrate. The drive pins will need to be replaced as they are no longer usable.
Sep 16, 2014 | Schlage Deadbolt. Double Cylinder Deadbolt...
Why is my security light blinking and wont start?
The most common problem is your lock cylinder.
The lockcylinder is equipped with spring loaded contact to touch the chip on the key. After years of use the spring collapse.
Disconnect the battery,remove airbag,remove steering wheel, remove column cover,disconnect orange wire under the dash,turn ignition switch to running position and push the locking pin with small pick . Pull the old cylinder out (tight fishing cord to the end of the orange wire before you pul and use the cord to pul the new one back)
Buy AC Delco plain cylinder and rekey to your old key.you're saving money from reprogramming the new key
Install in revers order
Good luck
Aug 15, 2014 | 1999 Chevrolet Silverado 1500
Front door lock jammed after reassembling. 6 pin lock reassembled and is now jammed. I've taken a 6 pin lock apart, well it came apart in my hand, and think I may have put the pins back in the wrong...
Locksmiths can often solve this problem by using a very thin Stainless Steel shim. It needs to be stiff enough to push between the tumbler pins at the shear line, but thin enough to slide between the plug and the cylinder body. The pins must be raised with a pick or key blank until the shim slides through one pin chamber at a time. When all pins are aligned at the shear line, the plug will rotate and the cylinder can be disassembled. You might have a missing spring or part of a spring jammed
Jul 20, 2014 | Locks & Locksmithing
Cant get the key to start truck or go into acc postion to remove
Sounds like a couple waffers have broken inside and 1 of them is stuck preventing the cylinder from turning. The waffer is above the shear line.
You will need to remove the bottom cover of the instrument dash to access the ignition cylinder. On the bottom of the cylinder there will be a hole. When the cylinder is in the ACC position, it will provide an opening in that hole so you can depress the lock pin. When the pin is depressed you simply pull out the ignition cylinder as a whole. Since you cannot get to ACC you will need to drill into the little hole until you reach the pin. Then you will have to drill the pin too. After that it will slide right out.
A new ignition cylinder with new keys can be picked up for about $30 on ebay. You could take the new one to a locksmith and have them rekey it to your old keys for about $30.
Mar 12, 2014 | 1998 Toyota Tacoma
No key for a schlage dead bolt i like to rekay
If you don't know how to open a lock cylinder in your hand, you probably should take it to a professional locksmith. They don't charge much to rekey a lock that you bring into the shop, and they can usually do it in under ten minutes. Twelve minutes if you don't bring a key that can open it.
That said, you can open it by shimming with a key blank and a shim, bumping with a bump key, removing the slide or top of the cylinder, picking with a pick, pick gun, or electric pick, key picking it, using tryout keys, rapping it open with a hammer handle, or simply wiggling every old key you can find in it until it either turns or you run out of old keys.
Dec 20, 2013 | Kwikset Professional Door Lock...
Schlage Secure key deadbolt is seized up. The reset key will not move at all in the lock. It is supposed to move 30 degrees to the left to reset the lock. It worked once. We have been using our front...
The best way to free up a lock is with graphite powder. Give it a good dose (put down some newspaper first to catch any falling particles) and "puff" it in. Do this several times, working the key between times and after. If it is still stubborn, loosen the interior bolts that hold the halves together. Loosen just enough so that the halves can re-orient themselves slightly (called "wiggling in"). You'll find a spot where the lock works smoothest. Tighten up the blots, but don't over tighten. Continue to work the key until you're satisfied that the position is as good as you can get it. Graphite is available at Lowe's, Home Depot or even Hobby Lobby (used for Pinewood Derby cars). Same stuff. By the bye, you should use graphite on all your locks from time-to-time. It keeps the cylinder, springs and pins freed up, making the action of the locks very smooth. I never work on a lock without adding graphite powder first.
Best regards, --W/D--
Jan 16, 2011 | Garden
How do i rekey the deadbolt to fit the doorknob key?
You would need to take it to a lock smith or an ace hardware. also bring one of the doorknobs so they can key it alike. Unfortunately, keying locks is not something that you can do without advanced equipment and experience.
Aug 15, 2010 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
How do I remove the ignition lock cylinder from a 2003 Saturn Vue for rekeying?
REMOVAL
  1. Disable SIR system. (Refer to "SIR Disable/Enable Procedure (For Frontal and Curtain Inflators)".
  2. Disconnect negative battery cable.
  3. Remove lock cylinder bezel from steering column shroud by carefully prying with thin blade screwdriver.
  4. Remove shroud fasteners and remove steering column upper and lower shroud panels.
  5. Insert key into ignition lock cylinder and rotate to RUN position. Then rotate ignition cylinder back to ACC position.
  6. Depress locking button on side of ignition module assembly with a thin pick-type tool. Slide lock cylinder assembly from ignition module.
INSTALLATION
IMPORTANT: Actuator blade within ignition module housing must be in ACC position to install lock cylinder assembly. If rotated, replace it to ACC position, using needle nose pliers.
  1. Insert key into ignition lock cylinder and install into ignition module.
  2. Install steering column upper and lower shrouds and shroud fasteners.
  3. Install lock cylinder bezel.
  4. Connect negative battery cable.
  5. Enable the SIR system. (Refer to "SIR Disable/Enable Procedure (For Frontal and Curtain Inflators)".
Apr 07, 2010 | 2003 Saturn VUE
I have a schlage deadbolt without the original key. is there any way to rekey without having to take cover plate off top of cylinder?
yes call lock smith for about thirty dollars they can make you a key right on the spot without removing lock.
Jan 05, 2010 | Electrical Supplies
Rekeying kwikset locks
Sure. You need to install the key in the cylinder and keep it turned so the pins are on top. Then you install the pins one at a time in each hole until all the pins fit level with the top of the cylinder, You will probably have to re-arrange the pins once or twice to get the correct length in the correct hole but once all the pins are level you're home free.
Sep 30, 2008 | Locks & Locksmithing
Kwikset Professional Door Lock installation Kit Logo
2,971 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
J.D. Browning
J.D. Browning
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
